    access to config language setting
    24 Posts 5 Posters 17.2k Views 5 Watching
      how do I get access to the overall MM language setting in config.js in my module? that value is not passed to each modules config
      • justjim1220J Offline
        justjim1220 Module Developer @sdetweil
        My best guess: "MagicMirror/translations/translations.js"
        Jim Hallock - 1995
          sdetweil @justjim1220
          @justjim1220 no… that is available translations… I mean the value in config.js
          	port: 8086,
          	ipWhitelist: [], // Set [] to allow all IP addresses
          	language: "en",  < ------------ this value
          	timeFormat: 12,
            timezone: "Europe/Oslo",
          	units: "imperial",
          the calendar code uses this value, BUT doesn’t get it config.language is not set (cause config comes from the module block)
          justjim1220J 3 Replies Last reply Reply Quote 0
            from what I can tell, modules containing the ability to change the language have their own translations folder.
            Other than that, have you tried language = this.language
            Jim Hallock - 1995
              NVM, I just tried it and it di not work.
              Jim Hallock - 1995
                Which calendar module are you referring to?
                Jim Hallock - 1995
                  @justjim1220 the default calendar module
                  the code in calendar.js does
                  	// Set locale.
                  		moment.updateLocale(this.config.language, this.getLocaleSpecification(this.config.timeFormat));
                  but it doesn’t have any value for this.config.language
                  as language is not in the MODULE config…
                  I also want to set timezone… as the user I am helping cannot get the clock and calendar to sync time offsets
                  if I copy those values to the calendar config block than they are accessible…
                  justjim1220J 2 Replies Last reply Reply Quote 0
                    All I can find is to put this in your js file:
                    getTranslations: function() {
                    	return {
                    		en: "translations/en.json",
                    		de: "translations/de.json"
                    Jim Hallock - 1995
                      for timezone:
                      Add this to your defaults in the modules js: timezone: "America/Chicago"
                      Then add this in the code:
                       getScripts: function() {
                      	return [
                                  "moment.js", "moment-timezone.js"
                      and this:
                      var now = moment();
                      	if (this.config.timezone) {
                      	now.tz(this.config.timezone);
                      Jim Hallock - 1995
                        @justjim1220 no… you are not understanding me…
                        how do i get the USERS config for language and timezone? not system time, etc…
                        user is in Norway…
                        doesn’t exist in the calendar module… so the set locale will fail…
                        justjim1220J 3 Replies Last reply Reply Quote 1
                          @sdetweil after you add all that I posted, in your config file the use can add the timezone and language they want to use.
                                  language: "en",
                                  timezone: "Norway/Oslo"
                          Jim Hallock - 1995
                            you will also need to add this to your start section:
                            / /Set locale.
                            moment.updateLocale(config.language, this.getLocaleSpecification(config.timeZone));
                            Jim Hallock - 1995
                              @justjim1220 but I don’t want to duplicate the language config…
                              strawberry 3.141S 1 Reply Last reply Reply Quote 1
                              • strawberry 3.141S Offline
                                strawberry 3.141 Project Sponsor Module Developer @sdetweil
                                @sdetweil the global language is accessible like this config.language see example https://github.com/MichMich/MagicMirror/blob/master/modules/default/clock/clock.js#L49
                                  I just did added this to the calendar config and it changed it automatically:
                                  	position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                                  		language: "fr",
                                  		timezone: "France/Paris"
                                  Jim Hallock - 1995
                                    sdetweil @strawberry 3.141
                                    @strawberry-3-141 cool, thanks
                                    • cowboysdudeC Offline
                                      cowboysdude Module Developer @sdetweil
                                      @sdetweil said in access to config language setting:
                                      The kid knows his stuff! He’s a good guy! Matter of fact he gave me this to add to my module if it’s of any help :)
                                      I use this under the start: function()
                                        this.config.lang = this.config.lang || config.language; //automatically overrides and sets
                                           language :)
                                        this.config.units = this.config.units || config.units;
                                        justbob
                                        Sorry for necroing this post, but from all I’ve read so far, this came up with most relevant information and solutions.
                                        My question is this - is there a reason why the language change via config was never incorporated in this module?
                                          sdetweil @justbob
                                          @justbob what module? this was a general question, not tied to any module
                                            justbob @sdetweil
                                            @sdetweil You mentioned default calendar module, and there were talks about default clock, so my questions referred to those…
