    Help with MMM-EmbedURL
    28 Posts 3 Posters 9.8k Views 3 Watching
      sdetweil @wishmaster270
      @wishmaster270 and I provide a script to launch chromium over server mode in my script repo.
      I set that up auto for pi0w.
      run-start.sh
      change the npm start to launch the run-start.sh
      • T Offline
        TK421_VT @wishmaster270
        @wishmaster270 said in Help with MMM-EmbedURL:
        embedElementType: “webview”
        I am guessing I run Requestly on the PI itself on the default Browers? I don’t currently have Firefox or Chrome loaded on it (not that it is that hard to install).
        Honestly, I have no idea if I am running in Server Mode. I install the basic 64 bit PI OS. I am guessing that is not the Server Mode?
        I tried adding WebView to the Config file with no change:
        module: “MMM-EmbedURL”,
        position: “top_right”,
        header: “Current Weather”,
        updateInterval: 120,
        attributes: [
        “frameborder=0”,
        embedElementType: “webview”,
        embed: [
        “https://www.wunderground.com/dashboard/pws/KVTCAMBR4?cm_ven=localwx_pwsdash”
        Thoughts?
        • T Offline
          TK421_VT @sdetweil
          I don’t have a start-up script running yet, I manually launch it with: npm run start as I am still configuring things.
          Is there something I am missing as to why I should?
            sdetweil @TK421_VT
            @TK421_VT note that u also have to allow WebView in the electronOptions config up by address/ipWhitelist
            • T Offline
              TK421_VT
              I am not going to lie, I wish I understood what you just said.
                sdetweil @TK421_VT
                @TK421_VT read his instructions. you have to enable electron webView before u can use it in a module
                • T Offline
                  TK421_VT @sdetweil
                  @sdetweil Thank you for trying to help, but even after reading the readme there are terms or concepts I don’t follow.
                  This is at the beginning of the config file:
                  let config = {
                  electronOptions: {
                  webPreferences: {
                  webviewTag: true,
                  Then this in the module:
                  basicElementType: “div”,
                  attributes: [
                  “frameborder=0”,
                  embed: [
                  this is what I see in the terminal log:
                  [16.12.2022 21:55.38.765] [ERROR] (node:57092) electron: Failed to load URL: https://www.wunderground.com/dashboard/pws/KVTCAMBR4?cm_ven=localwx_pwsdash with error: ERR_BLOCKED_BY_RESPONSE
                  • wishmaster270W Offline
                    wishmaster270 Module Developer @TK421_VT
                    @TK421_VT Hi,
                    your config looks good.
                    There is one last thing we can try. Can you please use your IP address (the one of the Pi) instead of localhost at the address setting.
                    You can get your IP either by hovering over the network icon in the top right corner of the screen or by entering
                    ip a
                    in the shell.
                    I had this changed for some other modules in my config cause of Cross-Origin problems and it is the only thing that is different in my setup.
                    • T Offline
                      @wishmaster270 Thanks I will give that a try, I know the IP as I set it statically.
                      • T Offline
                        TK421_VT @TK421_VT
                        @TK421_VT Sorry for the delay, I have been busy with Holiday stuff. I added the IP address in the config file
                        it still doesn’t load anything in the top right region.
                        This is what is in the module section in the config file
                        Any other thoughts?
                          @TK421_VT Hi,
                          that’s weird.
                          Do you still have Webview enabled in the config with:
                          electronOptions: {
                            webPreferences: {
                              webviewTag: true,
                          T 2 Replies Last reply Reply Quote 0
                          • T Offline
                            @wishmaster270 I will look, I ‘think’ so. but I am not sure.
                            • T Offline
                                @TK421_VT Sorry for the late response. I will need to set up a identical environment to debug the problem. I will try to figure things out in the next days.
                                wishmaster270W T 2 Replies Last reply Reply Quote 0
                                  wishmaster270 Module Developer @wishmaster270
                                  @TK421_VT
                                  I setup a new environment today and tested your configuration. There are a few issues with it i did not see cause you did not use the code signs to paste your configuration in the forum.
                                  Please use the
                                  YOUR CONFIGURATION
                                  which results in
                                  YOUR CONFIGURATION
                                  next time.
                                  First thing is that you set the basicElementType and embedElementType in the wrong level. They need to be set as child object of config.
                                  The second problem is that you use a wrong time of double quotes. It looks like your editor uses a wired type of encoding.
                                  is not the same as
                                  With the following config everything works well:
                                  /* Magic Mirror Config Sample
                                   * By Michael Teeuw https://michaelteeuw.nl
                                   * MIT Licensed.
                                   * see https://docs.magicmirror.builders/getting-started/configuration.html#general
                                   * and https://docs.magicmirror.builders/modules/configuration.html
                                  let config = {
                                  	electronOptions: {
                                  		webPreferences: {
                                  			webSecurity: false,
                                  			webviewTag: true,
                                  		fullscreen: true,
                                  		alwaysOnTop: false
                                  	// ignoreXOriginHeader: true,
                                  	// ignoreContentSecurityPolicy: true,
                                  	address: "192.168.1.1", // Address to listen on, can be:
                                  	port: 8080,
                                  	basePath: "/", // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                                  	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "10.18.8.0/24"], // Set [] to allow all IP addresses
                                  	useHttps: false, // Support HTTPS or not, default "false" will use HTTP
                                  	httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true
                                  	httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true
                                  	language: "de",
                                  	locale: "de-DE",
                                  	timeFormat: 24,
                                  	units: "metric",
                                  			module: "clock",
                                  			position: "top_center",
                                  			module: "MMM-EmbedURL",
                                  			header: "Current Weather",
                                  				embedElementType: "webview",
                                  				basicElementType: "div",
                                  				attributes: [
                                  					"frameborder=0",
                                  				embed: [
                                  			module: "MMM-Touch",
                                  			position: "bottom_center",
                                  				debug: true,
                                  				useDisplay: false,
                                  				defaultMode: "default",
                                  				gestureCommands: {
                                  					default: {
                                  						TAP_1: (commander) => {
                                  							commander.sendNotification("USER_PRESENCE", true);
                                  						PRESS_1: (commander) => {
                                  							commander.sendNotification("SCREEN_TOGGLE", { forced: true });
                                  						SWIPE_UP_1: (commander) => {
                                  							commander.sendNotification("SCREEN_ON", { forced: true });
                                  						SWIPE_DOWN_1: (commander) => {
                                  							commander.sendNotification("SCREEN_OFF", { forced: true });
                                  						SWIPE_LEFT_1: (commander) => {
                                  							commander.sendNotification("PROFILE_INCREMENT_HORIZONTAL", null);
                                  						SWIPE_RIGHT_1: (commander) => {
                                  							commander.sendNotification("PROFILE_DECREMENT_HORIZONTAL", null);
                                  if (typeof module !== "undefined") {
                                  	module.exports = config;
                                  S T 2 Replies Last reply Reply Quote 0
                                    @wishmaster270 the bad " is because of the no code wrapper
                                    see this
                                    "something"
                                    vs this
                                    “something”
                                    copy/paste of the second will cause bad config message
                                    @TK421_VT to use the code wrapper
                                    paste your text in the message editor, select it all
                                    the hit the button above the edit that looks like </>
                                    note the code wrapper tag MUST start and end on a blank line…
                                    • T Offline
                                      @wishmaster270 Moving basicElementType & embedElementTpe into the correct location seemed to work.
                                      Is there any way to make the window Wider or Longer? Or is it this size because of the region it is set in?
                                      T wishmaster270W 2 Replies Last reply Reply Quote 0
                                      • T Offline
                                        TK421_VT @TK421_VT
                                        YOUR CONFIGURATION
                                        /* MagicMirror² Config Sample
                                         * MIT Licensed.
                                         * see https://docs.magicmirror.builders/configuration/introduction.html
                                        let config = {
                                          electronOptions: {
                                            webPreferences: {
                                              webviewTag: true,
                                        	address: "192.168.1.40", 	// Address to listen on, can be:
                                        	port: 8080,
                                        	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                        	ipWhitelist: ["192.168.1.40", "127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                                        	language: "en",
                                        	locale: "en-US",
                                        	timeFormat: 12,
                                        	units: "english",
                                        			module: "clock",
                                        			timeFormat: "12",
                                        			displaySeconds: "false",
                                        			showPeriod: "true"
                                            module: "MMM-Bring",
                                            position: "bottom_bar",
                                               email: 'xxxxxx@xxxx.com',
                                               password: 'xxxxxx',
                                               updateInterval: 1, // in Minutes
                                               listName: "Costco", // optional
                                               showListName: false,
                                               activeItemColor: "#EE524F",
                                               latestItemColor: "#4FABA2",
                                               showLatestItems: false,
                                               maxItems: 0,
                                               maxLatestItems: 0,
                                               locale: "en-US",
                                               useKeyboard: false,
                                               customTitle: "Costco List", // optional
                                               listDropdown: false
                                        		module: "MMM-CalendarWeek",
                                        		position: "middle_center",	// This can be any of the regions. Best results in bottom region.
                                        	colored: true,
                                        	coloredSymbolOnly: false,
                                        	maximumNumberOfDays: 21,
                                        	maximumDaysPerLine: 7,
                                        	wrapEvents: true,
                                        	showEndDate: true,
                                        			url: 'https://calendar.google.com/calendar/ical/xxxxxxgmail.com/public/basic.ics',
                                        			symbol: 'calendar',
                                        			auth: {
                                        			    user: 'xxxxxxxx',
                                        			    pass: 'xxxxxxxx',
                                        			    method: 'basic'
                                            attributes: [
                                                "frameborder=0",
                                              embed: [
                                                "https://www.wunderground.com/dashboard/pws/KVTCAMBR4?cm_ven=localwx_pwsdash"
                                        • T Offline
                                          @wishmaster270 No worries on the late reply, the holidays are a busy time!
                                            sdetweil @TK421_VT
                                            @TK421_VT note that I edited your post to add code wrapper around your config.js content
                                            you placed it around the words 'your configuration ', which was supposed to mean the content of the config.js on you MagicMirror installation
