    Possible to enable mouse cursor on screen?
    10 Posts 7 Posters 9.1k Views 7 Watching
      jason02
      Hi, I’m planning to create a module to display a image carousel. The will be a left button on the left side of the screen and a right button on the right side of the screen. When a user clicks the left or right button, a new image is displayed in the center of the screen.
      The final version will most likely be touch enabled, but until then I would like to test out the button click events using a mouse for the time being. However the mouse/cursor seems disabled whenever I load the magic mirror. Is there anyway I can enable the mouse while using the magic mirror?
      • cowboysdudeC Offline
        That’s funny because I came here looking for the same thing… I’m hoping there is!
          paviro
          It is disabled via CSS I am not sure on which element html or body so adding something like the following to the custom css file should work:
          body {
          cursor:default;
          – The Doctor
            broberg Project Sponsor
            As paviro said, the cursor is hidden as default, and to make stuff clickable you have to change the z-index of region-fullscreen to 0 (the fullscreen div is over everyrhing and blocks links and on click events.)
              Thanks @paviro …
              See I knew there’d be a way ;)
                cweinhofer
                Just an update on this. I don’t know if the methodology has changed or this is just an additional way. In my MM, it seems like the cursor is being hidden by
                html {
                  cursor: none;
                so it can be shown with
                html {
                  cursor: auto;
                (default would probably work as well)
                  sdetweil @cweinhofer
                  @cweinhofer yes, but the design is a ‘mirror’ on a wall with no mouse or keyboard… why show the cursor, ever…
                  karsten13K C 2 Replies Last reply Reply Quote 0
                  • karsten13K Online
                    karsten13 @sdetweil
                    @sdetweil said in Possible to enable mouse cursor on screen?:
                    when you running mm in a web-browser there are use cases for a cursor, e.g.
                    • zooming in a map (MMM-RAIN-MAP, MMM-Flights, …)
                    • clicking on newsfeed articles to get the article opened in a new window
                      cweinhofer @sdetweil
                      I know this was the original design, but I’m assuming that there are other people like me who realize the value of this software, but are using it somewhat outside it’s original design.
                      In my case, I have two MM’s running in my house:
                      One is on my HTPC, where I bring up the HTPC interface when I want to watch something and I have a MM with MMM-BackgroundSlideshow running as a sort of MM-PhotoFrame hybrid when I don’t.
                      The other is my kitchen touchscreen computer that has MM 90% of the time, but the other 10% gets minimized to Ubuntu touch so I can bring up recipes.
                        sdetweil @karsten13
                        @karsten13 not in a passive mirror
                        but for the extended use case with some active click device/mouse, then one can change it.
