    Upgrade errors?
    35 Posts 9 Posters 16.8k Views 10 Watching
    • BKeyportB Offline
      Nevermind. It appears required dependencies aren’t being updated to previous OSes. Time to switch away from Raspbian.
        sdetweil @BKeyport
        @BKeyport thanks, I’ll have to check this in the morning, and see how to do the c++ runtime upgrade too
        • BKeyportB Offline
          @sdetweil It appears node and/or NPM is the problem - some of their newer dependencies aren’t compatible with older Raspbian installs, which will make it impossible for me to run what I want on the mirror.
          Losing OMXPlayer murders my setup - so I’m working on something else.
            sdetweil @BKeyport
            @BKeyport yeh, looks like buster/legacy is too down level for node 20. let’s try 18
            sudo npm  i n
            sudo n i 18
            node -v should show node 18
            then
            rm -rf node_modules
            npm  run install-mm
            please advise
              croc_dad72 @sdetweil
              @sdetweil said in Upgrade errors?:
              rm -rf node_modules
              npm run install-mm
              The update seem to have crashed my Mirror, I applied these fixes but nothing will run here is my start up logs, what am I missing? Any help would be much appreciated! Thanks.
              macserver@EDITHs-MacBook-Pro MagicMirror % npm run server
              > magicmirror@2.25.0 server
              > node ./serveronly
              [02.10.2023 07:51.49.432] [LOG]   Starting MagicMirror: v2.25.0
              [02.10.2023 07:51.49.436] [LOG]   Loading config ...
              [02.10.2023 07:51.49.438] [DEBUG] config template file not exists, no envsubst
              [02.10.2023 07:51.49.442] [LOG]   Loading module helpers ...
              [02.10.2023 07:51.49.443] [LOG]   No helper found for module: alert.
              [02.10.2023 07:51.49.449] [LOG]   Initializing new module helper ...
              [02.10.2023 07:51.49.450] [LOG]   Module helper loaded: updatenotification
              [02.10.2023 07:51.49.451] [LOG]   No helper found for module: clock.
              [02.10.2023 07:51.49.676] [LOG]   Initializing new module helper ...
              [02.10.2023 07:51.49.676] [LOG]   Module helper loaded: MMM-quote-of-the-day
              [02.10.2023 07:51.49.765] [ERROR] Whoops! There was an uncaught exception...
              [02.10.2023 07:51.49.770] [ERROR] Error: Cannot find module 'fetch'
              Require stack:
              - /Users/macserver/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js
              - /Users/macserver/MagicMirror/modules/MMM-MyCalendar/node_helper.js
              - /Users/macserver/MagicMirror/js/app.js
              - /Users/macserver/MagicMirror/serveronly/index.js
                  at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
                  at Module._resolveFilename (/Users/macserver/MagicMirror/node_modules/module-alias/index.js:49:29)
                  at Module._load (node:internal/modules/cjs/loader:920:27)
                  at Module.require (node:internal/modules/cjs/loader:1141:19)
                  at require (node:internal/modules/cjs/helpers:110:18)
                  at Object.<anonymous> (/Users/macserver/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js:11:15)
                  at Module._compile (node:internal/modules/cjs/loader:1254:14)
                  at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                  at Module.load (node:internal/modules/cjs/loader:1117:32)
                  at Module._load (node:internal/modules/cjs/loader:958:12)
                  at Object.<anonymous> (/Users/macserver/MagicMirror/modules/MMM-MyCalendar/node_helper.js:8:25)
                  at Module.load (node:internal/modules/cjs/loader:1117:32) {
                code: 'MODULE_NOT_FOUND',
                requireStack: [
                  '/Users/macserver/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js',
                  '/Users/macserver/MagicMirror/modules/MMM-MyCalendar/node_helper.js',
                  '/Users/macserver/MagicMirror/js/app.js',
                  '/Users/macserver/MagicMirror/serveronly/index.js'
              [02.10.2023 07:51.49.771] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [02.10.2023 07:51.49.771] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              S karsten13K 2 Replies Last reply Reply Quote 0
                sdetweil @croc_dad72
                @croc_dad72 said in Upgrade errors?:
                Error: Cannot find module ‘fetch’
                see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
                  sdetweil @BKeyport
                  @BKeyport also try the new temp node20 install script, listed at the top of my scripts page
                  • karsten13K Offline
                    karsten13 @croc_dad72
                    @croc_dad72
                    looks like you are on deprecated node version, run node -v which must be >= v18
                    • mumblebajM Offline
                      mumblebaj Module Developer @karsten13
                      @karsten13 Upgrade just broke my dev machine. :-) Guess I am not upgrading my mirror. Had to wipe my whole WSL Ubuntu install. Have to start from scratch with my dev machine. Not a great upgrade. My prod mirror is still a PI 3B running buster. :confounded_face:
                        sdetweil @mumblebaj
                        @mumblebaj buster is broken… do NOT upgrade buster machines…
                        lsb_release -a
                        to see what you have
                        mumblebajM 1 Reply Last reply Reply Quote 1
                          @sdetweil Thanks Sam. I already broke my dev machine. How do I clean install 2.24.0?
                            sdetweil @mumblebaj
                            @mumblebaj try the upgrade script again, with force instead of apply
                            it will remove and and add the right version the right way, including on buster
                            please advise your results…
                            • BKeyportB Offline
                              for my buster install:
                              Ran “apply” re-run did bring back PM2 and other tools - No MagicMirror though. Says it’s running, but doesn’t appear.
                              Running “force” re-run same result.
                              0|MagicMirror  | > magicmirror@2.25.0 start
                              0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                              0|MagicMirror  | [02.10.2023 15:49.10.094] [LOG]   Starting MagicMirror: v2.25.0
                              0|MagicMirror  | [02.10.2023 15:49.10.101] [LOG]   Loading config ...
                              0|MagicMirror  | [02.10.2023 15:49.10.105] [DEBUG] config template file not exists, no envsubst
                              0|MagicMirror  | [02.10.2023 15:49.10.112] [LOG]   Loading module helpers ...
                              0|MagicMirror  | [02.10.2023 15:49.10.114] [LOG]   No helper found for module: MMM-MagicMover.
                              0|MagicMirror  | [02.10.2023 15:49.10.116] [LOG]   No helper found for module: alert.
                              0|MagicMirror  | [02.10.2023 15:49.10.297] [LOG]   Initializing new module helper ...
                              0|MagicMirror  | [02.10.2023 15:49.10.298] [LOG]   Module helper loaded: calendar
                              0|MagicMirror  | [02.10.2023 15:49.10.319] [LOG]   Initializing new module helper ...
                              0|MagicMirror  | [02.10.2023 15:49.10.320] [LOG]   Module helper loaded: MMM-CommandToNotification
                              0|MagicMirror  | [02.10.2023 15:49.10.322] [LOG]   No helper found for module: clock.
                              0|MagicMirror  | [02.10.2023 15:49.10.323] [LOG]   No helper found for module: MMM-Worldclock.
                              0|MagicMirror  | [02.10.2023 15:49.10.326] [LOG]   Initializing new module helper ...
                              0|MagicMirror  | [02.10.2023 15:49.10.327] [LOG]   Module helper loaded: MMM-ValuesByNotification
                              0|MagicMirror  | [02.10.2023 15:49.10.328] [LOG]   No helper found for module: MMM-Multimonth.
                              0|MagicMirror  | [02.10.2023 15:49.10.331] [LOG]   No helper found for module: MMM-CalendarExt3Agenda.
                              0|MagicMirror  | [02.10.2023 15:49.10.332] [LOG]   No helper found for module: MMM-CalendarExt3.
                              0|MagicMirror  | [02.10.2023 15:49.10.463] [LOG]   Initializing new module helper ...
                              0|MagicMirror  | [02.10.2023 15:49.10.464] [LOG]   Module helper loaded: newsfeed
                              0|MagicMirror  | [02.10.2023 15:49.10.519] [LOG]   Initializing new module helper ...
                              0|MagicMirror  | [02.10.2023 15:49.10.519] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
                              0|MagicMirror  | [02.10.2023 15:49.10.525] [LOG]   Initializing new module helper ...
                              0|MagicMirror  | [02.10.2023 15:49.10.525] [LOG]   Module helper loaded: updatenotification
                              0|MagicMirror  | [02.10.2023 15:49.10.856] [ERROR] (node:7847) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
                              0|MagicMirror  | Require stack:
                              0|MagicMirror  | - /home/bkey1970/MagicMirror/modules/MMM-Wallpaper/node_helper.js
                              0|MagicMirror  | - /home/bkey1970/MagicMirror/js/app.js
                              0|MagicMirror  | - /home/bkey1970/MagicMirror/js/electron.js
                              0|MagicMirror  | - /home/bkey1970/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                              0|MagicMirror  | -
                              0|MagicMirror  |     at node:internal/modules/cjs/loader:1084:15
                              0|MagicMirror  |     at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                              0|MagicMirror  |     at Module._resolveFilename (/home/bkey1970/MagicMirror/node_modules/module-alias/index.js:49:29)
                              0|MagicMirror  |     at node:internal/modules/cjs/loader:929:27
                              0|MagicMirror  |     at Function._load (node:electron/js2c/asar_bundle:2:13327)
                              0|MagicMirror  |     at Module.require (node:internal/modules/cjs/loader:1150:19)
                              0|MagicMirror  |     at require (node:internal/modules/cjs/helpers:110:18)
                              0|MagicMirror  |     at Object.<anonymous> (/home/bkey1970/MagicMirror/modules/MMM-Wallpaper/node_helper.js:11:15)
                              0|MagicMirror  |     at Module._compile (node:internal/modules/cjs/loader:1271:14)
                              0|MagicMirror  |     at Object..js (node:internal/modules/cjs/loader:1326:10)
                              0|MagicMirror  |     at Module.load (node:internal/modules/cjs/loader:1126:32)
                              0|MagicMirror  |     at node:internal/modules/cjs/loader:967:12
                              0|MagicMirror  |     at loadModule (/home/bkey1970/MagicMirror/js/app.js:180:19)
                              0|MagicMirror  | (Use `electron --trace-warnings ...` to show where the warning was created)
                              0|MagicMirror  | [02.10.2023 15:49.10.857] [ERROR] (node:7847) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                              0|MagicMirror  | [7847:1002/154911.190579:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                              0|MagicMirror  | MESA-LOADER: failed to retrieve device information
                              0|MagicMirror  | MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                              0|MagicMirror  | failed to load driver: kms_swrast
                              0|MagicMirror  | MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                              0|MagicMirror  | failed to load swrast driver
                                @sdetweil now im getting this when I start it up? Any thoughts?
                                macserver@EDITHs-MacBook-Pro magicmirror % npm run server
                                evalmachine.<anonymous>:42
                                } = primordials;
                                ReferenceError: primordials is not defined
                                    at evalmachine.<anonymous>:42:5
                                    at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/fs.js:11:8)
                                    at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:3:27)
                                Node.js v18.15.0
                                Tried running the node upgrade but that seem to fail too?
                                  @croc_dad72 did u run the node20_install.sh script? by itself?
                                  I have to go test it again
                                  S BerkSmash1984B 2 Replies Last reply Reply Quote 0
                                    @croc_dad72 @BKeyport and any others… I screwed up for the non-buster systems…
                                    please try my scripts again… they should FIX the problems encountered…
                                    I remove the current node and then install the correct… 18 for buster, 20 for bullseye
                                    • BKeyportB Offline
                                      @sdetweil It does seem to work again on latest.
                                        SuperSchenk
                                        I also had this problem, using Buster on a Raspberry pi 3b.
                                        It started with my npm being to old, unable to upgrade because my node was to old.
                                        Installing the newest node gave me the `GLIBCXX_3.4.26’ not found (required by node) error.
                                        The solution for me was installing the LTS version of node using nvm.
                                        nvm install 'lts/*' --reinstall-packages-from=current
                                        nvm alias default 18
                                        this uses node version 18.
                                        after that I could upgrade npm
                                        nvm install-latest-npm
                                        and with all this in place the upgrade of magic mirror worked.
                                        Hope this helps
                                        • BerkSmash1984B Offline
                                          BerkSmash1984 @sdetweil
                                          @sdetweil I tried to run the upgrade script on my RPI 4B running Bullseye and it hosed my MM. During the install, I see this:
                                          It appears to have removed/partially remove npm altogether:
                                          Any thoughts?
                                            sdetweil @BKeyport
                                            @BKeyport said in Upgrade errors?:
                                            we removed this in 2.25
                                            see
                                            or, you can comment out the require in the module node_helper.js
                                            as fetch is built in in 2.18 and up
