My SmartDisplay
12 Posts 8 Posters 6.9k Views 11 Watching
    Bense
    this forum has inspired me to build a SmartDisplay for our family based on the MagicMirror. I use the following modules:
    • Default Clock
    • MMM-Todoist
    • MMM-SolarEdge
    • MMM-SynologySurveillance
    • MMM-OpenWeatherMapForecast
    • MMM-Buienradar
    • MMM-DWD-WarnWeather
    The Screen is a Lenovo ThinkVision P27h-20
    J M 2 Replies Last reply Aug 9, 2023, 8:45 AM Reply Quote 5
      Jalibu Module Developer @Bense
      @Bense cool!
      Does the screen allow you to power the Raspi via USB or how do you manage that?
      B 1 Reply Last reply Aug 9, 2023, 11:34 AM Reply Quote 0
        Bense @Jalibu
        @Jalibu
        Yep, the screen supplies power to the Raspi. So I only need one cable to the screen.
        I just see your Rain Map module, I have installed it directly. Looks very good!
        C 1 Reply Last reply Aug 25, 2023, 3:07 AM Reply Quote 0
          Chazzer @Bense
          @Bense Looks really good. :-) Thanks for sharing.
          Also wanted to use the weather app.
          I’ve also been working on my own MM for a few days.
          Do you have any idea why the weather app MMM-OpenWeatherMapForecast does not load?
          Default weather with the Api works.
          The latest MM version also works.
          Do you know if it is related to the module width?
          C B 2 Replies Last reply Oct 13, 2023, 3:49 AM Reply Quote 0
            Chazzer @Chazzer
            @Chazzer said in My SmartDisplay:
            Kannst du mal dein Modul aus der Config für openweathermap posten.
            mein Modul lädt nicht
              Socrates
              Where are u hiding your RPI?
                Michelle.H2020 @Bense
                @Bense
                Can you tell me how you get 4 modules on the right side without overlap?
                  bebetter14 @Chazzer
                  @Chazzer Did you ever find out why OpenWeather wasnt working? I have a very similar issue.
                  S R 3 Replies Last reply Dec 10, 2023, 3:47 AM Reply Quote 0
                  • S Away
                    sdetweil @bebetter14
                    @bebetter14 usually it’s the wrong key for the configuration
                      RobertV 0 @bebetter14
                      @bebetter14 me too having problem
