    MMM-octoprint
    17 Posts 6 Posters 6.8k Views 5 Watching
      btastic
      Hello!
      This is my second plugin. This module was sort of requested by @sdetweil and I thought it would be a great idea, since octoprint has a larger user base.
      Just like the moonraker module I developed a module to display data from the Octoprint API.
      It has some minor differences when setting up, but it should look the same once everything is setup properly.
      You can find the repository, installation guide and config options on my github: https://github.com/btastic/MMM-octoprint
      Feel free to discuss, ask questions or add suggestions for further development.
      Best regards
      Ben
      S BKeyportB 4 Replies Last reply Reply Quote 2
        sdetweil @btastic
        @btastic awesome…
          sdetweil @btastic
          @btastic
          you need a position: set in the example , else nothing displays
          for some reason my gcode files dont have thumbnails…
          so the img src url ends up being
          http://octopi/undefined
          you could pass th e endpoint and tail part of the url to the template
          and if the tail is undefined then do a messge instead of the img
          or construct the full url in the template
            sdetweil @btastic
            @btastic also, in your css file, you should prefix the classes with your modulename
            .MMM-octoprint .colum
            as all the stylesheets are loaded into the same namespace…
            it could collide with another module defining the same class name
              btastic @sdetweil
              @sdetweil Thank you for testing :) I fixed up the documentation to include a position.
              As for the missing thumbnails, did you install the plugin like I mentioned in the readme file? The plugins site also describes how to add thumbnails in your slicer software.
              You should only enable the showThumbnail flag once you have thumbnails working. Otherwise it can lead to unexpected behaviour, like you’re experiencing.
              The same for the layer progress. It can only be properly shown when the plugin and slicer are properly configured.
              I added some remarks about those flags in the readme file.
                btastic @sdetweil
                @sdetweil Thanks for the heads up, just added it.
                  btastic @sdetweil
                  @sdetweil I added a fallback thumbnail
                  • BKeyportB Offline
                    BKeyport Module Developer @btastic
                    @btastic Slick. I like it.
                      sdetweil @btastic
                      @btastic I did install the plugins
                      and went into thumbnails and scanned the gcode files…
                        jasondreher
                        Great module, but mine keeps flipping between fine and unavailable. When it flips to unavailable I look at the ip address and all looks fine…
                        any idea what the issue is?
                        • X Offline
                          xIExodusIx
                          Interessantes Modul,
                          leider wird bei mir außer “Lade…” nichts weiter angezeigt, auch nach 24 Std. nicht.
                          Hard- & Software Infos:
                          Magic Mirror: 2.30 on Raspberry Pi4, 4GB
                          OctoPrint: 1.10.3, Python: 3.11.2, OctoPi: 1.1.0 on Raspberry Pi4, 8GB
                          KristjanESPERANTOK 1 Reply Last reply Reply Quote -1
                          • KristjanESPERANTOK Online
                            KristjanESPERANTO Module Developer @xIExodusIx
                            @xIExodusIx Try this: Remove this line const fetch = require("fetch"); from node_helper.js in the module directory. If it doesn’t work, show us the log output.
                            S X 2 Replies Last reply Reply Quote 0
                              sdetweil @KristjanESPERANTO
                              @KristjanESPERANTO or just comment out
                              // const fetch = require(“fetch”);
                              • X Offline
                                xIExodusIx @KristjanESPERANTO
                                @KristjanESPERANTO & @sdetweil
                                Danke für die Hilfe, es scheint zu funktionieren, jetzt wird nicht mehr nur “Lade…” angezeigt, sondern die angegebenen Druck-Infos. Ich muss das aber noch mit einem Druck-Auftrag testen.
                                Thanks for the help, it seems to work, now it’s not just showing “loading…” anymore, now it shows the specified print information. But I still have to test this with a print job.
                                Thank you :-)
                                  sdetweil @xIExodusIx
                                  @xIExodusIx great!! thx for the feedback
                                  X 1 Reply Last reply Reply Quote 0
                                  • X Offline
                                    xIExodusIx @sdetweil
                                    @sdetweil & @KristjanESPERANTO
                                    Yes, everything is working now, even the thumbnail and the layer progress are displayed. Only downside: It is displayed very, very small on the left edge of the screen. Not as I specified “middle_center”. I’m trying to figure out why.
                                    But thanks for your great and fast Help :-)
                                      @xIExodusIx
                                      please don’t double post… all posts from users with reputation below 2 are reviewed (by me)… surprizingly I DO do other things than MM…!!
                                      from the doc, middle_center is all the way across the screen (magenta here)
                                      https://docs.magicmirror.builders/modules/configuration.html#position
