    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 412.0k Views 32 Watching
      danidanial
      I was able to get it working. For those that may need to resolve this in the future, the answer was at this link: :backhand_index_pointing_right_light_skin_tone:
      https://github.com/MMRIZE/MMM-CalendarExt3Agenda#update-to-120
      When some submodule is not updated, try this.
      cd ~/MagicMirror/modules/MMM-CalendarExt3Agenda
      git submodule update --init --recursive
        MarNog @MMRIZE
        @MMRIZE Thanks for the module! I see your first screenshot and looks like you have multiple calendars using the original MMM-Calendar and MMM-CalendarExt3Agenda modules. What setting do you use to get it working like this? I setup mine, but I cant figure out what do do on the original MMM-Calendar module to display only one specific calendar and another calendar to be displayed using Ext3Agenda module. Also, what is the best way to get hyphens in the column to be between the times when using 2 digits for hours?
        	header: "Cabrillo's Dates and Deadlines",
        	position: "bottom_right", //When you want to hide default calendar module, just remove position of calendar module.
        		maxTitleLength: 50,
        		wrapEvents: true,
        		tableClass: "small",
        		maximumEntries: 13,
        		//sliceMultiDayEvents: true,
        			symbol: "calendar-check",
        			name: "Cabrillo_Dates_Deadlines", // <-- specify calendar name
        			url: "https://calendar.google.com/calendar/ical/c_5a2463022055508fcb5a604f131895484562edb98904940f4efb3fa1c1362e47%40group.calendar.google.com/public/basic.ics",
        			// HOW to REMOVE this one from the Calendar Module??
        			url: "https://calendar.google.com/calendar/ical/c_jvq8rotabh0rrru2qeo2oec9gc%40group.calendar.google.com/public/basic.ics",
        			name: "CTC_Schedule", // <-- specify calendar name
        			color: "skyblue", // <-- if you don't want to get color, just remove this line.
        			broadcastPastEvents: true, // <-- need to broadcast past events
        			maximalNumberOfDays: 30, // <-- how old events would be broadcasted
        			maximumEntries: 100, // <-- assign enough number to prevent truncating new events by old events.
        			symbol: 'calendar-check', // <-- when you want to display symbol. If you don't want, just set as `symbol:[],`
          module: "MMM-CalendarExt3Agenda",
          title: "CTC TA Schedule",
            instanceId: "CTCCalendar",
            firstDayOfWeek: 1,
            startDayIndex: 0,
            endDayIndex: 2,
            showMiniMonthCalendar: false,
            calendarSet: ['CTC_Schedule'],
            eventFilter: (ev) => {
                     if (ev.title.startsWith("OUT")) {
                     	return false
        	     return true
        Thank you
        BKeyportB M 2 Replies Last reply Reply Quote 0
        • BKeyportB Offline
          BKeyport Module Developer @MarNog
          @MarNog Multiple instances of the calendar module. One with position in place for the ones you want to show with the default module, one without a position for the ones you want to display with CX3A.
            MMRIZE @MarNog
            @MarNog
            Interesting. You might have added some custom CSS, so hard to guess what happened at the moment.
            I think the area for time displaying is not so wide enough. Give them more space.
            Currently, the hyphen and startTime/endTime condition is defined like this.
            /* MMM-CalendarExt3Agenda.css line 187 */
            .CX3A .event .time {
              font-size: 75%;
              vertical-align: text-bottom;
            .CX3A .event .time.notInDay {
              display: none;
            .CX3A .event .startTime::after {
              content: ' -';
            .CX3A .event .startTime.notInDay + .endTime.inDay::before {
              content: '- ';
              MarNog @BKeyport
              @BKeyport I added another instance of the Calendar module and it worked like charm. Thank you.
                MarNog @MMRIZE
                @MMRIZE I had used a custom.css from someone’s post and I modified the font size. After your suggestion I changed the width on the custom.css and the time is showing correctly now. Thank you
                • T Offline
                  themoe @MMRIZE
                  @MMRIZE I really like your modules! I tried to setup the Ext3Agenda, but with no success.
                  Can you share the part of the config file to show the Agenda for a couple of days with the scheduled meetings?
                    MMRIZE @themoe
                    @themoe
                    In many cases; ppl might have missed/made wrong to the default calendar setting.
                    Show me your config for default calendars module and CX3A instead.
                    • G Offline
                      gonzonia
                      I have two instances of MMM-CalendarExt3Agenda showing with different calendar sets.
                      For one set it shows data for 4 days, with all days populated.
                      For the other one, it shows 4 days but the last day isn’t populated. If I increase the endDayIndex by 1 it will add a 5th day and day 4 will be populated but the 5th day will not, so I know the data is there.
                      Any ideas what would cause this?
                      Working instance 1:
                      			classes: "SceneFamily",
                      			header: "Upcoming Family Calendar",
                      				instanceId: "FamilyAgenda",
                      				locale: 'en-US',
                      				firstDayOfWeek: 1,
                      				startDayIndex: 0,
                      				endDayIndex: 3,
                      				useSymbol: true,
                      				calendarSet: ['Dad', 'Mom', 'Kid1', 'Kid2', 'Work1', 'Work22, 'Home'],
                      Missing Data Instance 2
                      			classes: "SceneFamily SceneKids",
                      			header: "Chores",
                      				instanceId: "Chores",
                      				locale: 'en-US',
                      				firstDayOfWeek: 1,
                      				startDayIndex: 0,
                      				endDayIndex: 3,
                      				useSymbol: true,
                      				calendarSet: ['Dad Chores', 'Kid Chores', 'Mom Chores'],
                      • UncleRogerU Offline
                        UncleRoger
                        I apologize for what I’m sure is a bonehead question… I had a stock calendar module to show events from one calendar (and a second, hidden instance of calendar) but when I tried to implement pages (MMM-Pages), it was loading the hidden calendar along with the non-hidden one.
                        So I thought I’d try CalExt3Ag to replace the visible calendar. The problem is, I want it to look like the stock calendar:
                        but the best I could get is this:
                        Is it possible to get a much simplified listing (one line per event, relative dates) of events using CalExt3Ag?
                        • BKeyportB Offline
                          BKeyport Module Developer @UncleRoger
                          @UncleRoger Not exactly. However you can get it simplied some:
                          That’s all CSS.
                            MMRIZE @UncleRoger
                            @UncleRoger
                            1. About the look of the module to mimic the original calendar module;
                              Sorry, it can’t. This module is an alternative view of your events listing, not a replacement. If you need only the same look as the original calendar, just use the original.
                            2. About the working with MMM-Pages.
                              MMM-Pages is a good, reliable module, though it doesn’t consider the multi-instance of the module. So when you need multi-instances and want to show/hide on different pages, it cannot work as expected. Try other paging/screen control module. (e.g. I recommend MMM-Scenes2 with shame.)
                              MMM-Scenes2 Demo
                              Click to see the DEMO
                            My mistake. You can assign class name in MMM-Pages settings. (Thanks @sdetweil )
                              sdetweil @MMRIZE
                              @MMRIZE i.like you Scenes module.
                              but MMM-Pages works fine for multi instance. just don’t use the module name in the page definition
                              use page1, page2, page3…
                              and then use that in the individual module classes: setting
                              super easy and much more clear
                              M UncleRogerU 2 Replies Last reply Reply Quote 1
                                MMRIZE @sdetweil
                                Ah, I misunderstood those identifiers are module name not class name.
                                  sdetweil @MMRIZE
                                  @MMRIZE well they are used as class names in the code lookup. each module’s name is
                                  assigned as a class in the Dom for each module.
                                  that’s why using module name is not instance aware.
                                  but classes can be any string, and pages just search for all with that class.
                                    MMRIZE @sdetweil
                                    You are right.
                                    However the example seems somehow ambiguous (though config description) It might mislead someone.(like @UncleRoger or me) :D
                                      sdetweil @MMRIZE
                                      @MMRIZE yes, I would have preferred my description , but I can’t update the doc.
                                      depends on where u want the config info (all in the pages config, which doesn’t support multi-instance cause it talks module name)
                                      or all at the modules. page1, page2. etc
                                      understandable, but spread out.
                                      edit : I updated the MMM-Pages readme (also the front page of the module on Github )to describe this
                                      https://github.com/sdetweil/MMM-pages
                                        UncleRoger @sdetweil
                                        @sdetweil @MMRIZE
                                        You guys are amazing! Thank you!
                                        Scenes2 looks really interesting but I think it’s probably overkill for what I’m trying to do (MagicMirror swapping with Mr. Rogers’ Picture Picture). I could see that there are a lot of possibilities with it. I might play around with it for a future build.
                                        The reason I have two calendar modules is that one is displayed for the dinner menu and one is there just to define the calendars for MMM-MonthlyCalendar. I’m planning on playing with CalendarExt3 to see if I like it better than MonthlyCalendar but the latter was quick and easy to get going.
                                        Anyway, thanks again!
                                          sdetweil @UncleRoger
                                          @UncleRoger if it doesn’t have a position, it would.
                                          be in the fixed section of pages, else it would think it is suspended, and not operate. fixedeans on all pages, but it still wouldn’t be shown
                                            CDT @sdetweil
                                            Possible bug here. The Agenda doesn’t show scheduled events on the final day as set by the endDateIndex.
                                            I’m trying to get the Ext3Agenda to show me just a single day. Using startDayIndex:0, endDateIndex:0. When doing this, it only shows full-day events, not events scheduled a specific time.
                                            If I change endDateIndex:1, then I get the proper items appearing, but also a header for day 2.
                                            I notice that not matter what the endDateIndex is listed, it doesn’t seem to show sheduled events the last day. Only the header and any full-day events.
                                            M luisestradaL 3 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 12
                                            • 7 / 12
