    Upgrade errors?
    35 Posts 9 Posters 16.6k Views 10 Watching
    • karsten13K Offline
      karsten13 @croc_dad72
      @croc_dad72
      looks like you are on deprecated node version, run node -v which must be >= v18
      • mumblebajM Offline
        mumblebaj Module Developer @karsten13
        @karsten13 Upgrade just broke my dev machine. :-) Guess I am not upgrading my mirror. Had to wipe my whole WSL Ubuntu install. Have to start from scratch with my dev machine. Not a great upgrade. My prod mirror is still a PI 3B running buster. :confounded_face:
          sdetweil @mumblebaj
          @mumblebaj buster is broken… do NOT upgrade buster machines…
          lsb_release -a
          to see what you have
          mumblebajM 1 Reply Last reply Reply Quote 1
            @sdetweil Thanks Sam. I already broke my dev machine. How do I clean install 2.24.0?
              sdetweil @mumblebaj
              @mumblebaj try the upgrade script again, with force instead of apply
              it will remove and and add the right version the right way, including on buster
              please advise your results…
              • BKeyportB Offline
                for my buster install:
                Ran “apply” re-run did bring back PM2 and other tools - No MagicMirror though. Says it’s running, but doesn’t appear.
                Running “force” re-run same result.
                0|MagicMirror  | > magicmirror@2.25.0 start
                0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                0|MagicMirror  | [02.10.2023 15:49.10.094] [LOG]   Starting MagicMirror: v2.25.0
                0|MagicMirror  | [02.10.2023 15:49.10.101] [LOG]   Loading config ...
                0|MagicMirror  | [02.10.2023 15:49.10.105] [DEBUG] config template file not exists, no envsubst
                0|MagicMirror  | [02.10.2023 15:49.10.112] [LOG]   Loading module helpers ...
                0|MagicMirror  | [02.10.2023 15:49.10.114] [LOG]   No helper found for module: MMM-MagicMover.
                0|MagicMirror  | [02.10.2023 15:49.10.116] [LOG]   No helper found for module: alert.
                0|MagicMirror  | [02.10.2023 15:49.10.297] [LOG]   Initializing new module helper ...
                0|MagicMirror  | [02.10.2023 15:49.10.298] [LOG]   Module helper loaded: calendar
                0|MagicMirror  | [02.10.2023 15:49.10.319] [LOG]   Initializing new module helper ...
                0|MagicMirror  | [02.10.2023 15:49.10.320] [LOG]   Module helper loaded: MMM-CommandToNotification
                0|MagicMirror  | [02.10.2023 15:49.10.322] [LOG]   No helper found for module: clock.
                0|MagicMirror  | [02.10.2023 15:49.10.323] [LOG]   No helper found for module: MMM-Worldclock.
                0|MagicMirror  | [02.10.2023 15:49.10.326] [LOG]   Initializing new module helper ...
                0|MagicMirror  | [02.10.2023 15:49.10.327] [LOG]   Module helper loaded: MMM-ValuesByNotification
                0|MagicMirror  | [02.10.2023 15:49.10.328] [LOG]   No helper found for module: MMM-Multimonth.
                0|MagicMirror  | [02.10.2023 15:49.10.331] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
                0|MagicMirror  | [02.10.2023 15:49.10.332] [LOG]   No helper found for module: MMM-CalendarExt3.
                0|MagicMirror  | [02.10.2023 15:49.10.463] [LOG]   Initializing new module helper ...
                0|MagicMirror  | [02.10.2023 15:49.10.464] [LOG]   Module helper loaded: newsfeed
                0|MagicMirror  | [02.10.2023 15:49.10.519] [LOG]   Initializing new module helper ...
                0|MagicMirror  | [02.10.2023 15:49.10.519] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
                0|MagicMirror  | [02.10.2023 15:49.10.525] [LOG]   Initializing new module helper ...
                0|MagicMirror  | [02.10.2023 15:49.10.525] [LOG]   Module helper loaded: updatenotification
                0|MagicMirror  | [02.10.2023 15:49.10.856] [ERROR] (node:7847) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
                0|MagicMirror  | Require stack:
                0|MagicMirror  | - /home/bkey1970/MagicMirror/modules/MMM-Wallpaper/node_helper.js
                0|MagicMirror  | - /home/bkey1970/MagicMirror/js/app.js
                0|MagicMirror  | - /home/bkey1970/MagicMirror/js/electron.js
                0|MagicMirror  | - /home/bkey1970/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                0|MagicMirror  | -
                0|MagicMirror  |     at node:internal/modules/cjs/loader:1084:15
                0|MagicMirror  |     at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                0|MagicMirror  |     at Module._resolveFilename (/home/bkey1970/MagicMirror/node_modules/module-alias/index.js:49:29)
                0|MagicMirror  |     at node:internal/modules/cjs/loader:929:27
                0|MagicMirror  |     at Function._load (node:electron/js2c/asar_bundle:2:13327)
                0|MagicMirror  |     at Module.require (node:internal/modules/cjs/loader:1150:19)
                0|MagicMirror  |     at require (node:internal/modules/cjs/helpers:110:18)
                0|MagicMirror  |     at Object.<anonymous> (/home/bkey1970/MagicMirror/modules/MMM-Wallpaper/node_helper.js:11:15)
                0|MagicMirror  |     at Module._compile (node:internal/modules/cjs/loader:1271:14)
                0|MagicMirror  |     at Object..js (node:internal/modules/cjs/loader:1326:10)
                0|MagicMirror  |     at Module.load (node:internal/modules/cjs/loader:1126:32)
                0|MagicMirror  |     at node:internal/modules/cjs/loader:967:12
                0|MagicMirror  |     at loadModule (/home/bkey1970/MagicMirror/js/app.js:180:19)
                0|MagicMirror  | (Use `electron --trace-warnings ...` to show where the warning was created)
                0|MagicMirror  | [02.10.2023 15:49.10.857] [ERROR] (node:7847) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                0|MagicMirror  | [7847:1002/154911.190579:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                0|MagicMirror  | MESA-LOADER: failed to retrieve device information
                0|MagicMirror  | MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                0|MagicMirror  | failed to load driver: kms_swrast
                0|MagicMirror  | MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                0|MagicMirror  | failed to load swrast driver
                  croc_dad72 @sdetweil
                  @sdetweil now im getting this when I start it up? Any thoughts?
                  macserver@EDITHs-MacBook-Pro magicmirror % npm run server
                  evalmachine.<anonymous>:42
                  } = primordials;
                  ReferenceError: primordials is not defined
                      at evalmachine.<anonymous>:42:5
                      at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/fs.js:11:8)
                      at Module._compile (node:internal/modules/cjs/loader:1254:14)
                      at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                      at Module.load (node:internal/modules/cjs/loader:1117:32)
                      at Module._load (node:internal/modules/cjs/loader:958:12)
                      at Module.require (node:internal/modules/cjs/loader:1141:19)
                      at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:3:27)
                  Node.js v18.15.0
                  Tried running the node upgrade but that seem to fail too?
                    sdetweil @croc_dad72
                    @croc_dad72 did u run the node20_install.sh script? by itself?
                    I have to go test it again
                    S BerkSmash1984B 2 Replies Last reply Reply Quote 0
                      @croc_dad72 @BKeyport and any others… I screwed up for the non-buster systems…
                      please try my scripts again… they should FIX the problems encountered…
                      I remove the current node and then install the correct… 18 for buster, 20 for bullseye
                      • BKeyportB Offline
                        @sdetweil It does seem to work again on latest.
                          SuperSchenk
                          I also had this problem, using Buster on a Raspberry pi 3b.
                          It started with my npm being to old, unable to upgrade because my node was to old.
                          Installing the newest node gave me the `GLIBCXX_3.4.26’ not found (required by node) error.
                          The solution for me was installing the LTS version of node using nvm.
                          nvm install 'lts/*' --reinstall-packages-from=current
                          nvm alias default 18
                          this uses node version 18.
                          after that I could upgrade npm
                          nvm install-latest-npm
                          and with all this in place the upgrade of magic mirror worked.
                          Hope this helps
                          • BerkSmash1984B Offline
                            BerkSmash1984 @sdetweil
                            @sdetweil I tried to run the upgrade script on my RPI 4B running Bullseye and it hosed my MM. During the install, I see this:
                            It appears to have removed/partially remove npm altogether:
                            Any thoughts?
                              sdetweil @BKeyport
                              @BKeyport said in Upgrade errors?:
                              Cannot find module ‘fetch’
                              we removed this in 2.25
                              see
                              or, you can comment out the require in the module node_helper.js
                              as fetch is built in in 2.18 and up
                                sdetweil @BerkSmash1984
                                @BerkSmash1984 I see 64bit… let me look
                                seems the process is different there… darn
                                  @sdetweil Can you help me fix my WSL? I seem to be having and issue with electron and a missing lib. I have emailed you the install.log as well.
                                    sdetweil @mumblebaj
                                    @mumblebaj maybe
                                    https://github.com/snobu/destreamer/issues/216
                                      @sdetweil Thanks Sam. A bunch of missing libs but all working again.
                                      Now to add my modules I had running on the dev machine. The joy. :-)
                                        sdetweil @mumblebaj
                                        @mumblebaj always backup
                                        I have one that makes a small image
                                        https://github.com/sdetweil/MagicMirror-backup-restore
                                          @sdetweil I use your backup scripts on my main mirror. My dev machine I did not backup. Will teach me for next time. :crying_face:
                                          • BKeyportB Offline
                                            @sdetweil turns out there was an update to MMM-Wallpaper that missed due to all the bugs in upgrading. 😉
                                            S kaiK 2 Replies Last reply Reply Quote 0
