    How to disable seconds in clock time?
    9 Posts 4 Posters 5.1k Views 3 Watching
      alang
      I’m two days new to magic mirror and have been able to make may changes by using custom.css, but there is something simple I haven’t been able to figure yet.
      How can I get the seconds to not display on the default clock time module?
        Mykle1 Project Sponsor Module Developer @alang
        @alang said in How to disable seconds in clock time?:
        From the clock module README file:
        displaySeconds: false,
          alang
          I knew the answer would be embarrassing. I appreciate the help without name calling. Thank you.
          Mykle1M 1 Reply Last reply Reply Quote 3
            Thank you.
            You’re welcome. Enjoy your mirror.
              Manino
              Somone know why it does’nt work for me? I have tried:
              module; "clock",
              position: "top_left"
              and
              module; "clock",
                sdetweil @Manino
                @Manino position line needs a trailing comma
                this works for me
                                        module: "clock",
                                        config:{
                                                displaySeconds:false,
                  Manino @sdetweil
                  @sdetweil Intresting, no need for trailing comma when it was only
                  module; "clock",
                  It did work with a trailing comma after position line, thanks!
                    sdetweil @Manino
                    @Manino said in How to disable seconds in clock time?:
                    correct, the trailing comma means more follows this line
                    it was not needed for the default because there was no more following…
                    as soon as you added another line, then it needs the trailing comma…
                    this is javascript syntax.
                    if you had run the syntax checker
                    npm run config:check
                    it would have told you the error
                    unexpected token
                    and it would have pointed to the line
                    this almost always means missing trailing comma on the line BEFORE the error
                      Manino @sdetweil
                      @sdetweil Oh, that’s good to know!!
