    MMM-aviationwx (Aviation weather)
    111 Posts 12 Posters 132.7k Views 11 Watching
      stuloh
      This module displays METAR data (weather reporting information normally used for aviation purposes) and, where available, FAA delay data for airports in the continental United States.
      This is my first MM module (and first GitHub repo for that matter), so feedback and improvements are welcome!
        daffythug
        Hello, there is a commit on github to add worldwide support. Can you look at it? I couldnt make it work unfortunately.
          stuloh
          Ah yes - I’ll take a look at it - a bit time strapped at the moment, but will get around to it eventually.
            cohron
            Great start, already using it. I assume you are a fellow pilot.
            • 3 Offline
              320fan
              Hi all,
              I would like to push development of this module. Now, it can track only US airports, but the best way to allow worldwide aviation weather (METAR & TAF) monitoring. For that, I would like to propose a https://avwx.rest service. In addition to “raw” METAR&TAF data (https://avwx.rest/api/metar/KJFK for example) with JSON format, you can parse any weather data via AVWX engine (example: https://avwx.rest/api/parse/metar?report=KJFK 012251Z 04012KT 10SM OVC011 16/13 A3014&options=info,translate)
              Is anyone able to help with this modification? I’m not an expert in java (but I can help with decoding of TAF&METAR data for sure ;) But, however, I can help with test for that script modification.
                Mykle1 Project Sponsor Module Developer @320fan
                @320fan
                Have you tried to contact the author?
                3 1 Reply Last reply Reply Quote 0
                • 3 Offline
                  320fan @Mykle1
                  @Mykle1 said in MMM-aviationwx (Aviation weather):
                  @320fan
                  Sure. He told me that for this moment he doesn’t have time for that. So, I would like to find a people, who interested in that development.
                    @320fan
                    Oh, I see. I will take a look at the data. You are interested in both METAR and TAF data? Can you give me a url to the data that you do want?
                    • 3 Offline
                      320fan @Mykle1
                      @320fan
                      Firstly, thanks for your help. As I told before, I’m not a expert in Java.
                      Yea, I would like to get both METAR/TAF data. And I would like to keep a initial MMM-aviationwx layout for METAR (Wind, Visibility, clouds, temperature and runaway codition). For the TAF reports - I just want to see all available time periods with data above.
                      If I got you correctly, as initial reference you can take next data (it’s my base airport):
                      https://avwx.rest/api/taf/uudd
                      https://avwx.rest/api/metar/uudd
                      P.S. If I go deeply into the detail - my company use AIMS Crew Management System, for which I have iPad iAIMS application, which creates events in my calendar like “3355 DME GYD”. Number - it’s a flight number and DME/GYD - IATA departure and arrival airports. As a best solution I would like to see both METAR/TAF reports for the next upcoming flight in the calendar. For the calendar - I have set up sync of my MagicMirror with iCloud based calendar via vdirsyncer:
                                              header: "Main calendars",
                                              position: "bottom_left",
                                                      colored: true,   // Activate coloring
                                                      fetchInterval: 100000, // ~2 mins
                                                      timeFormat: "relative",
        symbol: 'plane',
        maximumEntries: 5,
        maximumNumberOfDays: 31,
        color: '#16416B',
        url: 'http://localhost:8080/modules/calendars/my_iCloud_ID_for_calendar.ics',
                        @320fan
                        In its simplest form, the data from the TAF url
                        It appears somewhat incomplete, as some of the elements have no data within them. Also, the data for TAF does not include flight information that I can see. I can take a look at the METAR data later today if you like
                        • 11
                        • 12
                        • 1 / 12
