    Upgrade errors?
    35 Posts 9 Posters 17.9k Views 10 Watching
      sdetweil @BKeyport
      @BKeyport yeh, looks like buster/legacy is too down level for node 20. let’s try 18
      sudo npm  i n
      sudo n i 18
      node -v should show node 18
      then
      rm -rf node_modules
      npm  run install-mm
      please advise
      C 1 Reply Last reply
        croc_dad72 @sdetweil
        @sdetweil said in Upgrade errors?:
        rm -rf node_modules
        npm run install-mm
        The update seem to have crashed my Mirror, I applied these fixes but nothing will run here is my start up logs, what am I missing? Any help would be much appreciated! Thanks.
        macserver@EDITHs-MacBook-Pro MagicMirror % npm run server
        > magicmirror@2.25.0 server
        > node ./serveronly
        [02.10.2023 07:51.49.432] [LOG]   Starting MagicMirror: v2.25.0
        [02.10.2023 07:51.49.436] [LOG]   Loading config ...
        [02.10.2023 07:51.49.438] [DEBUG] config template file not exists, no envsubst
        [02.10.2023 07:51.49.442] [LOG]   Loading module helpers ...
        [02.10.2023 07:51.49.443] [LOG]   No helper found for module: alert.
        [02.10.2023 07:51.49.449] [LOG]   Initializing new module helper ...
        [02.10.2023 07:51.49.450] [LOG]   Module helper loaded: updatenotification
        [02.10.2023 07:51.49.451] [LOG]   No helper found for module: clock.
        [02.10.2023 07:51.49.676] [LOG]   Initializing new module helper ...
        [02.10.2023 07:51.49.676] [LOG]   Module helper loaded: MMM-quote-of-the-day
        [02.10.2023 07:51.49.765] [ERROR] Whoops! There was an uncaught exception...
        [02.10.2023 07:51.49.770] [ERROR] Error: Cannot find module 'fetch'
        Require stack:
        - /Users/macserver/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js
        - /Users/macserver/MagicMirror/modules/MMM-MyCalendar/node_helper.js
        - /Users/macserver/MagicMirror/js/app.js
        - /Users/macserver/MagicMirror/serveronly/index.js
            at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
            at Module._resolveFilename (/Users/macserver/MagicMirror/node_modules/module-alias/index.js:49:29)
            at Module._load (node:internal/modules/cjs/loader:920:27)
            at Module.require (node:internal/modules/cjs/loader:1141:19)
            at require (node:internal/modules/cjs/helpers:110:18)
            at Object.<anonymous> (/Users/macserver/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js:11:15)
            at Module._compile (node:internal/modules/cjs/loader:1254:14)
            at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
            at Module.load (node:internal/modules/cjs/loader:1117:32)
            at Module._load (node:internal/modules/cjs/loader:958:12)
            at Object.<anonymous> (/Users/macserver/MagicMirror/modules/MMM-MyCalendar/node_helper.js:8:25)
            at Module.load (node:internal/modules/cjs/loader:1117:32) {
          code: 'MODULE_NOT_FOUND',
          requireStack: [
            '/Users/macserver/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js',
            '/Users/macserver/MagicMirror/modules/MMM-MyCalendar/node_helper.js',
            '/Users/macserver/MagicMirror/js/app.js',
            '/Users/macserver/MagicMirror/serveronly/index.js'
        [02.10.2023 07:51.49.771] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [02.10.2023 07:51.49.771] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        S karsten13K 2 Replies Last reply
          sdetweil @croc_dad72
          @croc_dad72 said in Upgrade errors?:
          Error: Cannot find module ‘fetch’
          see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
            sdetweil @BKeyport
            @BKeyport also try the new temp node20 install script, listed at the top of my scripts page
            • karsten13K
              karsten13 @croc_dad72
              @croc_dad72
              looks like you are on deprecated node version, run node -v which must be >= v18
              mumblebajM 1 Reply Last reply
              • mumblebajM
                mumblebaj Module Developer @karsten13
                @karsten13 Upgrade just broke my dev machine. :-) Guess I am not upgrading my mirror. Had to wipe my whole WSL Ubuntu install. Have to start from scratch with my dev machine. Not a great upgrade. My prod mirror is still a PI 3B running buster. :confounded_face:
                  sdetweil @mumblebaj
                  @mumblebaj buster is broken… do NOT upgrade buster machines…
                  lsb_release -a
                  to see what you have
                  • mumblebajM
                    @sdetweil Thanks Sam. I already broke my dev machine. How do I clean install 2.24.0?
                      sdetweil @mumblebaj
                      @mumblebaj try the upgrade script again, with force instead of apply
                      it will remove and and add the right version the right way, including on buster
                      please advise your results…
                      BKeyportB 1 Reply Last reply
                      • BKeyportB
                        for my buster install:
                        Ran “apply” re-run did bring back PM2 and other tools - No MagicMirror though. Says it’s running, but doesn’t appear.
                        Running “force” re-run same result.
                        0|MagicMirror  | > magicmirror@2.25.0 start
                        0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                        0|MagicMirror  | [02.10.2023 15:49.10.094] [LOG]   Starting MagicMirror: v2.25.0
                        0|MagicMirror  | [02.10.2023 15:49.10.101] [LOG]   Loading config ...
                        0|MagicMirror  | [02.10.2023 15:49.10.105] [DEBUG] config template file not exists, no envsubst
                        0|MagicMirror  | [02.10.2023 15:49.10.112] [LOG]   Loading module helpers ...
                        0|MagicMirror  | [02.10.2023 15:49.10.114] [LOG]   No helper found for module: MMM-MagicMover.
                        0|MagicMirror  | [02.10.2023 15:49.10.116] [LOG]   No helper found for module: alert.
                        0|MagicMirror  | [02.10.2023 15:49.10.297] [LOG]   Initializing new module helper ...
                        0|MagicMirror  | [02.10.2023 15:49.10.298] [LOG]   Module helper loaded: calendar
                        0|MagicMirror  | [02.10.2023 15:49.10.319] [LOG]   Initializing new module helper ...
                        0|MagicMirror  | [02.10.2023 15:49.10.320] [LOG]   Module helper loaded: MMM-CommandToNotification
                        0|MagicMirror  | [02.10.2023 15:49.10.322] [LOG]   No helper found for module: clock.
                        0|MagicMirror  | [02.10.2023 15:49.10.323] [LOG]   No helper found for module: MMM-Worldclock.
                        0|MagicMirror  | [02.10.2023 15:49.10.326] [LOG]   Initializing new module helper ...
                        0|MagicMirror  | [02.10.2023 15:49.10.327] [LOG]   Module helper loaded: MMM-ValuesByNotification
                        0|MagicMirror  | [02.10.2023 15:49.10.328] [LOG]   No helper found for module: MMM-Multimonth.
                        0|MagicMirror  | [02.10.2023 15:49.10.331] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
                        0|MagicMirror  | [02.10.2023 15:49.10.332] [LOG]   No helper found for module: MMM-CalendarExt3.
                        0|MagicMirror  | [02.10.2023 15:49.10.463] [LOG]   Initializing new module helper ...
                        0|MagicMirror  | [02.10.2023 15:49.10.464] [LOG]   Module helper loaded: newsfeed
                        0|MagicMirror  | [02.10.2023 15:49.10.519] [LOG]   Initializing new module helper ...
                        0|MagicMirror  | [02.10.2023 15:49.10.519] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
                        0|MagicMirror  | [02.10.2023 15:49.10.525] [LOG]   Initializing new module helper ...
                        0|MagicMirror  | [02.10.2023 15:49.10.525] [LOG]   Module helper loaded: updatenotification
                        0|MagicMirror  | [02.10.2023 15:49.10.856] [ERROR] (node:7847) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
                        0|MagicMirror  | Require stack:
                        0|MagicMirror  | - /home/bkey1970/MagicMirror/modules/MMM-Wallpaper/node_helper.js
                        0|MagicMirror  | - /home/bkey1970/MagicMirror/js/app.js
                        0|MagicMirror  | - /home/bkey1970/MagicMirror/js/electron.js
                        0|MagicMirror  | - /home/bkey1970/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                        0|MagicMirror  | -
                        0|MagicMirror  |     at node:internal/modules/cjs/loader:1084:15
                        0|MagicMirror  |     at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                        0|MagicMirror  |     at Module._resolveFilename (/home/bkey1970/MagicMirror/node_modules/module-alias/index.js:49:29)
                        0|MagicMirror  |     at node:internal/modules/cjs/loader:929:27
                        0|MagicMirror  |     at Function._load (node:electron/js2c/asar_bundle:2:13327)
                        0|MagicMirror  |     at Module.require (node:internal/modules/cjs/loader:1150:19)
                        0|MagicMirror  |     at require (node:internal/modules/cjs/helpers:110:18)
                        0|MagicMirror  |     at Object.<anonymous> (/home/bkey1970/MagicMirror/modules/MMM-Wallpaper/node_helper.js:11:15)
                        0|MagicMirror  |     at Module._compile (node:internal/modules/cjs/loader:1271:14)
                        0|MagicMirror  |     at Object..js (node:internal/modules/cjs/loader:1326:10)
                        0|MagicMirror  |     at Module.load (node:internal/modules/cjs/loader:1126:32)
                        0|MagicMirror  |     at node:internal/modules/cjs/loader:967:12
                        0|MagicMirror  |     at loadModule (/home/bkey1970/MagicMirror/js/app.js:180:19)
                        0|MagicMirror  | (Use `electron --trace-warnings ...` to show where the warning was created)
                        0|MagicMirror  | [02.10.2023 15:49.10.857] [ERROR] (node:7847) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                        0|MagicMirror  | [7847:1002/154911.190579:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                        0|MagicMirror  | MESA-LOADER: failed to retrieve device information
                        0|MagicMirror  | MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                        0|MagicMirror  | failed to load driver: kms_swrast
                        0|MagicMirror  | MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                        0|MagicMirror  | failed to load swrast driver
                          @sdetweil now im getting this when I start it up? Any thoughts?
                          macserver@EDITHs-MacBook-Pro magicmirror % npm run server
                          evalmachine.<anonymous>:42
                          } = primordials;
                          ReferenceError: primordials is not defined
                              at evalmachine.<anonymous>:42:5
                              at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/fs.js:11:8)
                              at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:3:27)
                          Node.js v18.15.0
                          Tried running the node upgrade but that seem to fail too?
                            @croc_dad72 did u run the node20_install.sh script? by itself?
                            I have to go test it again
                            S BerkSmash1984B 2 Replies Last reply
                              @croc_dad72 @BKeyport and any others… I screwed up for the non-buster systems…
                              please try my scripts again… they should FIX the problems encountered…
                              I remove the current node and then install the correct… 18 for buster, 20 for bullseye
                              • BKeyportB
                                @sdetweil It does seem to work again on latest.
                                  SuperSchenk
                                  I also had this problem, using Buster on a Raspberry pi 3b.
                                  It started with my npm being to old, unable to upgrade because my node was to old.
                                  Installing the newest node gave me the `GLIBCXX_3.4.26’ not found (required by node) error.
                                  The solution for me was installing the LTS version of node using nvm.
                                  nvm install 'lts/*' --reinstall-packages-from=current
                                  nvm alias default 18
                                  this uses node version 18.
                                  after that I could upgrade npm
                                  nvm install-latest-npm
                                  and with all this in place the upgrade of magic mirror worked.
                                  Hope this helps
                                  • BerkSmash1984B
                                    BerkSmash1984 @sdetweil
                                    @sdetweil I tried to run the upgrade script on my RPI 4B running Bullseye and it hosed my MM. During the install, I see this:
                                    It appears to have removed/partially remove npm altogether:
                                    Any thoughts?
                                      sdetweil @BKeyport
                                      @BKeyport said in Upgrade errors?:
                                      we removed this in 2.25
                                      see
                                      or, you can comment out the require in the module node_helper.js
                                      as fetch is built in in 2.18 and up
                                        sdetweil @BerkSmash1984
                                        @BerkSmash1984 I see 64bit… let me look
                                        seems the process is different there… darn
                                        • mumblebajM
                                          @sdetweil Can you help me fix my WSL? I seem to be having and issue with electron and a missing lib. I have emailed you the install.log as well.
                                            sdetweil @mumblebaj
                                            @mumblebaj maybe
                                            https://github.com/snobu/destreamer/issues/216
