    How to disable seconds in clock time?
    9 Posts 4 Posters 4.8k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @alang
      @alang said in How to disable seconds in clock time?:
      Thank you.
      You’re welcome. Enjoy your mirror.
        Manino
        Somone know why it does’nt work for me? I have tried:
        module; "clock",
        position: "top_left"
                 displaySeconds: false
        and
        module; "clock",
                 displaySeconds: false,
          sdetweil @Manino
          @Manino position line needs a trailing comma
          this works for me
                                  module: "clock",
                                  config:{
                                          displaySeconds:false,
            Manino @sdetweil
            @sdetweil Intresting, no need for trailing comma when it was only
            module; "clock",
            It did work with a trailing comma after position line, thanks!
              sdetweil @Manino
              @Manino said in How to disable seconds in clock time?:
              correct, the trailing comma means more follows this line
              it was not needed for the default because there was no more following…
              as soon as you added another line, then it needs the trailing comma…
              this is javascript syntax.
              if you had run the syntax checker
              npm run config:check
              it would have told you the error
              unexpected token
              and it would have pointed to the line
              this almost always means missing trailing comma on the line BEFORE the error
                Manino @sdetweil
                @sdetweil Oh, that’s good to know!!
