    Help with MMM-EmbedURL
    28 Posts 3 Posters 11.5k Views 3 Watching
    • T
      TK421_VT
      I am new to MM and need help. I am trying to embed a WeatherUnderground url of my personal Weather station to my MM. I have loaded the module and added the basic code to my config file, but I get nothing. It sounds like it might be an issue with Embed sites that forbid embedding and Cookie banners, but I don’t understand how to remove it. I see the Chrome extension Requestly, but I don’t understand how or where to use it.
      Here is an example of a webpage that I want to use: https://www.wunderground.com/dashboard/pws/KVTCAMBR4?cm_ven=localwx_pwsdash
      Any help would be greatly appprecated.
      S wishmaster270W 2 Replies Last reply
      • S sdetweil moved this topic from Showcase on
        sdetweil @TK421_VT
        @TK421_VT said in Help with MMM-EmbedURL:
        I setup the module and see this error in the developers window
        ctrl-shift-i on keyboard, select the console tab
        Refused to display 'https://www.wunderground.com/' in a frame because it set 'X-Frame-Options' to 'sameorigin'.
        also see this in the console output from npm start
        [16.12.2022 07:04.53.720] [ERROR] (node:4015) electron: Failed to load URL: https://www.wunderground.com/dashboard/pws/KVTCAMBR4?cm_ven=localwx_pwsdash with error: ERR_BLOCKED_BY_RESPONSE
        I don’t know how to solve this
        • wishmaster270W
          wishmaster270 Module Developer @TK421_VT
          @TK421_VT Hi,
          i setup a quick dev environment and tried to add the URL. You are right the page forbids embedding.
          If a activate the Requestly extension in my Firefox and remove the response headers “X-Frame-Options”, “Content-Security-Policy”, “X-Content-Security-Policy” the site can be embedded. I am pretty sure if you follow the instructions in this tutorial you can embed the site into a MagicMirror instance that is running in server mode and is displayed within Firefox or Chrome.
          The question is if you are running MagicMirror in sever mode and display it in a local browser. If not you use the electron browser and you do not need any extensions but can use webview to embed the site.
          You will need to enable webview in the electronOptions as described in the Readme of the module and you need to set embedElementType: "webview" in the module configuration.
          S T 2 Replies Last reply
            sdetweil @wishmaster270
            @wishmaster270 and I provide a script to launch chromium over server mode in my script repo.
            I set that up auto for pi0w.
            run-start.sh
            change the npm start to launch the run-start.sh
            T 1 Reply Last reply
            • T
              TK421_VT @wishmaster270
              @wishmaster270 said in Help with MMM-EmbedURL:
              embedElementType: “webview”
              I am guessing I run Requestly on the PI itself on the default Browers? I don’t currently have Firefox or Chrome loaded on it (not that it is that hard to install).
              Honestly, I have no idea if I am running in Server Mode. I install the basic 64 bit PI OS. I am guessing that is not the Server Mode?
              I tried adding WebView to the Config file with no change:
              module: “MMM-EmbedURL”,
              position: “top_right”,
              header: “Current Weather”,
              updateInterval: 120,
              attributes: [
              “frameborder=0”,
              embedElementType: “webview”,
              embed: [
              “https://www.wunderground.com/dashboard/pws/KVTCAMBR4?cm_ven=localwx_pwsdash”
              Thoughts?
              • T
                TK421_VT @sdetweil
                I don’t have a start-up script running yet, I manually launch it with: npm run start as I am still configuring things.
                Is there something I am missing as to why I should?
                  sdetweil @TK421_VT
                  @TK421_VT note that u also have to allow WebView in the electronOptions config up by address/ipWhitelist
                  • T
                    TK421_VT
                    I am not going to lie, I wish I understood what you just said.
                      sdetweil @TK421_VT
                      @TK421_VT read his instructions. you have to enable electron webView before u can use it in a module
                      • T
                        TK421_VT @sdetweil
                        @sdetweil Thank you for trying to help, but even after reading the readme there are terms or concepts I don’t follow.
                        This is at the beginning of the config file:
                        let config = {
                        electronOptions: {
                        webPreferences: {
                        webviewTag: true,
                        Then this in the module:
                        basicElementType: “div”,
                        attributes: [
                        “frameborder=0”,
                        embed: [
                        this is what I see in the terminal log:
                        [16.12.2022 21:55.38.765] [ERROR] (node:57092) electron: Failed to load URL: https://www.wunderground.com/dashboard/pws/KVTCAMBR4?cm_ven=localwx_pwsdash with error: ERR_BLOCKED_BY_RESPONSE
                        wishmaster270W 1 Reply Last reply
                        • wishmaster270W
                          @TK421_VT Hi,
                          your config looks good.
                          There is one last thing we can try. Can you please use your IP address (the one of the Pi) instead of localhost at the address setting.
                          You can get your IP either by hovering over the network icon in the top right corner of the screen or by entering
                          ip a
                          in the shell.
                          I had this changed for some other modules in my config cause of Cross-Origin problems and it is the only thing that is different in my setup.
                          • T
                            @wishmaster270 Thanks I will give that a try, I know the IP as I set it statically.
                            • T
                              TK421_VT @TK421_VT
                              @TK421_VT Sorry for the delay, I have been busy with Holiday stuff. I added the IP address in the config file
                              it still doesn’t load anything in the top right region.
                              This is what is in the module section in the config file
                              Any other thoughts?
                              • wishmaster270W
                                @TK421_VT Hi,
                                that’s weird.
                                Do you still have Webview enabled in the config with:
                                electronOptions: {
                                  webPreferences: {
                                    webviewTag: true,
                                • T
                                  @wishmaster270 I will look, I ‘think’ so. but I am not sure.
                                  • T
                                    • wishmaster270W
                                      @TK421_VT Sorry for the late response. I will need to set up a identical environment to debug the problem. I will try to figure things out in the next days.
                                      wishmaster270W T 2 Replies Last reply
                                      • wishmaster270W
                                        wishmaster270 Module Developer @wishmaster270
                                        @TK421_VT
                                        I setup a new environment today and tested your configuration. There are a few issues with it i did not see cause you did not use the code signs to paste your configuration in the forum.
                                        Please use the
                                        YOUR CONFIGURATION
                                        which results in
                                        YOUR CONFIGURATION
                                        next time.
                                        First thing is that you set the basicElementType and embedElementType in the wrong level. They need to be set as child object of config.
                                        The second problem is that you use a wrong time of double quotes. It looks like your editor uses a wired type of encoding.
                                        is not the same as
                                        With the following config everything works well:
                                        /* Magic Mirror Config Sample
                                         * By Michael Teeuw https://michaelteeuw.nl
                                         * MIT Licensed.
                                         * see https://docs.magicmirror.builders/getting-started/configuration.html#general
                                         * and https://docs.magicmirror.builders/modules/configuration.html
                                        let config = {
                                        	electronOptions: {
                                        		webPreferences: {
                                        			webSecurity: false,
                                        			webviewTag: true,
                                        		fullscreen: true,
                                        		alwaysOnTop: false
                                        	// ignoreXOriginHeader: true,
                                        	// ignoreContentSecurityPolicy: true,
                                        	address: "192.168.1.1", // Address to listen on, can be:
                                        	port: 8080,
                                        	basePath: "/", // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                                        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "10.18.8.0/24"], // Set [] to allow all IP addresses
                                        	useHttps: false, // Support HTTPS or not, default "false" will use HTTP
                                        	httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true
                                        	httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true
                                        	language: "de",
                                        	locale: "de-DE",
                                        	timeFormat: 24,
                                        	units: "metric",
                                        			module: "clock",
                                        			position: "top_center",
                                        			module: "MMM-EmbedURL",
                                        			header: "Current Weather",
                                        				embedElementType: "webview",
                                        				basicElementType: "div",
                                        				attributes: [
                                        					"frameborder=0",
                                        				embed: [
                                        			module: "MMM-Touch",
                                        			position: "bottom_center",
                                        				debug: true,
                                        				useDisplay: false,
                                        				defaultMode: "default",
                                        				gestureCommands: {
                                        					default: {
                                        						TAP_1: (commander) => {
                                        							commander.sendNotification("USER_PRESENCE", true);
                                        						PRESS_1: (commander) => {
                                        							commander.sendNotification("SCREEN_TOGGLE", { forced: true });
                                        						SWIPE_UP_1: (commander) => {
                                        							commander.sendNotification("SCREEN_ON", { forced: true });
                                        						SWIPE_DOWN_1: (commander) => {
                                        							commander.sendNotification("SCREEN_OFF", { forced: true });
                                        						SWIPE_LEFT_1: (commander) => {
                                        							commander.sendNotification("PROFILE_INCREMENT_HORIZONTAL", null);
                                        						SWIPE_RIGHT_1: (commander) => {
                                        							commander.sendNotification("PROFILE_DECREMENT_HORIZONTAL", null);
                                        if (typeof module !== "undefined") {
                                        	module.exports = config;
                                          @wishmaster270 the bad " is because of the no code wrapper
                                          see this
                                          "something"
                                          vs this
                                          “something”
                                          copy/paste of the second will cause bad config message
                                          @TK421_VT to use the code wrapper
                                          paste your text in the message editor, select it all
                                          the hit the button above the edit that looks like </>
                                          note the code wrapper tag MUST start and end on a blank line…
                                          • T
                                            @wishmaster270 Moving basicElementType & embedElementTpe into the correct location seemed to work.
                                            Is there any way to make the window Wider or Longer? Or is it this size because of the region it is set in?
                                            T wishmaster270W 2 Replies Last reply
