    MMM-octoprint
    17 Posts 6 Posters 7.2k Views 5 Watching
    • BKeyportB
      BKeyport Module Developer @btastic
      @btastic Slick. I like it.
        sdetweil @btastic
        @btastic I did install the plugins
        and went into thumbnails and scanned the gcode files…
          jasondreher
          Great module, but mine keeps flipping between fine and unavailable. When it flips to unavailable I look at the ip address and all looks fine…
          any idea what the issue is?
          • X
            xIExodusIx
            Interessantes Modul,
            leider wird bei mir außer “Lade…” nichts weiter angezeigt, auch nach 24 Std. nicht.
            Hard- & Software Infos:
            Magic Mirror: 2.30 on Raspberry Pi4, 4GB
            OctoPrint: 1.10.3, Python: 3.11.2, OctoPi: 1.1.0 on Raspberry Pi4, 8GB
            KristjanESPERANTOK 1 Reply Last reply Reply Quote -1
            • KristjanESPERANTOK
              KristjanESPERANTO Module Developer @xIExodusIx
              @xIExodusIx Try this: Remove this line const fetch = require("fetch"); from node_helper.js in the module directory. If it doesn’t work, show us the log output.
              S X 2 Replies Last reply Reply Quote 0
                sdetweil @KristjanESPERANTO
                @KristjanESPERANTO or just comment out
                // const fetch = require(“fetch”);
                • X
                  xIExodusIx @KristjanESPERANTO
                  @KristjanESPERANTO & @sdetweil
                  Danke für die Hilfe, es scheint zu funktionieren, jetzt wird nicht mehr nur “Lade…” angezeigt, sondern die angegebenen Druck-Infos. Ich muss das aber noch mit einem Druck-Auftrag testen.
                  Thanks for the help, it seems to work, now it’s not just showing “loading…” anymore, now it shows the specified print information. But I still have to test this with a print job.
                  Thank you :-)
                    sdetweil @xIExodusIx
                    @xIExodusIx great!! thx for the feedback
                    X 1 Reply Last reply Reply Quote 0
                    • X
                      xIExodusIx @sdetweil
                      @sdetweil & @KristjanESPERANTO
                      Yes, everything is working now, even the thumbnail and the layer progress are displayed. Only downside: It is displayed very, very small on the left edge of the screen. Not as I specified “middle_center”. I’m trying to figure out why.
                      But thanks for your great and fast Help :-)
                        @xIExodusIx
                        please don’t double post… all posts from users with reputation below 2 are reviewed (by me)… surprizingly I DO do other things than MM…!!
                        from the doc, middle_center is all the way across the screen (magenta here)
                        https://docs.magicmirror.builders/modules/configuration.html#position
