    MMM-birthdays
    modulereminders
    13 Posts 9 Posters 8.9k Views 9 Watching
    • A
      amitchone
      Hey all, figured I’d post this here as it seems to be being adopted by more people than I would have ever imagined, so maybe it’s quite useful.
      It’s just a simple module I made to remind you about birthdays with a configurable notice period. That’s it, that’s all it is. Just list the birthdays (either in config.js or a JSON file, to avoid config.js getting too cluttered, in the MMM-birthdays/ directory) and off you go!
      More feedback and users will make it more robust and hopefully more useful to more people, so if you feel this is something you could use, please do try it out!
      Cheers all,
      Adam
      J MZ-BERM 2 Replies Last reply
      Reply Quote 2
        james3xyx3 @amitchone
        D 1 Reply Last reply
        • MZ-BERM
          MZ-BER @amitchone
          @amitchone Thanks for sharing Adam! :clapping_hands:
          • K
            kasperinline
            Great work, and allready in use :-)
              det @james3xyx3
              @james3xyx3 said in MMM-birthdays:
              @amitchone hello, thanks for creating this module. When I try git clone your repository I get unable to access, the TLS connection was non-properly terminated. Not sure what’s wrong.
              You have to send out /MagicMirror/modules folder with:
              git clone https://github.com/amitchone/MMM-birthdays.git
              J 1 Reply Last reply
                james3xyx3 @det
                  Chazzer
                  Hi! I came across your module yesterday and installed it. First of all, thanks for the module and the excellent guide. I’m using it with a .*json document, and I find it convenient that it’s separated and doesn’t need to be in the config.
                  Do you have any plans to add icons for birthdays in the future? An idea would be to display round birthdays with balloons, confetti, or just colored or monochrome icons that can be customized. I think that would be great.
                    sdetweil @Chazzer
                    @Chazzer you can also look at my birthday list module
                    https://github.com/sdetweil/birthdaylist
                    from a csv, multiple people with the same are on the same line
                    i have an image, but its the same…
                    could be extended to add another csv column with the image name
                    C 1 Reply Last reply
                      Chazzer @sdetweil
                      @sdetweil Hello, thank you for the module recommendation. I’ll definitely take a closer look at it. Could you please share a screenshot that includes the icon and birthdays?
                        sdetweil @Chazzer
                        only shows this month forward to end of the year, birthdays prior to today in this month are greyed out
                        multiple people can have the same BD… but same or different ages listed together…
                        this image is the calendar sheet with the month day number on it
                        the module settings for this image are
                                module: "birthdaylist",
                                disabled: false,
                                position:'top_left',
                        			language: "en",
                        			dimmEntries: true,  // true: dims entries and the associated
                        					     //       symbol when the date has expired.
                        				             // false: dont display entries and the associated
                        			initialLoadDelay: 0, // How many seconds to wait on a fresh start up.
                        					     // This is to prevent collision with all other modules also
                        					     // loading all at the same time. This only happens once,
                        					     // when the mirror first starts up.
                        			updateDelay: 5,      // How many seconds after midnight before a refresh
                        					     // This is to prevent collision with other
                        					     // modules refreshing at the same time.
                        			currentMonthOnly: false,  // will show birthdays for the current month only if true
                        			maxEntries: 0,			 // maximum entries to show, default is all
                        			dateFormat: '',			 // date format for birthday (default is none), could be 'Do' for 'Sep 12th'
                        			ageFormat:'',			 // some format string for the persons age, '[ n ]'  n will be replace by age value
                        			debug:false
                        • G
                          greedyvegan
                          is there a way to include google contacts birthdays, instead of individually adding birthdates?
                            Chazzer @sdetweil
                            @sdetweil Thank Sam. :call_me_hand:
                            • M MyMirror referenced this topic on
                              jbat66
                              I updated MMM-birthdays to add the ability to turn off the module when there are no bdays to show.
                              Also added the ability to update the name of the title/header
                              Pull request here: https://github.com/amitchone/MMM-birthdays/pull/10
                              My fork, if you want to install and test it.
                              https://github.com/jbat66/MMM-birthdays
                              Thank you Adam for writing this module.
