    MMM-ProfileSwitcher, A Profile/User/Layout Switching Module
    userswitchprofilelayoutmodule
    91 Posts 21 Posters 161.4k Views 23 Watching
    • T
      tosti007 Module Developer
      @Binog To be honest I have no clue why there would be an additional /, try pulling all the new updates from the magicmirror framework (perhaps it was a bug?). The config looks fine for me except the url looks a bit strange NOTIFICATION¬ification that part especially. Does it work when you go to the link manually?
      If there is anything don’t hesitate to contact me!
      ProfileSwitcher, TouchNotifications
        Binog
        so the Notification,.,. is a compiling-error of this board. as mentioned above or elsewhere it does look correct in the config file.
        Actually I am a bit further, and ruled out some errors,.none the less I am not able to switch profiles!
        If I press one of my - not working - bottoms, I get these errors:
        konsole:
        source-code:
          Binog @Blackmirror
          @Blackmirror
          Where to You let Current_profile been read?
            Blackmirror @Binog
            @Binog
            I understand your question not really.
            I send the current_profile with MMM-Buttons and use it with MMM-RadioDE,
            with
            classes: ‘Radio’
            under the module name
              paul.calladine
              My mirror is just about finished, I have the MMM-PIRSensor working and MMM-Buttons working which both allow me to wake/sleep the monitor working fine.
              However i’d like to use MMM-Buttons as a toggle switch to enable me to essentially enable or disable the PIR sensor module:
              i.e.
              Profile 1 - PIRSensor wakes and turns off the monitor as normal
              Profile 2 - PIRSensor doesn’t do anything on motion being detected and the screen stays off
              I was thinking of modifying the code to do this but does anyone know if this module will allow me to achieve the results? Essentially having two profiles the same but profile 1 includes the PIRSensor module?
              • jdfraserJ
                jdfraser
                Hello and thanks for creating this module! I have experimenting with creating a photo frame and hope that your ProfileSwitcher will get me the rest of the way there.
                I am having an issue with MMM-ProfileSwitcher and using it with MMM-RandomBackground or MMM-RandomPhoto. I have tried some simple troubleshooting steps, but am not sure how to proceed further and hope you could help.
                I have simplified my config.js to try and eliminate other sources as being the issue. Currently I am experimenting using only the clock module, MMM-RandomBackground and MMM-ProfileSwitcher. I have 3 profiles ‘TestA’, ‘TestB’ and default. I ideally like to be able to show a random photo on my frame and alternate having overlays of weather / time / news / etc. based on the profile.
                My idea is to have a class that shows the random photo at a reduced opacity that can have some overlay infomation (clock, weather, news, etc.). And another class that only shows the photo at full opacity.
                The problem I have is that if my config.js has more than one entry for MMM-RandomBackground, it ignores more than the one entry. I am sure I have configured it correctly and have included my config.js below, but I only see a background photo for “TestA” Profile.
                			module: 'MMM-ProfileSwitcher',
                			header: 'Profile',
                				defaultTime: 10000,
                				defaultClass: 'default',
                				everyoneClass: 'everyone',
                				useLockStrings: true,
                				leaveMessages: false,
                				enterMessages: false,
                				timers: {
                					// when TestA is selected swap to the defaultClass after the defaultTime
                					"TestA": {},
                				        // When TestB is selected swap to TestA after 20 seconds
                				        "TestB": {
                						profile: "TestA",
                					    //	time: 20 * 1000
                					"default": {
                						profile: "TestB"
                			module: 'alert',
                			displayTime: 10000
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			disabled: false,
                			classes: "TestA",
                			position: "bottom_left",
                				timeFormat: 12,
                				displaySeconds: false,
                				showPeriod: false,
                				clockBold: false,
                				dateFormat: "MMMM Do"
                			module: "clock",
                			disabled: false,
                			classes: "default",
                				timeFormat: 12,
                				showPeriod: false,
                				clockBold: false,
                			module: "clock",
                			disabled: false,
                			classes: "TestB",
                				timeFormat: 12,
                				showPeriod: false,
                				clockBold: false,
                			module : 'MMM-RandomBackground',
                			disabled: false,
                			classes: "TestA",
                			position : 'fullscreen_below', // Any region but this one makes the most sense
                			config : {
                				animationSpeed : 2000,
                				updateInterval : 50000,
                				opacity : 1
                			disabled: false,
                			classes: "TestB",
                			config : {
                				opacity : 0.5
                If you are able to offer any insight as to why this might be happening or further troubleshooting I could do, I would greatly appreciate it.
                *** Full disclosure ***
                I originally posted this help request under another topic, but thought there would be a better chance that I might get more timely help with my issue in this topic. Sorry for the cross-post. :)
                  Cyberdyne
                  Is it possible to include a BT detection to switch profiles? RPi3 has a build BT which is not used (at least in my configuration) by the MagicMirror. It would be great if personal stuff like the calender could be switched depending on the BT device (Smartphone, Smartwatch, Fitnesstracker, …) which is near by.
                  I was searching for identification via BT on the RPi and this is what I have found so far:
                  “…present/absent can be done with very little power consumption on rPi and iPhone. Install bluetooth dongle on rPi as: (sudo aptitude install bluetooth bluez-utils bluez-compat). Figure out mac of your phone device by making it searchable and then do (hcitool scan) on rPi. Then connect to your device (make sure its searchable) as: sudo bluez-simple-agent hci0 mac_of_your_device and say yes on both sides. Then sudo bluez-test-device trusted mac_of_your_device. Now they both “know” each other. Then do sudo hcitool name mac_of_your_device in your favourite script to figure out if the iphone is nearby. This will not create a connection - but just say hi to it. If it returns a name, phone is nearby. If it returns nothing - phone is not nearby or bluetooth is switched off. Compared to creating connections or other distance computation methods out there - this method conserves battery on both sides and keeps airwave pollution to a minimum.” (found here)
                  and this would be even better with distance sensing:
                  https://www.raspberrypi.org/forums/viewtopic.php?f=37&t=47466
                  F 1 Reply Last reply Reply Quote 1
                  • F
                    fcornelius @Cyberdyne
                    @cyberdyne I had the same idea two days ago and did some research on it. I also asked /r/smartmirrors for some advice on it and got pretty good tips. The bottom line is, if you want to have a solid, non hacky solution supporting both iOS/android go the other way round with the use of beacons.
                    Thread is here
                      3squaremirror
                      having issue showing MMM-Profilepicture using MMM-ModuleScheduler and MMM-ProfileSwitcher.
                      I’m trying to switch a day and night time image with profilepicture. Using modulescheduler to switch the image based on the time.
                      As far as I can tell, each module is running correctly, as I’m not seeing any error in the console log.
                      i think the issue has to do with LockStrings, and i don’t know how to fix it
                      Will not show MMM-Profilepicture. LockStrings active: module_2_MMM-ProfileSwitcher
                      my configs
                      //////////////////// profile ///////////////////////////
                                  disabled: false,
                                  classes: 'default everyone',
                              module: 'MMM-ModuleScheduler',
                              disabled: false,
                                  notification_schedule: [
                                      // SWITCH TO THE DAY PROFILE AT 07:30 EVERY DAY
                                      {notification: 'CURRENT_PROFILE', schedule: '30 7 * * *', payload: 'day'},
                                      // SWITCH TO THE NIGHT PROFILE AT 23:30 EVERY DAY
                                      {notification: 'CURRENT_PROFILE', schedule: '30 18 * * *', payload: 'night'},
                                  module: "MMM-Profilepicture",
                                  position: "fullscreen_below",
                                  classes: "day",
                                  disabled: false,
                                      url: "https://images.unsplash.com/photo-1623150502742-6a849aa94be4?ixlib=rb-4.0.3&ixid=MnwxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8&auto=format&fit=crop&w=1980&q=80",
                                      opacity: 1,
                                      maxWidth: "120%",
                                      maxHeight: "120%",
                                  classes: "night",
                                  disabled: false,
                                      url: "https://images.unsplash.com/photo-1620121692029-d088224ddc74?ixlib=rb-4.0.3&ixid=MnwxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8&auto=format&fit=crop&w=1980&q=80",
                                      opacity: 1,
                                      maxWidth: "140%",
                                      maxHeight: "140%",
                          ////////////////end profile //////////////////////////
                        sdetweil @3squaremirror
                        @3squaremirror don’t know, but please don’t double post.
                        members with reputation below 2 have every post reviewed.
                        this stops the unrelated spam we get every day (6 this morning).
                          @3squaremirror yes. profileswitcher says it’s in charge of hiding and showing modules (via lockstring)
                          so. can u force profile switcher to switch to that users profile?
                          3 1 Reply Last reply Reply Quote 0
                            3squaremirror @sdetweil
                            @sdetweil my apology about the double posting, it’s noted. i am not clear on how to force profile switcher to switch. can you elaborate that?
                              @3squaremirror sorry, no idea. was just a thought. know nothing about the module
                              wishmaster270W 1 Reply Last reply Reply Quote 1
                              • wishmaster270W
                                wishmaster270 Module Developer @sdetweil
                                @3squaremirror
                                Do you use any other modules which may hide/show modules?
                                If i copy your configuration to my test environment and add some notifications (change day/night every minute) everything works as expected.
                                  3squaremirror @wishmaster270
                                  @wishmaster270 i also use the Touch and Pages module.
                                  • wishmaster270W
                                    wishmaster270 Module Developer @3squaremirror
                                    @3squaremirror
                                    I think the problem is the pages module. It uses lockstrings as well and may block the module of being shown.
                                    Tried combining pages and profiles a view years ago and had very similar problems.
                                    But you can ralize all you can do with MMM-pages and MMM-page-indicator with MMM-ProfileSwitcher and MMM-ProfileControl. So there is no need to mix Pages and Profiles.
                                      @wishmaster270 thank you, i think you’re right. i read about forcing a module to unhide the lockstring. not sure how to get that done.
                                        @3squaremirror some code needs to use the force parameter on the show() or hide() functions.
                                        but I can’t tell from the log which code issued the show/hide. only that the profileswitcher had it locked
                                        • 5 / 5
