    Upgrade errors?
    35 Posts 9 Posters 16.2k Views 10 Watching
      sdetweil @mumblebaj
      @mumblebaj try the upgrade script again, with force instead of apply
      it will remove and and add the right version the right way, including on buster
      please advise your results…
      • BKeyportB Offline
        for my buster install:
        Ran “apply” re-run did bring back PM2 and other tools - No MagicMirror though. Says it’s running, but doesn’t appear.
        Running “force” re-run same result.
        0|MagicMirror  | > magicmirror@2.25.0 start
        0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
        0|MagicMirror  | [02.10.2023 15:49.10.094] [LOG]   Starting MagicMirror: v2.25.0
        0|MagicMirror  | [02.10.2023 15:49.10.101] [LOG]   Loading config ...
        0|MagicMirror  | [02.10.2023 15:49.10.105] [DEBUG] config template file not exists, no envsubst
        0|MagicMirror  | [02.10.2023 15:49.10.112] [LOG]   Loading module helpers ...
        0|MagicMirror  | [02.10.2023 15:49.10.114] [LOG]   No helper found for module: MMM-MagicMover.
        0|MagicMirror  | [02.10.2023 15:49.10.116] [LOG]   No helper found for module: alert.
        0|MagicMirror  | [02.10.2023 15:49.10.297] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [02.10.2023 15:49.10.298] [LOG]   Module helper loaded: calendar
        0|MagicMirror  | [02.10.2023 15:49.10.319] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [02.10.2023 15:49.10.320] [LOG]   Module helper loaded: MMM-CommandToNotification
        0|MagicMirror  | [02.10.2023 15:49.10.322] [LOG]   No helper found for module: clock.
        0|MagicMirror  | [02.10.2023 15:49.10.323] [LOG]   No helper found for module: MMM-Worldclock.
        0|MagicMirror  | [02.10.2023 15:49.10.326] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [02.10.2023 15:49.10.327] [LOG]   Module helper loaded: MMM-ValuesByNotification
        0|MagicMirror  | [02.10.2023 15:49.10.328] [LOG]   No helper found for module: MMM-Multimonth.
        0|MagicMirror  | [02.10.2023 15:49.10.331] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
        0|MagicMirror  | [02.10.2023 15:49.10.332] [LOG]   No helper found for module: MMM-CalendarExt3.
        0|MagicMirror  | [02.10.2023 15:49.10.463] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [02.10.2023 15:49.10.464] [LOG]   Module helper loaded: newsfeed
        0|MagicMirror  | [02.10.2023 15:49.10.519] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [02.10.2023 15:49.10.519] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
        0|MagicMirror  | [02.10.2023 15:49.10.525] [LOG]   Initializing new module helper ...
        0|MagicMirror  | [02.10.2023 15:49.10.525] [LOG]   Module helper loaded: updatenotification
        0|MagicMirror  | [02.10.2023 15:49.10.856] [ERROR] (node:7847) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
        0|MagicMirror  | Require stack:
        0|MagicMirror  | - /home/bkey1970/MagicMirror/modules/MMM-Wallpaper/node_helper.js
        0|MagicMirror  | - /home/bkey1970/MagicMirror/js/app.js
        0|MagicMirror  | - /home/bkey1970/MagicMirror/js/electron.js
        0|MagicMirror  | - /home/bkey1970/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
        0|MagicMirror  | -
        0|MagicMirror  |     at node:internal/modules/cjs/loader:1084:15
        0|MagicMirror  |     at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
        0|MagicMirror  |     at Module._resolveFilename (/home/bkey1970/MagicMirror/node_modules/module-alias/index.js:49:29)
        0|MagicMirror  |     at node:internal/modules/cjs/loader:929:27
        0|MagicMirror  |     at Function._load (node:electron/js2c/asar_bundle:2:13327)
        0|MagicMirror  |     at Module.require (node:internal/modules/cjs/loader:1150:19)
        0|MagicMirror  |     at require (node:internal/modules/cjs/helpers:110:18)
        0|MagicMirror  |     at Object.<anonymous> (/home/bkey1970/MagicMirror/modules/MMM-Wallpaper/node_helper.js:11:15)
        0|MagicMirror  |     at Module._compile (node:internal/modules/cjs/loader:1271:14)
        0|MagicMirror  |     at Object..js (node:internal/modules/cjs/loader:1326:10)
        0|MagicMirror  |     at Module.load (node:internal/modules/cjs/loader:1126:32)
        0|MagicMirror  |     at node:internal/modules/cjs/loader:967:12
        0|MagicMirror  |     at loadModule (/home/bkey1970/MagicMirror/js/app.js:180:19)
        0|MagicMirror  | (Use `electron --trace-warnings ...` to show where the warning was created)
        0|MagicMirror  | [02.10.2023 15:49.10.857] [ERROR] (node:7847) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
        0|MagicMirror  | [7847:1002/154911.190579:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
        0|MagicMirror  | MESA-LOADER: failed to retrieve device information
        0|MagicMirror  | MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
        0|MagicMirror  | failed to load driver: kms_swrast
        0|MagicMirror  | MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
        0|MagicMirror  | failed to load swrast driver
          croc_dad72 @sdetweil
          @sdetweil now im getting this when I start it up? Any thoughts?
          macserver@EDITHs-MacBook-Pro magicmirror % npm run server
          evalmachine.<anonymous>:42
          } = primordials;
          ReferenceError: primordials is not defined
              at evalmachine.<anonymous>:42:5
              at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/fs.js:11:8)
              at Module._compile (node:internal/modules/cjs/loader:1254:14)
              at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
              at Module.load (node:internal/modules/cjs/loader:1117:32)
              at Module._load (node:internal/modules/cjs/loader:958:12)
              at Module.require (node:internal/modules/cjs/loader:1141:19)
              at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:3:27)
          Node.js v18.15.0
          Tried running the node upgrade but that seem to fail too?
            sdetweil @croc_dad72
            @croc_dad72 did u run the node20_install.sh script? by itself?
            I have to go test it again
            S BerkSmash1984B 2 Replies Last reply Reply Quote 0
              @croc_dad72 @BKeyport and any others… I screwed up for the non-buster systems…
              please try my scripts again… they should FIX the problems encountered…
              I remove the current node and then install the correct… 18 for buster, 20 for bullseye
              • BKeyportB Offline
                @sdetweil It does seem to work again on latest.
                  SuperSchenk
                  I also had this problem, using Buster on a Raspberry pi 3b.
                  It started with my npm being to old, unable to upgrade because my node was to old.
                  Installing the newest node gave me the `GLIBCXX_3.4.26’ not found (required by node) error.
                  The solution for me was installing the LTS version of node using nvm.
                  nvm install 'lts/*' --reinstall-packages-from=current
                  nvm alias default 18
                  this uses node version 18.
                  after that I could upgrade npm
                  nvm install-latest-npm
                  and with all this in place the upgrade of magic mirror worked.
                  Hope this helps
                  • BerkSmash1984B Offline
                    BerkSmash1984 @sdetweil
                    @sdetweil I tried to run the upgrade script on my RPI 4B running Bullseye and it hosed my MM. During the install, I see this:
                    It appears to have removed/partially remove npm altogether:
                    Any thoughts?
                      sdetweil @BKeyport
                      @BKeyport said in Upgrade errors?:
                      Cannot find module ‘fetch’
                      we removed this in 2.25
                      see
                      or, you can comment out the require in the module node_helper.js
                      as fetch is built in in 2.18 and up
                        sdetweil @BerkSmash1984
                        @BerkSmash1984 I see 64bit… let me look
                        seems the process is different there… darn
                        • mumblebajM Offline
                          @sdetweil Can you help me fix my WSL? I seem to be having and issue with electron and a missing lib. I have emailed you the install.log as well.
                            sdetweil @mumblebaj
                            @mumblebaj maybe
                            https://github.com/snobu/destreamer/issues/216
                              @sdetweil Thanks Sam. A bunch of missing libs but all working again.
                              Now to add my modules I had running on the dev machine. The joy. :-)
                                sdetweil @mumblebaj
                                @mumblebaj always backup
                                I have one that makes a small image
                                https://github.com/sdetweil/MagicMirror-backup-restore
                                  @sdetweil I use your backup scripts on my main mirror. My dev machine I did not backup. Will teach me for next time. :crying_face:
                                  • BKeyportB Offline
                                    @sdetweil turns out there was an update to MMM-Wallpaper that missed due to all the bugs in upgrading. 😉
                                    S kaiK 2 Replies Last reply Reply Quote 0
                                      sdetweil @BKeyport
                                      @BKeyport yes I saw that too
                                        sdetweil @mumblebaj
                                        @mumblebaj My scripts don’t depend on node or anything else they’re all bash scripts. So if you haven’t deleted anything you can still run the back up there and be able to restore it later
                                        • kaiK Offline
                                          kai @BKeyport
                                          …just in case this might be interesting for anyone: I had the same problems on my Raspberry Pi 4 Model B (Rev 1.2) with buster (armv71).
                                          • node 20 gave me the `GLIBCXX_3.4.26’ not found (required by node) error
                                          • I had the “failed to load swrast driver”
                                          I checked my modules, and the solution for my MM was (thanks to @sdetweil and @BKeyport here):
                                          • installing node 18 (I did it manually like mentioned here)
                                          • removing “DWD Warn Weather” (which caused the swrast error) from config.js
                                          Now MagicMirror v2.25.0 is up and running! :beaming_face_with_smiling_eyes:
                                          Thank you for all your effort and your tireless support!
                                          May the code be with you.
                                          -kai
                                            JohnGalt
                                            @sdetweil - I’m not sure this the correct topic for my error, so if not we can move it - but I am having the issues described above, but on an initial install [as opposed to an upgrade]. This is on a freshly created VirtualBox VM using the current RaspbianOS version of Debian, using Sam’s install script.
                                            After a long series of lines indicating it was setting up various node packages, the install.log file ends with a message that node failed to install:
                                            added 1 package, and audited 2 packages in 1s
                                            found 0 vulnerabilities
                                            installing on bullseye
                                            installing correct version of node and npm, please wait
                                              installing : node-v20.8.0
                                                   mkdir : /usr/local/n/versions/node/20.8.0
                                                   fetch : https://nodejs.org/dist/v20.8.0/node-v20.8.0-linux-x64.tar.xz
                                                 copying : node/20.8.0
                                               installed :  (with npm )
                                            Note: the node command changed location and the old location may be remembered in your current shell.
                                                     old : /usr/bin/node
                                                     new : /usr/local/bin/node
                                            If "node --version" shows the old version then start a new shell, or reset the location hash with:
                                            hash -r  (for bash, zsh, ash, dash, and ksh)
                                            rehash   (for csh and tcsh)
                                            node failed to install, exiting
                                            Thoughts??
