    Something I'm working on ...
    Scheduled Pinned Locked Moved Announcements
    39 Posts 12 Posters 53.5k Views 12 Watching
    • tosti007T
      tosti007 Module Developer @MichMich
      @MichMich I didn’t check, will do when I have time somewhere later today.
      If there is anything don’t hesitate to contact me!
      ProfileSwitcher, TouchNotifications
      • yawnsY
        yawns Moderator @tosti007
        @tosti007 said in Something I’m working on ...:
        I cannot upload any modules at all, either with pc (windows, firefox) or android (chrome). Is this currently supposed to be like that (aka disabled) or am i doing something wrong? :) I am on the correct github account and the repositories are public.
        I just tried as well. You can click “Step 1 - Select repository” but nothing happens. The console is showing a HTTP500 error:
        vue.js?3de6:5729 Download the Vue Devtools for a better development experience:
        https://github.com/vuejs/vue-devtools
        vue-resource.common.js?2f13:1071 GET http://beta.magicmirror.builders/api/me/repositories 500 (Internal Server Error)
        (anonymous) @ vue-resource.common.js?2f13:1071
        PromiseObj @ vue-resource.common.js?2f13:198
        xhrClient @ vue-resource.common.js?2f13:1025
        sendRequest @ vue-resource.common.js?2f13:1140
        exec @ vue-resource.common.js?2f13:1097
        next @ vue-resource.common.js?2f13:1122
        before @ vue-resource.common.js?2f13:966
        timeout @ vue-resource.common.js?2f13:1014
        method @ vue-resource.common.js?2f13:980
        body @ vue-resource.common.js?2f13:853
        jsonp @ vue-resource.common.js?2f13:942
        header @ vue-resource.common.js?2f13:997
        cors @ vue-resource.common.js?2f13:824
        (anonymous) @ bootstrap.js?5e63:36
        (anonymous) @ vue-resource.common.js?2f13:1125
        Client @ vue-resource.common.js?2f13:1090
        Http @ vue-resource.common.js?2f13:1350
        Http.(anonymous function) @ vue-resource.common.js?2f13:1379
        fetchRepositories @ AddModule.vue?5997:99
        boundFn @ vue.js?3de6:131
        mounted @ AddModule.vue?5997:141
        callHook @ vue.js?3de6:1833
        insert @ vue.js?3de6:2007
        invokeInsertHook @ vue.js?3de6:4159
        patch @ vue.js?3de6:4301
        Vue._update @ vue.js?3de6:1722
        (anonymous) @ vue.js?3de6:1697
        get @ vue.js?3de6:740
        Watcher @ vue.js?3de6:732
        Vue._mount @ vue.js?3de6:1696
        Vue$3.$mount @ vue.js?3de6:5716
        Vue$3.$mount @ vue.js?3de6:7873
        initRender @ vue.js?3de6:2218
        Vue._init @ vue.js?3de6:2580
        Vue$3 @ vue.js?3de6:2624
        (anonymous) @ app.js?8b67:47
        (anonymous) @ app-c86aef609d.js:1578
        __webpack_require__ @ app-c86aef609d.js:20
        (anonymous) @ app-c86aef609d.js:64
        (anonymous) @ app-c86aef609d.js:67
        AddModule.vue?5997:105 Responsebody: "↵↵    ↵        ↵        ↵        ↵    ↵    ↵                    <div>↵                <h1>Whoops, looks like something went wrong.</h1>↵                                        <h2>↵                            1/1↵                            RuntimeException in <a>Client.php line 70</a>:Pipeline.php line 104↵       <li>at Pipeline->then(<em>object</em>(Closure)) in <a>Router.php line 644</a></li>↵       <li>at Router->runRouteWithinStack(<em>object</em>(Route), <em>object</em>(Request)) in <a>Router.php line 618</a></li>↵       <li>at Router->dispatchToRoute(<em>object</em>(Request)) in <a>Router.php line 596</a></li>↵       <li>at Router->dispatch(<em>object</em>(Request)) in <a>Kernel.php line 267</a></li>↵       <li>at Kernel->Illuminate\Foundation\Http\{closure}(<em>object</em>(Request)) in <a>Pipeline.php line 53</a></li>↵       <li>at Pipeline->Illuminate\Routing\{closure}(<em>object</em>(Request)) in <a>CheckForMaintenanceMode.php line 46</a></li>↵       <li>at CheckForMaintenanceMode->handle(<em>object</em>(Request), <em>object</em>(Closure)) in <a>Pipeline.php line 137</a></li>↵       <li>at Pipeline->Illuminate\Pipeline\{closure}(<em>object</em>(Request)) in <a>Pipeline.php line 33</a></li>↵       <li>at Pipeline->Illuminate\Routing\{closure}(<em>object</em>(Request)) in <a>Pipeline.php line 104</a></li>↵       <li>at Pipeline->then(<em>object</em>(Closure)) in <a>Kernel.php line 149</a></li>↵       <li>at Kernel->sendRequestThroughRouter(<em>object</em>(Request)) in <a>Kernel.php line 116</a></li>↵       <li>at Kernel->handle(<em>object</em>(Request)) in <a>index.php line 53</a></li>↵    ↵</h2></div>↵↵            ↵    ↵"bodyBlob: BlobbodyText: PromiseObjdata: (...)get data: ()arguments: (...)caller: (...)length: 0name: "get"prototype: Object__proto__: ()[[FunctionLocation]]: vue-resource.common.js?2f13:856[[Scopes]]: Scopes[4]set data: (body)arguments: (...)caller: (...)length: 1name: "set"prototype: Object__proto__: ()[[FunctionLocation]]: vue-resource.common.js?2f13:859[[Scopes]]: Scopes[4]headers: Headersmap: Object__proto__: Objectok: falsestatus: 500statusText: "Internal Server Error"url: "/api/me/repositories"__proto__: Object
        (anonymous) @ AddModule.vue?5997:105
        tosti007T 1 Reply Last reply
        • MichMichM
          MichMich
          It seems the php-curl module was missing. Could you give it an other try. If it doesn’t work, I need to dive into it.
          yawnsY 1 Reply Last reply
          • yawnsY
            yawns Moderator @MichMich
            Okay, I was able to add my module right now. However now it says it cannot find the readme. This affects all modules, not only mine.
            MichMichM 1 Reply Last reply
            • MichMichM
              MichMich @yawns
              @yawns Should be fixed now.
              • yawnsY
                yes indeed. Thanks @MichMich
                • tosti007T
                  tosti007 Module Developer @yawns
                  @yawns thank you for checking the log for me, @MichMich thanks for fixing the readme bug. I will try and upload my modules later.
                  • tosti007T
                    Well it seems I broke stuff, this time with the picture of my uploaded module. It doesn’t display it and when you to to the actual file it gives a NotSupportedException or this one :) My original picture has a size of 558 x 173 (not sure if this is important in any way).
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @tosti007
                      @tosti007 did you probably upload an exotic file extension?
                      • MichMichM
                        MichMich
                        Hmm… need to look into this. Will do this later. Thanks for testing.
                        • tosti007T
                          tosti007 Module Developer @strawberry 3.141
                          @strawberry-3.141 Nop, tried both png and jpg to no avail
                          • tosti007T
                            @MichMich You’re welcome. I will leave the picture on it for now so you can look into it.
