    Something I'm working on ...
    Scheduled Pinned Locked Moved Announcements
    39 Posts 12 Posters 43.3k Views 12 Watching
    • MichMichM Offline
      MichMich @tosti007
      @tosti007 Doe you notice some particular error in the browser’s console?
      tosti007T 1 Reply Last reply Reply Quote 0
      • tosti007T Offline
        tosti007 Module Developer @MichMich
        @MichMich I didn’t check, will do when I have time somewhere later today.
        If there is anything don't hesitate to contact me!
        ProfileSwitcher, TouchNotifications
        • yawnsY Offline
          yawns Moderator @tosti007
          @tosti007 said in Something I’m working on ...:
          I cannot upload any modules at all, either with pc (windows, firefox) or android (chrome). Is this currently supposed to be like that (aka disabled) or am i doing something wrong? :) I am on the correct github account and the repositories are public.
          I just tried as well. You can click “Step 1 - Select repository” but nothing happens. The console is showing a HTTP500 error:
          vue.js?3de6:5729 Download the Vue Devtools for a better development experience:
          https://github.com/vuejs/vue-devtools
          vue-resource.common.js?2f13:1071 GET http://beta.magicmirror.builders/api/me/repositories 500 (Internal Server Error)
          (anonymous) @ vue-resource.common.js?2f13:1071
          PromiseObj @ vue-resource.common.js?2f13:198
          xhrClient @ vue-resource.common.js?2f13:1025
          sendRequest @ vue-resource.common.js?2f13:1140
          exec @ vue-resource.common.js?2f13:1097
          next @ vue-resource.common.js?2f13:1122
          before @ vue-resource.common.js?2f13:966
          timeout @ vue-resource.common.js?2f13:1014
          method @ vue-resource.common.js?2f13:980
          body @ vue-resource.common.js?2f13:853
          jsonp @ vue-resource.common.js?2f13:942
          header @ vue-resource.common.js?2f13:997
          cors @ vue-resource.common.js?2f13:824
          (anonymous) @ bootstrap.js?5e63:36
          (anonymous) @ vue-resource.common.js?2f13:1125
          Client @ vue-resource.common.js?2f13:1090
          Http @ vue-resource.common.js?2f13:1350
          Http.(anonymous function) @ vue-resource.common.js?2f13:1379
          fetchRepositories @ AddModule.vue?5997:99
          boundFn @ vue.js?3de6:131
          mounted @ AddModule.vue?5997:141
          callHook @ vue.js?3de6:1833
          insert @ vue.js?3de6:2007
          invokeInsertHook @ vue.js?3de6:4159
          patch @ vue.js?3de6:4301
          Vue._update @ vue.js?3de6:1722
          (anonymous) @ vue.js?3de6:1697
          get @ vue.js?3de6:740
          Watcher @ vue.js?3de6:732
          Vue._mount @ vue.js?3de6:1696
          Vue$3.$mount @ vue.js?3de6:5716
          Vue$3.$mount @ vue.js?3de6:7873
          initRender @ vue.js?3de6:2218
          Vue._init @ vue.js?3de6:2580
          Vue$3 @ vue.js?3de6:2624
          (anonymous) @ app.js?8b67:47
          (anonymous) @ app-c86aef609d.js:1578
          __webpack_require__ @ app-c86aef609d.js:20
          (anonymous) @ app-c86aef609d.js:64
          (anonymous) @ app-c86aef609d.js:67
          AddModule.vue?5997:105 Responsebody: "↵↵    ↵        ↵        ↵        ↵    ↵    ↵                    <div>↵                <h1>Whoops, looks like something went wrong.</h1>↵                                        <h2>↵                            1/1↵                            RuntimeException in <a>Client.php line 70</a>:Pipeline.php line 104↵       <li>at Pipeline->then(<em>object</em>(Closure)) in <a>Router.php line 644</a></li>↵       <li>at Router->runRouteWithinStack(<em>object</em>(Route), <em>object</em>(Request)) in <a>Router.php line 618</a></li>↵       <li>at Router->dispatchToRoute(<em>object</em>(Request)) in <a>Router.php line 596</a></li>↵       <li>at Router->dispatch(<em>object</em>(Request)) in <a>Kernel.php line 267</a></li>↵       <li>at Kernel->Illuminate\Foundation\Http\{closure}(<em>object</em>(Request)) in <a>Pipeline.php line 53</a></li>↵       <li>at Pipeline->Illuminate\Routing\{closure}(<em>object</em>(Request)) in <a>CheckForMaintenanceMode.php line 46</a></li>↵       <li>at CheckForMaintenanceMode->handle(<em>object</em>(Request), <em>object</em>(Closure)) in <a>Pipeline.php line 137</a></li>↵       <li>at Pipeline->Illuminate\Pipeline\{closure}(<em>object</em>(Request)) in <a>Pipeline.php line 33</a></li>↵       <li>at Pipeline->Illuminate\Routing\{closure}(<em>object</em>(Request)) in <a>Pipeline.php line 104</a></li>↵       <li>at Pipeline->then(<em>object</em>(Closure)) in <a>Kernel.php line 149</a></li>↵       <li>at Kernel->sendRequestThroughRouter(<em>object</em>(Request)) in <a>Kernel.php line 116</a></li>↵       <li>at Kernel->handle(<em>object</em>(Request)) in <a>index.php line 53</a></li>↵    ↵</h2></div>↵↵            ↵    ↵"bodyBlob: BlobbodyText: PromiseObjdata: (...)get data: ()arguments: (...)caller: (...)length: 0name: "get"prototype: Object__proto__: ()[[FunctionLocation]]: vue-resource.common.js?2f13:856[[Scopes]]: Scopes[4]set data: (body)arguments: (...)caller: (...)length: 1name: "set"prototype: Object__proto__: ()[[FunctionLocation]]: vue-resource.common.js?2f13:859[[Scopes]]: Scopes[4]headers: Headersmap: Object__proto__: Objectok: falsestatus: 500statusText: "Internal Server Error"url: "/api/me/repositories"__proto__: Object
          (anonymous) @ AddModule.vue?5997:105
          • MichMichM Offline
            MichMich
            It seems the php-curl module was missing. Could you give it an other try. If it doesn’t work, I need to dive into it.
            • yawnsY Offline
              yawns Moderator @MichMich
              Okay, I was able to add my module right now. However now it says it cannot find the readme. This affects all modules, not only mine.
              MichMichM 1 Reply Last reply Reply Quote 0
              • MichMichM Offline
                MichMich @yawns
                @yawns Should be fixed now.
                • yawnsY Offline
                  yes indeed. Thanks @MichMich
                  • tosti007T Offline
                    tosti007 Module Developer @yawns
                    @yawns thank you for checking the log for me, @MichMich thanks for fixing the readme bug. I will try and upload my modules later.
                    • tosti007T Offline
                      Well it seems I broke stuff, this time with the picture of my uploaded module. It doesn’t display it and when you to to the actual file it gives a NotSupportedException or this one :) My original picture has a size of 558 x 173 (not sure if this is important in any way).
                      • strawberry 3.141S Offline
                        strawberry 3.141 Project Sponsor Module Developer @tosti007
                        @tosti007 did you probably upload an exotic file extension?
                        • MichMichM Offline
                          MichMich
                          Hmm… need to look into this. Will do this later. Thanks for testing.
                          • tosti007T Offline
                            tosti007 Module Developer @strawberry 3.141
                            @strawberry-3.141 Nop, tried both png and jpg to no avail
                            • tosti007T Offline
                              @MichMich You’re welcome. I will leave the picture on it for now so you can look into it.
