    Motion Detector
    213 Posts 38 Posters 584.3k Views 39 Watching
    • in_a_daysI
      in_a_days @oscarkindberg
      @oscarkindberg Try this instead:
                          module: 'motiondetector',
                                  timeout: 300000 // time in milliseconds for to switch off the display after last movement is detected.
      This is set for a 5 minute delay. Modify the timeout value if you want a longer or shorter delay before your screen turns off.
      O 1 Reply Last reply
      • O
        oscarkindberg @in_a_days
        @in_a_days Hit! Works now, BUT next issue.
        After 5-6 min the screens goes white, can’t find anything in the code that would cause that.
        D 1 Reply Last reply
          phoenixrising
          I apologize if this a very noob question but I am having trouble getting the motion detector module running. I have clone the files to the module folder. I have modified the config file but maybe I dont have it correct. Could some one show me how the config file be modified to get the module running. Any other pointers? Thank you,
            danielis @oscarkindberg
            @oscarkindberg try hdmi_blanking=1in /boot/config.txt
              danielis @phoenixrising
              @phoenixrising look at the last reply of in_a_days.
              If that is not working post your config.js here.
              • O
                oscarkindberg @danielis
                @danielis Where do I fint that? I’ve searched all the .js files in the module and config.
                  @oscarkindberg it is the file config.txt in the folder /boot/
                  type ‘sudo nano /boot/config.txt’ without ’
                  add as last line:
                  hdmi_blanking=1
                  • O
                    @danielis Actually got it to work now, changed to “updateInterval: 10000” from “updateInterval: 1000” and in diff-cam-engine.js I changed captureIntervalTime to 1000 instead of 100.
                    Made it easier on the RBP3 i think.
                    Downloaded MMM-SystemStats to keep check on sysload during config and it’s lookin’ good now.
                    Thanks for the help! I’ll comeback with a picture of the mirror as soon as my mirrorglas arrives.
                    P 1 Reply Last reply
                      phoenixrising @oscarkindberg
                      @oscarkindberg where is the updateinterval located?
                      • O
                        oscarkindberg @phoenixrising
                        @phoenixrising Sorry! I meant timeout: 10000 in config.js file. Copy pasted wrong part
                          Jhonte
                          @alexyak I’m using raspberry pi 3 with the camera module. And the motiondetection module.
                          Could not initiate the module before I ran sudo modprobe bcm2835-v4l2 but even after I never get any motion “score”.
                          I inspected the diffImageData it all contained 0,0,0,255 in series…
                          The camera works when using raspistill. Any hints of what I can test to debug the camera output within electro?
                            phoenixrising @Jhonte
                            @Jhonte , post your config file.
                            J 1 Reply Last reply
                              Jhonte @phoenixrising
                              @phoenixrising said in Motion Detector:
                              /* Magic Mirror Config Sample
                               * MIT Licensed.
                              var config = {
                              	port: 8080,
                              	language: 'en',
                              	timeFormat: 24,
                              	units: 'metric',
                                @Jhonte , see oscarkindberg example. You are missing the config portion to your module config file. Ill dig mine up later when I have a chance.
                                  @phoenixrising That is only an override for the defaults? Or am I missing something here. Working the same way with or without the config part.
                                  • W
                                    WLCD
                                    Hey All,
                                    I’ve followed all the instructions in this topic, and I’ve finally got it to work (RPi 3 + PS EYE camera) everything works well for a while, and then HDMI out stays inactive, moreover, the PS EYE Left LED (the blue one) shuts off, normal operation, both LEDs are ON, so there is definitely an issue with Raspbian itself, is there anyone which resolved this since the previous post ?
                                    My config : https://pastebin.com/j7cKDBy3
                                      pepemujica
                                      Hi @alexyak !
                                      Thanks for the module, it looks awesome!
                                      I was trying to use it, at some point I could make it run, I mean, I can set the timeout and the monitor “wakes up” when the pi camera detects any movement.
                                      But when the timeout reachs the limit time, the monitor get off, but after a few seconds it appears a message that says “not signal, cable disconect”.
                                      Is there any way to avoid that alert?
                                      Kind regards
                                        danielis
                                        Never monitors turn off by themselve as soon as there is no signal or after a few minutes without signal. Mine was a old that did not turn on/off automatically.
                                        I used wiringpi to activate a relais that turns the current of the monitor on and off.
                                          pepemujica
                                          @danielis
                                          Sorry I can’t get your point as English is not my first language.
                                          What I’m saying is that when the camera does not detect any movement, and the timeout setted is out, the monitor does not show the mirror, but after a few seconds appears something like this:
                                          0_1495564666424_upload-299d3f7e-ab18-477b-a821-071edeee684f
                                            danielis
                                            OK
                                            But if there is a movement detected - is then the mirror shown?
                                            Why do you expect to see the mirror after the timeout?
                                            The mirror must be on if there is a movement. And if there is no movement and the timeout is over, then is the mirror off.
                                            That is what you want and what this module is doing.
                                            I think your problem is that as soon as the mirror is off, your monitor should turn off - right?
                                            • 10
                                            • 11
                                            • 8 / 11
