    My SmartDisplay
    12 Posts 8 Posters 8.2k Views 11 Watching
      Socrates
      Where are u hiding your RPI?
        Michelle.H2020 @Bense
        @Bense
        Can you tell me how you get 4 modules on the right side without overlap?
          bebetter14 @Chazzer
          @Chazzer Did you ever find out why OpenWeather wasnt working? I have a very similar issue.
          S R 3 Replies Last reply Reply Quote 0
            sdetweil @bebetter14
            @bebetter14 usually it’s the wrong key for the configuration
              RobertV 0 @bebetter14
              @bebetter14 me too having problem
                @bebetter14 open the developers window, ctrl-shift-i on the browser keyboard, select the console tab and put weath in the filter field to see messages from the weather module.
                pretty sure the error is 401, unauthorized
                  bebetter14 @sdetweil
                  @sdetweil Thank you Sam for the assitance once again! You are correct there was an error. I tried to copy the sample config and replaced my API Key from Openweather and entered in my lat and long.
                    module: "MMM-OpenWeatherMapForecast",
                    header: "Weather",
                    classes: "default everyone",
                    disabled: false,
                      apikey: "SUPER SECRET!!!",
                      latitude: "51.506130",
                      longitude: "-0.090270",
                      iconset: "4c",
                      concise: false,
                      forecastLayout: "table"
                  The error Im getting is saying Verify styleshhet URLs, Affected Resource Localhost/:0
                  The weird thing I can use the API key for the default weather map no problem. Maybe I’m entering it in in the wrong format. Your help is much appreciated!
