    [ORDER CLOSED] Two way mirror order in Germany
    Scheduled Pinned Locked Moved Solved Hardware
    558 Posts 80 Posters 2.9m Views 60 Watching
    • G Offline
      Goldjunge_Chriz @lolobyte
      @lolobyte
      7,5 kg :)
      • L Offline
        lolobyte @Goldjunge_Chriz
        @Goldjunge_Chriz
        if i’m correct and no error in my calculation then i carry a weight of 63 kg only mirror glaas.
        That’s ok.
        Some packaging material an all mirrors are welcome in my car.
        G 2 Replies Last reply Reply Quote 1
        • G Offline
          @lolobyte
          Which mirrors do you now exactly pick up in your car? Please tell me all names.
          • L Offline
            @Goldjunge_Chriz
            ok, here the list taken from the master list…
            @mcg | 0,50m²
            @CFenner | 0,45m²
            @sero | 0,20m² | confirmed
            @yaye | 0,20m² | confirmed
            @mantha | 0,55m² | confirmed
            @Mire | 0,80m² | confirmed
            @jupilde | 0,45m²
            @lolobyte | 0,96m² | confirmed ;-)
            To all members listed here. Please confirm your pickup in Heilbronn.
            If other member wish this service, please post it here.
            M M S J 4 Replies Last reply Reply Quote 0
              Mire @lolobyte
              DoubleConfirm @Goldjunge_Chriz @lolobyte
              • G Offline
                @lolobyte
                Then you have actually only 31 kg in your car ;)
                • L Offline
                  @Goldjunge_Chriz
                  yes, was a mistake
                    mantha @lolobyte
                    @lolobyte
                    Confirm, Heilbronn is fine for me due to I’m often in Neckarsulm.
                    Many thanks for the service!!!
                    Manuel
                      Ashidian
                      @Goldjunge_Chriz confirmed
                      I have one last question. What happens if the package arrived, had no noticable damage on the outside but when I unpacked it the mirror is broken?
                      • W Offline
                        wiloo
                        @Goldjunge_Chriz confirmed! And thx for your offer :)
                        • Y Offline
                          yaye
                          @Goldjunge_Chriz @lolobyte I confirm my order and the pick up in Heilbronn
                          • F Offline
                            fez @Goldjunge_Chriz
                              cpramhofer
                              @schlachtkreuzer6 @XxX_Cobra_XxX @wiloo
                              @Goldjunge_Chriz
                              for you Austrian Guys:
                              is anyone now picking up the mirrors from germany? of course i would also pay something for the delivery!
                              i really don´t want to reduce size ;)
                              • MichMichM Offline
                                MichMich
                                You guys have no idea how freaking awesome it is for me to see some many people working together to improve the MagicMirror. I could have never guessed so many people were willing to spend money on something I initially started!
                                Keep up the great work guys! Greets from your western neighbours! :)
                                  cpramhofer
                                  @Goldjunge_Chriz
                                  if it would fit then i would reduce the size to 115 x 60
                                  Thanks you so much for that!
                                  • F Offline
                                    fox
                                    @Goldjunge_Chriz i update on
                                    55,3 x 32,3
                                    and confirm hereby
                                    Issues With MMM-WatchDog known?
                                    https://forum.magicmirror.builders/post/29827
                                    Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                    • G Offline
                                      Goldjunge_Chriz @Ashidian
                                      @Ashidian
                                      If nothing is noticeable on the outside, the mirror will not be broken, because I will pack it very well :) I give myself really great effort, you can believe me. The material costs then also a small amount, but that is worth it;)
                                      @MichMich
                                      Thank you for your praise. To hear this from you is a special pleasure and makes me proud. But a special thank you really goes to you ;)
                                      • G Offline
                                        Goldjunge_Chriz
                                        @cpramhofer
                                        Unfortunately, this is still too big. DHL has the maximum size for international shipping of 120x60x60cm. At Hermes, the longest + shortest side must be smaller than 120cm. Since the crate is of course larger than the mirror, we exceed the maximum with your dimensions. The other shipping companies like DPD, UPS, Iloxx etc are unfortunately much too expensive.
                                        @all @fox
                                        I just updated the list above and adjusted it
                                        • O Offline
                                          oberschlingel
                                          Is it still possible to be part of the order? I would like to order a 0.6m x 1.0m with polished edges to Berlin, Germany.
                                          Thank you very much!
                                            ace0024 @Goldjunge_Chriz
                                            ace0024 - confirmed!
                                            Thank you!
                                            Finally, here is the final list:
                                            # username sizes (m) area (m²) location additional comments pickup/delivery confirmed
                                            01 yawns ~ 0.8 * 0.8 ~ 0.64 Germany, Cologne polished edges delivery
                                            02 gustav1976 0.6 * 1.8 1.08 Germany, Koblenz polished edges delivery
                                            03 gustav1976 1.0 * 1.2 1.20 Germany, Koblenz polished edges delivery
                                            04 gustav1976 1.4 * 0.8 1.12 Germany, Koblenz polished edges delivery
                                            05 lolobyte 0.8 * 0.6 0.48 Germany, Heilbronn polished edges pickup
                                            06 lolobyte 0.8 * 0.6 0.48 Germany, Heilbronn polished edges pickup
                                            07 Jeff 1.0 * 0.6 0.6 Germany, Karlsruhe polished edges pickup
                                            08 Ashidian 0.69 * 0.435 0.3 (pay 0.4) Germany, Rostock polished edges delivery ✓
                                            09 cpramhofer 1.2 * 0.7 0.84 Austria, Vienna polished edges delivery
                                            10 Schlachtkreuzer ~ 1.0 * 1.0 ~ 1.0 Austria, Vienna polished edges delivery
                                            11 mcg 0.5 * 1.0 0.5 Germany, Ludwigshafen polished edges pickup in Heilbronn
                                            12 cfenner 0.667 * 0.667 0.45 Germany, Mannheim polished edges pickup in Heilbronn
                                            13 sero 0.5 * 0.4 0.2 (pay 0.4) Germany, Stuttgart polished edges pickup in Heilbronn ✓
                                            14 Deepgear 0.46 * 1.5 0.69 Germany, Pforzheim just cut pickup
                                            15 Binog 0.8 * 0.5 0.4 Germany, Cologne polished edges delivery
                                            16 yaye 0.5 * 0.4 0.2 (pay 0.4) Germany, Stuttgart polished edges pickup in Heilbronn ✓
                                            17 Ali Baba 0.4 * 1.0 0.4 Germany, Hoyerswerda polished edges delivery ✓
                                            18 mantha 0.563 * 0.97 0.55 Germany, Ulm polished edges pickup in Heilbronn ✓
                                            19 fox 0.553 * 0.323 0.18 (pay 0.4) Germany, Schwabmünchen polished edges delivery ✓
                                            20 wiloo 0.7 * 0.5 0.35 (pay 0.4) Germany, Traunstein polished edges delivery ✓
                                            21 ace0024 1.7 * 0.45 0.76 Germany, Neuried near Munich polished edges delivery ✓
                                            22 mire 0.8 * 1.0 0.8 Germany, Ludwigsburg polished edges pickup in Heilbronn ✓
                                            23 selarp 0.55 * 0.8 0.44 Schweden polished edges delivery
                                            24 jupilde 0.6 * 0.9 0.54 Germany, Stuttgart polished edges pickup in Heilbronn
                                            25 ZombieDE 0.36 * 1.0 0.36 (pay 0,4) Germany, Passau polished edges delivery
                                            26 olexs 0.63 * 0,379 0.239 (pay 0,4) Germany, Bad Homburg polished edges delivery
                                            27 ferby09 0.6 * 1.0 0.6 Germany, Berlin polished edges delivery ✓
                                            Total 16.37 (15.4)
                                            Z 1 Reply Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 27
                                            • 28
                                            • 12 / 28
