    Upgrade errors?
    35 Posts 9 Posters 16.6k Views 10 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      @sdetweil – Apparently, script upgrade broke node on my system - can you help me figure how how to fix?
      Thanks!
      On run:
      node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
      upgrade output:
      doing test run = false
      update log will be in /home/bkey1970/MagicMirror/installers/upgrade.log
      Minimum Node version: v20.8.0
      Installed Node version: v16.20.2
      Node should be upgraded.
      Installing Node.js ...
      gpg: WARNING: unsafe ownership on homedir '/home/bkey1970/.gnupg'
      Reading package lists... Done
      Building dependency tree
      The following packages will be upgraded:
        nodejs
      1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Need to get 27.0 MB of archives.
      After this operation, 63.7 MB of additional disk space will be used.
      Get:1 https://deb.nodesource.com/node_20.x buster/main armhf nodejs armhf 20.5.1-deb-1nodesource1 [27.0 MB]
      Fetched 27.0 MB in 7s (4,153 kB/s)
      apt-listchanges: Reading changelogs...
      (Reading database ... 103684 files and directories currently installed.)
      Preparing to unpack .../nodejs_20.5.1-deb-1nodesource1_armhf.deb ...
      Unpacking nodejs (20.5.1-deb-1nodesource1) over (16.20.2-deb-1nodesource1) ...
      Setting up nodejs (20.5.1-deb-1nodesource1) ...
      Processing triggers for man-db (2.8.5-2) ...
      node version is node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
      Node.js installation Done! version=
      Minimum npm version: V10.1.0
      Installed npm version: V
      npm should be upgraded.
      Installing npm ...
      E: Unable to correct problems, you have held broken packages.
      npm installation Done! version=V
      apply: line 318: [: -ge: unary operator expected
      saving custom.css
      upgrading from version 2.24.0 to 2.25.0
      fetching latest revisions
      apply: line 558: [: -ge: unary operator expected
      no modules found needing npm refresh
      restoring custom.css
      • kaiK Offline
        kai @BKeyport
        @BKeyport said in Upgrade errors?:
        @sdetweil turns out there was an update to MMM-Wallpaper that missed due to all the bugs in upgrading. 😉
        …just in case this might be interesting for anyone: I had the same problems on my Raspberry Pi 4 Model B (Rev 1.2) with buster (armv71).
        • node 20 gave me the `GLIBCXX_3.4.26’ not found (required by node) error
        • I had the “failed to load swrast driver”
        I checked my modules, and the solution for my MM was (thanks to @sdetweil and @BKeyport here):
        • installing node 18 (I did it manually like mentioned here)
        • removing “DWD Warn Weather” (which caused the swrast error) from config.js
        Now MagicMirror v2.25.0 is up and running! :beaming_face_with_smiling_eyes:
        Thank you for all your effort and your tireless support!
        May the code be with you.
        -kai
        • BKeyportB Offline
          Nevermind. It appears required dependencies aren’t being updated to previous OSes. Time to switch away from Raspbian.
            sdetweil @BKeyport
            @BKeyport thanks, I’ll have to check this in the morning, and see how to do the c++ runtime upgrade too
            • BKeyportB Offline
              @sdetweil It appears node and/or NPM is the problem - some of their newer dependencies aren’t compatible with older Raspbian installs, which will make it impossible for me to run what I want on the mirror.
              Losing OMXPlayer murders my setup - so I’m working on something else.
                sdetweil @BKeyport
                @BKeyport yeh, looks like buster/legacy is too down level for node 20. let’s try 18
                sudo npm  i n
                sudo n i 18
                node -v should show node 18
                then
                rm -rf node_modules
                npm  run install-mm
                please advise
                  croc_dad72 @sdetweil
                  @sdetweil said in Upgrade errors?:
                  rm -rf node_modules
                  npm run install-mm
                  The update seem to have crashed my Mirror, I applied these fixes but nothing will run here is my start up logs, what am I missing? Any help would be much appreciated! Thanks.
                  macserver@EDITHs-MacBook-Pro MagicMirror % npm run server
                  > magicmirror@2.25.0 server
                  > node ./serveronly
                  [02.10.2023 07:51.49.432] [LOG]   Starting MagicMirror: v2.25.0
                  [02.10.2023 07:51.49.436] [LOG]   Loading config ...
                  [02.10.2023 07:51.49.438] [DEBUG] config template file not exists, no envsubst
                  [02.10.2023 07:51.49.442] [LOG]   Loading module helpers ...
                  [02.10.2023 07:51.49.443] [LOG]   No helper found for module: alert.
                  [02.10.2023 07:51.49.449] [LOG]   Initializing new module helper ...
                  [02.10.2023 07:51.49.450] [LOG]   Module helper loaded: updatenotification
                  [02.10.2023 07:51.49.451] [LOG]   No helper found for module: clock.
                  [02.10.2023 07:51.49.676] [LOG]   Initializing new module helper ...
                  [02.10.2023 07:51.49.676] [LOG]   Module helper loaded: MMM-quote-of-the-day
                  [02.10.2023 07:51.49.765] [ERROR] Whoops! There was an uncaught exception...
                  [02.10.2023 07:51.49.770] [ERROR] Error: Cannot find module 'fetch'
                  Require stack:
                  - /Users/macserver/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js
                  - /Users/macserver/MagicMirror/modules/MMM-MyCalendar/node_helper.js
                  - /Users/macserver/MagicMirror/js/app.js
                  - /Users/macserver/MagicMirror/serveronly/index.js
                      at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
                      at Module._resolveFilename (/Users/macserver/MagicMirror/node_modules/module-alias/index.js:49:29)
                      at Module._load (node:internal/modules/cjs/loader:920:27)
                      at Module.require (node:internal/modules/cjs/loader:1141:19)
                      at require (node:internal/modules/cjs/helpers:110:18)
                      at Object.<anonymous> (/Users/macserver/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js:11:15)
                      at Module._compile (node:internal/modules/cjs/loader:1254:14)
                      at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                      at Module.load (node:internal/modules/cjs/loader:1117:32)
                      at Module._load (node:internal/modules/cjs/loader:958:12)
                      at Object.<anonymous> (/Users/macserver/MagicMirror/modules/MMM-MyCalendar/node_helper.js:8:25)
                      at Module.load (node:internal/modules/cjs/loader:1117:32) {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: [
                      '/Users/macserver/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js',
                      '/Users/macserver/MagicMirror/modules/MMM-MyCalendar/node_helper.js',
                      '/Users/macserver/MagicMirror/js/app.js',
                      '/Users/macserver/MagicMirror/serveronly/index.js'
                  [02.10.2023 07:51.49.771] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [02.10.2023 07:51.49.771] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  S karsten13K 2 Replies Last reply Reply Quote 0
                    sdetweil @croc_dad72
                    @croc_dad72 said in Upgrade errors?:
                    Error: Cannot find module ‘fetch’
                    see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
                      sdetweil @BKeyport
                      @BKeyport also try the new temp node20 install script, listed at the top of my scripts page
                      • karsten13K Offline
                        karsten13 @croc_dad72
                        @croc_dad72
                        looks like you are on deprecated node version, run node -v which must be >= v18
                        • mumblebajM Offline
                          mumblebaj Module Developer @karsten13
                          @karsten13 Upgrade just broke my dev machine. :-) Guess I am not upgrading my mirror. Had to wipe my whole WSL Ubuntu install. Have to start from scratch with my dev machine. Not a great upgrade. My prod mirror is still a PI 3B running buster. :confounded_face:
                            sdetweil @mumblebaj
                            @mumblebaj buster is broken… do NOT upgrade buster machines…
                            lsb_release -a
                            to see what you have
                            mumblebajM 1 Reply Last reply Reply Quote 1
                              @sdetweil Thanks Sam. I already broke my dev machine. How do I clean install 2.24.0?
                                sdetweil @mumblebaj
                                @mumblebaj try the upgrade script again, with force instead of apply
                                it will remove and and add the right version the right way, including on buster
                                please advise your results…
                                • BKeyportB Offline
                                  for my buster install:
                                  Ran “apply” re-run did bring back PM2 and other tools - No MagicMirror though. Says it’s running, but doesn’t appear.
                                  Running “force” re-run same result.
                                  0|MagicMirror  | > magicmirror@2.25.0 start
                                  0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                  0|MagicMirror  | [02.10.2023 15:49.10.094] [LOG]   Starting MagicMirror: v2.25.0
                                  0|MagicMirror  | [02.10.2023 15:49.10.101] [LOG]   Loading config ...
                                  0|MagicMirror  | [02.10.2023 15:49.10.105] [DEBUG] config template file not exists, no envsubst
                                  0|MagicMirror  | [02.10.2023 15:49.10.112] [LOG]   Loading module helpers ...
                                  0|MagicMirror  | [02.10.2023 15:49.10.114] [LOG]   No helper found for module: MMM-MagicMover.
                                  0|MagicMirror  | [02.10.2023 15:49.10.116] [LOG]   No helper found for module: alert.
                                  0|MagicMirror  | [02.10.2023 15:49.10.297] [LOG]   Initializing new module helper ...
                                  0|MagicMirror  | [02.10.2023 15:49.10.298] [LOG]   Module helper loaded: calendar
                                  0|MagicMirror  | [02.10.2023 15:49.10.319] [LOG]   Initializing new module helper ...
                                  0|MagicMirror  | [02.10.2023 15:49.10.320] [LOG]   Module helper loaded: MMM-CommandToNotification
                                  0|MagicMirror  | [02.10.2023 15:49.10.322] [LOG]   No helper found for module: clock.
                                  0|MagicMirror  | [02.10.2023 15:49.10.323] [LOG]   No helper found for module: MMM-Worldclock.
                                  0|MagicMirror  | [02.10.2023 15:49.10.326] [LOG]   Initializing new module helper ...
                                  0|MagicMirror  | [02.10.2023 15:49.10.327] [LOG]   Module helper loaded: MMM-ValuesByNotification
                                  0|MagicMirror  | [02.10.2023 15:49.10.328] [LOG]   No helper found for module: MMM-Multimonth.
                                  0|MagicMirror  | [02.10.2023 15:49.10.331] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
                                  0|MagicMirror  | [02.10.2023 15:49.10.332] [LOG]   No helper found for module: MMM-CalendarExt3.
                                  0|MagicMirror  | [02.10.2023 15:49.10.463] [LOG]   Initializing new module helper ...
                                  0|MagicMirror  | [02.10.2023 15:49.10.464] [LOG]   Module helper loaded: newsfeed
                                  0|MagicMirror  | [02.10.2023 15:49.10.519] [LOG]   Initializing new module helper ...
                                  0|MagicMirror  | [02.10.2023 15:49.10.519] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
                                  0|MagicMirror  | [02.10.2023 15:49.10.525] [LOG]   Initializing new module helper ...
                                  0|MagicMirror  | [02.10.2023 15:49.10.525] [LOG]   Module helper loaded: updatenotification
                                  0|MagicMirror  | [02.10.2023 15:49.10.856] [ERROR] (node:7847) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
                                  0|MagicMirror  | Require stack:
                                  0|MagicMirror  | - /home/bkey1970/MagicMirror/modules/MMM-Wallpaper/node_helper.js
                                  0|MagicMirror  | - /home/bkey1970/MagicMirror/js/app.js
                                  0|MagicMirror  | - /home/bkey1970/MagicMirror/js/electron.js
                                  0|MagicMirror  | - /home/bkey1970/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                  0|MagicMirror  | -
                                  0|MagicMirror  |     at node:internal/modules/cjs/loader:1084:15
                                  0|MagicMirror  |     at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                                  0|MagicMirror  |     at Module._resolveFilename (/home/bkey1970/MagicMirror/node_modules/module-alias/index.js:49:29)
                                  0|MagicMirror  |     at node:internal/modules/cjs/loader:929:27
                                  0|MagicMirror  |     at Function._load (node:electron/js2c/asar_bundle:2:13327)
                                  0|MagicMirror  |     at Module.require (node:internal/modules/cjs/loader:1150:19)
                                  0|MagicMirror  |     at require (node:internal/modules/cjs/helpers:110:18)
                                  0|MagicMirror  |     at Object.<anonymous> (/home/bkey1970/MagicMirror/modules/MMM-Wallpaper/node_helper.js:11:15)
                                  0|MagicMirror  |     at Module._compile (node:internal/modules/cjs/loader:1271:14)
                                  0|MagicMirror  |     at Object..js (node:internal/modules/cjs/loader:1326:10)
                                  0|MagicMirror  |     at Module.load (node:internal/modules/cjs/loader:1126:32)
                                  0|MagicMirror  |     at node:internal/modules/cjs/loader:967:12
                                  0|MagicMirror  |     at loadModule (/home/bkey1970/MagicMirror/js/app.js:180:19)
                                  0|MagicMirror  | (Use `electron --trace-warnings ...` to show where the warning was created)
                                  0|MagicMirror  | [02.10.2023 15:49.10.857] [ERROR] (node:7847) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                                  0|MagicMirror  | [7847:1002/154911.190579:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                                  0|MagicMirror  | MESA-LOADER: failed to retrieve device information
                                  0|MagicMirror  | MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                                  0|MagicMirror  | failed to load driver: kms_swrast
                                  0|MagicMirror  | MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                                  0|MagicMirror  | failed to load swrast driver
                                    @sdetweil now im getting this when I start it up? Any thoughts?
                                    macserver@EDITHs-MacBook-Pro magicmirror % npm run server
                                    evalmachine.<anonymous>:42
                                    } = primordials;
                                    ReferenceError: primordials is not defined
                                        at evalmachine.<anonymous>:42:5
                                        at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/fs.js:11:8)
                                        at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:3:27)
                                    Node.js v18.15.0
                                    Tried running the node upgrade but that seem to fail too?
                                      @croc_dad72 did u run the node20_install.sh script? by itself?
                                      I have to go test it again
                                      S BerkSmash1984B 2 Replies Last reply Reply Quote 0
                                        @croc_dad72 @BKeyport and any others… I screwed up for the non-buster systems…
                                        please try my scripts again… they should FIX the problems encountered…
                                        I remove the current node and then install the correct… 18 for buster, 20 for bullseye
                                        • BKeyportB Offline
                                          @sdetweil It does seem to work again on latest.
                                            SuperSchenk
                                            I also had this problem, using Buster on a Raspberry pi 3b.
                                            It started with my npm being to old, unable to upgrade because my node was to old.
                                            Installing the newest node gave me the `GLIBCXX_3.4.26’ not found (required by node) error.
                                            The solution for me was installing the LTS version of node using nvm.
                                            nvm install 'lts/*' --reinstall-packages-from=current
                                            nvm alias default 18
                                            this uses node version 18.
                                            after that I could upgrade npm
                                            nvm install-latest-npm
                                            and with all this in place the upgrade of magic mirror worked.
                                            Hope this helps
                                            • BerkSmash1984B Offline
                                              BerkSmash1984 @sdetweil
                                              @sdetweil I tried to run the upgrade script on my RPI 4B running Bullseye and it hosed my MM. During the install, I see this:
                                              It appears to have removed/partially remove npm altogether:
                                              Any thoughts?
