    NFL Score Module
    95 Posts 20 Posters 132.6k Views 25 Watching
    • T Offline
      TheHyp3
      I got a problem: Every second its switching between Regular-Season 2016 and Post-Season 2015?
      I´ve updated already but still the same problem. Here is my config:
      		 module: 'MMM-NFL',
      		 position: 'top_left',
      		 	colored: 'true',
      			focus_on: ['NE', 'SEA', 'PHI', 'NYG', 'DAL'],
      Any help on that?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @TheHyp3
        @TheHyp3 thanks for reporting, I made a hotfix for it. I’m not sure how the data will look like when we are in the post season, so it could happen again.
        your config has some syntax errors. you shouldn’t put a boolean into quotes. in javascript it will allways lead to true, so if you would have done colored: 'false' it would have been colored as well.
        T 1 Reply Last reply Reply Quote 2
        • T Offline
          TheHyp3 @strawberry 3.141
          @strawberry-3.141 its working now. Thanks again ;)
          Also fixed my config!
            Fixed not changing to post season and added icons for TBD
            [card:fewieden/MMM-NFL]
              chieftainSupreme @strawberry 3.141
              @strawberry-3.141 has there been any movement on this? I’ve been dying for an NBA module but can’t find a basketball API, and I’m pretty new to the scene to begin with. I’d love to collaborate with someone on this, if there’s interest.
              strawberry 3.141S 1 Reply Last reply Reply Quote 1
                strawberry 3.141 Project Sponsor Module Developer @chieftainSupreme
                @chieftainSupreme sorry I have no time in the next month to do any requests, but i saw that someone forked my repository and trys to change it for nba. check it out maybe you can help him https://github.com/in-a-days/MMM-NBA/
                • I Offline
                  in_a_days @strawberry 3.141
                  @strawberry-3.141 @chieftainSupreme
                  I am playing around with this - but I’m also just barely qualified to write code!
                  I’m gutting out most the higher level functions like stats and voice support, trying to just get correct scores to display. Biggest problem so far is I can not find an easy to parse score feed. This NFL feed is perfect.
                  http://www.nfl.com/liveupdate/scorestrip/ss.xml
                    chieftainSupreme @in_a_days
                    @in_a_days I’ve been having trouble finding an NBA feed as well, I’ll keep looking and let you know if I find anything
                    • I Offline
                      in_a_days @chieftainSupreme
                      @chieftainSupreme
                      Found this today. It’s not nearly as elegant as the NFL xml file, but it should technically be parsable.
                      http://www.espn.com/nba/bottomline/scores
                      • I Offline
                        in_a_days
                        So it’s been over 15 years since I’ve done much coding. My background is in C++ and I ran a few Python tutorials when I first got my Pi.
                        I’m writing a parser for this NBA score feed and it just occurred to me that I don’t know how to integrate a python script into Magic Mirror. I’ve made some good progress, but is there any sense continuing? Will I be able to easily port this to JS or will Magic Mirror know what to do with the .py file, or am I going to need to start over?
                          strawberry 3.141 Project Sponsor Module Developer @in_a_days
                          @in_a_days check out this python shell module https://github.com/paviro/MMM-Facial-Recognition/blob/master/node_helper.js#L11
                          • I Offline
                            in_a_days
                            I’ve completed an ugly parser for this NBA data. I have a python program that stores and prints a list of home teams, away teams, scores, and event times. Can anybody help me with passing these variables into the existing NFL module framework?
                              @in_a_days I suggest to move this into the development section and a new thread for nba
                              Help: you can run the python script in from inside the node_helper and read the output, then send the data to your module with a socket notification
                              I 1 Reply Last reply Reply Quote 1
                              • I Offline
                                @strawberry-3.141
                                Thank you again for the help. I’ve opened a new thread here:
                                https://forum.magicmirror.builders/topic/1431/mmm-nba-nba-scores-module
                                  Fixed issues reported (shows NFL undefined 2017)
                                    Achilles
                                    Is anyone having a problem getting the Preseason 2018 to display? If I reboot my MM, it will say, Preseason 2018, but the final week of the 2017 regular season will display. Any suggestions?
                                    • cowboysdudeC Offline
                                      cowboysdude Module Developer @Achilles
                                      @achilles said in NFL Score Module:
                                      I’m on vacation for a while, please create a github issue if you need help, so I can keep track
                                      Here’s where you do it :)
                                      https://github.com/fewieden/MMM-NFL/issues
                                      But looking at the code real quick it’s not set up for preseason …regular and playoffs only. The NFL only offers those two options for data.
                                        Achilles
                                        Thanks cowboysdude!
                                        If it isnt set up for Preseason, than that would make sense. Regular season, here I come!
                                        • justjim1220J Offline
                                          justjim1220 Module Developer @strawberry 3.141
                                          @strawberry-3-141
                                          @cowboysdude
                                          This MMM-NFL module only shows the preseason from last year…
                                          How do I get it to show the current week’s games and scores?
                                          Or, better yet, How can I get it to show the pre-season, regular season, and playoff games for a single particular team or teams???
                                          What I am wanting is a single page on my mirror to show all the above for 3 certain teams: Chiefs, Cowboys, & Broncos, side-by-side for one view of each team on the same page, so that my eldest son (Broncos), my son-in-law (Cowboys), and myself (Chiefs - of course!) can easily see the comparison between them.
                                          Jim Hallock - 1995
                                            BTW…
                                            I’ve tried to place 3 iFrames on one page, one to show each schedule in a live updated format. But I cannot figure out how to get it to work. Is it even possible to use the same module coded in 3 different ways to show on the same page??? :thinking_face: :thinking_face: :thinking_face:
                                            Jim Hallock - 1995
                                            • 3 / 5
