    access to config language setting
    24 Posts 5 Posters 17.2k Views 5 Watching
      sdetweil @justjim1220
      @justjim1220 no… you are not understanding me…
      how do i get the USERS config for language and timezone? not system time, etc…
      user is in Norway…
      this.config.language
      doesn’t exist in the calendar module… so the set locale will fail…
      justjim1220J 3 Replies Last reply Reply Quote 1
      • justjim1220J Offline
        justjim1220 Module Developer @sdetweil
        @sdetweil after you add all that I posted, in your config file the use can add the timezone and language they want to use.
                language: "en",
                timezone: "Norway/Oslo"
        Jim Hallock - 1995
          you will also need to add this to your start section:
          / /Set locale.
          moment.updateLocale(config.language, this.getLocaleSpecification(config.timeZone));
          Jim Hallock - 1995
            @justjim1220 but I don’t want to duplicate the language config…
            strawberry 3.141S 1 Reply Last reply Reply Quote 1
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @sdetweil
              @sdetweil the global language is accessible like this config.language see example https://github.com/MichMich/MagicMirror/blob/master/modules/default/clock/clock.js#L49
                I just did added this to the calendar config and it changed it automatically:
                	position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                		language: "fr",
                		timezone: "France/Paris"
                Jim Hallock - 1995
                  sdetweil @strawberry 3.141
                  @strawberry-3-141 cool, thanks
                  • cowboysdudeC Offline
                    cowboysdude Module Developer @sdetweil
                    @sdetweil said in access to config language setting:
                    The kid knows his stuff! He’s a good guy! Matter of fact he gave me this to add to my module if it’s of any help :)
                    I use this under the start: function()
                      this.config.lang = this.config.lang || config.language; //automatically overrides and sets
                         language :)
                      this.config.units = this.config.units || config.units;
                      justbob
                      Sorry for necroing this post, but from all I’ve read so far, this came up with most relevant information and solutions.
                      My question is this - is there a reason why the language change via config was never incorporated in this module?
                        sdetweil @justbob
                        @justbob what module? this was a general question, not tied to any module
                          justbob @sdetweil
                          @sdetweil You mentioned default calendar module, and there were talks about default clock, so my questions referred to those…
                            sdetweil @justbob
                            @justbob what do you mean language change?
                            the modules use the default translations
                            set by changing language line 33 of the config.js.sample
                              justbob @sdetweil
                              @sdetweil OMG, you are right, thank you for pointing out the line!:man_bowing:
                              I was so focused on lines below line 39 (modules), that I completely skipped the ones above as I considered them to be mere comments… :man_facepalming_light_skin_tone:
                                sdetweil @justbob
                                @justbob everything ABOVE modules applies to all , its the overall environment
                                  justbob @sdetweil
                                  @sdetweil I am aware of that, but somehow I just ignored it as I was “on auto-pilot”. :grinning_face_with_sweat:
