    Something I'm working on ...
    Scheduled Pinned Locked Moved Announcements
    39 Posts 12 Posters 53.5k Views 12 Watching
      chrisfoerg
      It is only an idea. In Wordpress the themes have all the same style at the beginning in the css file for the declaration of the theme:
      Theme Name: Tutorial
      Theme URI: http://wordpress.lernenhoch2.de
      Description: Template zum WordPress Tutorial auf http://wordpress.lernenhoch2.de
      Author: Christian Strang
      Author URI: http://lernenhoch2.de
      https://codex.wordpress.org/Theme_Development#Theme_Stylesheet
      maybe it is something for you to use?
      • MichMichM
        MichMich @LukeCodewalker
        @LukeCodewalker It seems the html is malformed and thus the markdown parser in unable to parse it correctly. It looks like the table contains white lines which are not allowed. If you run your markdown thru a markdown linter, you’ll see there is an issue with the markdown of that readme file.
        CatoC 1 Reply Last reply
        • CatoC
          Cato Module Developer @MichMich
          @MichMich I guess both @LukeCodewalker and me have the same issue. I’ve included my markdown below and as far as I can see there should be no issue with it. The only thing might be the inclusion of
          tags for new line.
          Configuration option | Comment | Default
          url | Video Streaming URL.<br><br>You find it in <i>Motion Eye</i> in the <i>Video Streaming Section</i> under <i>Usefull URLs</i> by by clicking the <i>Streaming URL</i> link.<br><br>It should look something like this: `http://motioneye:8081` (probably an IP instead of hostname) | No default
          autoHide | If you want the camera to only be visible on the mirror when there is motion, set this to true. You will then have to enable "Call a Web Hook" in Motion Eye under the Motion Notifications section: <br><br> - Web Hook URL: <b>[http://URL of your mirror]/motioneye</b>. Example: http://192.168.1.11:8080/motioneye<br> - HTTP Method: <b>GET</b><br><br>Remember to update IP white list to enable access from your Motion Eye box.|false
          autoHideDelay|If autoHide is enabled you can decide how long to wait before hiding the camera|60000 (60 seconds)
          width|Width of camera image. You have to try out what fits YOUR monitor | 400px
          debug|Show messages in the log|false
          MichMichM 1 Reply Last reply
          • MichMichM
            MichMich @Cato
            @Cato That’s correct. You’re mixing html and markdown. Which is not supported within a markdown table. The markdown parser is very strict about this due to security reasons. (We want to prevent code injection via a readme file at all costs.)
            I just use the parser used/developed by/for https://www.npmjs.com, so this is not something I can change.
            • CatoC
              @MichMich Are you sure about that?
              I thought InLine HTML was perfectly allowed. See:
              • https://daringfireball.net/projects/markdown/syntax#html
              • https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet#html
              • MichMichM
                MichMich @Cato
                @Cato Yes, it’s allowed, but not within a markdown table.
                • CatoC
                  Ok, I’ll reformat my documentation when I get time.
                  I found this nice tool: https://dlaa.me/markdownlint/ for checking syntax.
                  • paphkoP
                    paphko
                    Nice step, a dedicated module database :-)
                    However, via chrome for Android, I am not able to upload an image for my module…
                      roramirez Core Contributors @MichMich
                      @MichMich From some days I’ve been working in design and little code about mention before.
                      I hope soon release something can be stable. At today is state alfa state and not working.
                      I send the URL of project if someone is interested
                      https://github.com/roramirez/MagicMirror-Module-Manager
                        bmarofsky @MichMich
                        @MichMich It would be good to require screenshots. Other wise its a good start.
                        • tosti007T
                          tosti007 Module Developer
                          I cannot upload any modules at all, either with pc (windows, firefox) or android (chrome). Is this currently supposed to be like that (aka disabled) or am i doing something wrong? :) I am on the correct github account and the repositories are public.
                          If there is anything don’t hesitate to contact me!
                          ProfileSwitcher, TouchNotifications
                          MichMichM yawnsY 2 Replies Last reply
                          • MichMichM
                            MichMich @bmarofsky
                            @bmarofsky Not all modules have visuals. Some just work in the background.
                            • MichMichM
                              MichMich @tosti007
                              @tosti007 Doe you notice some particular error in the browser’s console?
                              tosti007T 1 Reply Last reply
                              • tosti007T
                                tosti007 Module Developer @MichMich
                                @MichMich I didn’t check, will do when I have time somewhere later today.
                                • yawnsY
                                  yawns Moderator @tosti007
                                  @tosti007 said in Something I’m working on ...:
                                  I just tried as well. You can click “Step 1 - Select repository” but nothing happens. The console is showing a HTTP500 error:
                                  vue.js?3de6:5729 Download the Vue Devtools for a better development experience:
                                  https://github.com/vuejs/vue-devtools
                                  vue-resource.common.js?2f13:1071 GET http://beta.magicmirror.builders/api/me/repositories 500 (Internal Server Error)
                                  (anonymous) @ vue-resource.common.js?2f13:1071
                                  PromiseObj @ vue-resource.common.js?2f13:198
                                  xhrClient @ vue-resource.common.js?2f13:1025
                                  sendRequest @ vue-resource.common.js?2f13:1140
                                  exec @ vue-resource.common.js?2f13:1097
                                  next @ vue-resource.common.js?2f13:1122
                                  before @ vue-resource.common.js?2f13:966
                                  timeout @ vue-resource.common.js?2f13:1014
                                  method @ vue-resource.common.js?2f13:980
                                  body @ vue-resource.common.js?2f13:853
                                  jsonp @ vue-resource.common.js?2f13:942
                                  header @ vue-resource.common.js?2f13:997
                                  cors @ vue-resource.common.js?2f13:824
                                  (anonymous) @ bootstrap.js?5e63:36
                                  (anonymous) @ vue-resource.common.js?2f13:1125
                                  Client @ vue-resource.common.js?2f13:1090
                                  Http @ vue-resource.common.js?2f13:1350
                                  Http.(anonymous function) @ vue-resource.common.js?2f13:1379
                                  fetchRepositories @ AddModule.vue?5997:99
                                  boundFn @ vue.js?3de6:131
                                  mounted @ AddModule.vue?5997:141
                                  callHook @ vue.js?3de6:1833
                                  insert @ vue.js?3de6:2007
                                  invokeInsertHook @ vue.js?3de6:4159
                                  patch @ vue.js?3de6:4301
                                  Vue._update @ vue.js?3de6:1722
                                  (anonymous) @ vue.js?3de6:1697
                                  get @ vue.js?3de6:740
                                  Watcher @ vue.js?3de6:732
                                  Vue._mount @ vue.js?3de6:1696
                                  Vue$3.$mount @ vue.js?3de6:5716
                                  Vue$3.$mount @ vue.js?3de6:7873
                                  initRender @ vue.js?3de6:2218
                                  Vue._init @ vue.js?3de6:2580
                                  Vue$3 @ vue.js?3de6:2624
                                  (anonymous) @ app.js?8b67:47
                                  (anonymous) @ app-c86aef609d.js:1578
                                  __webpack_require__ @ app-c86aef609d.js:20
                                  (anonymous) @ app-c86aef609d.js:64
                                  (anonymous) @ app-c86aef609d.js:67
                                  AddModule.vue?5997:105 Responsebody: "↵↵    ↵        ↵        ↵        ↵    ↵    ↵                    <div>↵                <h1>Whoops, looks like something went wrong.</h1>↵                                        <h2>↵                            1/1↵                            RuntimeException in <a>Client.php line 70</a>:Pipeline.php line 104↵       <li>at Pipeline->then(<em>object</em>(Closure)) in <a>Router.php line 644</a></li>↵       <li>at Router->runRouteWithinStack(<em>object</em>(Route), <em>object</em>(Request)) in <a>Router.php line 618</a></li>↵       <li>at Router->dispatchToRoute(<em>object</em>(Request)) in <a>Router.php line 596</a></li>↵       <li>at Router->dispatch(<em>object</em>(Request)) in <a>Kernel.php line 267</a></li>↵       <li>at Kernel->Illuminate\Foundation\Http\{closure}(<em>object</em>(Request)) in <a>Pipeline.php line 53</a></li>↵       <li>at Pipeline->Illuminate\Routing\{closure}(<em>object</em>(Request)) in <a>CheckForMaintenanceMode.php line 46</a></li>↵       <li>at CheckForMaintenanceMode->handle(<em>object</em>(Request), <em>object</em>(Closure)) in <a>Pipeline.php line 137</a></li>↵       <li>at Pipeline->Illuminate\Pipeline\{closure}(<em>object</em>(Request)) in <a>Pipeline.php line 33</a></li>↵       <li>at Pipeline->Illuminate\Routing\{closure}(<em>object</em>(Request)) in <a>Pipeline.php line 104</a></li>↵       <li>at Pipeline->then(<em>object</em>(Closure)) in <a>Kernel.php line 149</a></li>↵       <li>at Kernel->sendRequestThroughRouter(<em>object</em>(Request)) in <a>Kernel.php line 116</a></li>↵       <li>at Kernel->handle(<em>object</em>(Request)) in <a>index.php line 53</a></li>↵    ↵</h2></div>↵↵            ↵    ↵"bodyBlob: BlobbodyText: PromiseObjdata: (...)get data: ()arguments: (...)caller: (...)length: 0name: "get"prototype: Object__proto__: ()[[FunctionLocation]]: vue-resource.common.js?2f13:856[[Scopes]]: Scopes[4]set data: (body)arguments: (...)caller: (...)length: 1name: "set"prototype: Object__proto__: ()[[FunctionLocation]]: vue-resource.common.js?2f13:859[[Scopes]]: Scopes[4]headers: Headersmap: Object__proto__: Objectok: falsestatus: 500statusText: "Internal Server Error"url: "/api/me/repositories"__proto__: Object
                                  (anonymous) @ AddModule.vue?5997:105
                                  • MichMichM
                                    MichMich
                                    It seems the php-curl module was missing. Could you give it an other try. If it doesn’t work, I need to dive into it.
                                    yawnsY 1 Reply Last reply
                                    • yawnsY
                                      yawns Moderator @MichMich
                                      Okay, I was able to add my module right now. However now it says it cannot find the readme. This affects all modules, not only mine.
                                      • MichMichM
                                        MichMich @yawns
                                        @yawns Should be fixed now.
                                        • yawnsY
                                          yes indeed. Thanks @MichMich
                                          • tosti007T
                                            tosti007 Module Developer @yawns
                                            @yawns thank you for checking the log for me, @MichMich thanks for fixing the readme bug. I will try and upload my modules later.
