    Something I'm working on ...
    Scheduled Pinned Locked Moved Announcements
    39 Posts 12 Posters 52.0k Views 12 Watching
      roramirez Core Contributors
      Its great. With this, I was thinking is possible create a installer system, its somethings i was thinking from time ago.
      Using the API and the parameters of configuration per every module its possible create the section of module for add into the config.js
      • MichMichM Offline
        MichMich
        By the way, this project is in a horrible raw early alpha stage … buttt, if someone is interested to contribute, the source code is available here: https://github.com/MichMich/MagicMirror-Website/tree/develop
        Be advised: the code needs a lot of refactoring and misses a lot of commenting.
        The frontend is a SPA based on Vue.js and a bit of Vuex. The Backend/Api is based on Laravel.
        If you clone the repo, take the following steps to get it up and running:
        • Run: composer install
        • Run npm install
        • Create an environment configuration: cp .env.example .env
        • Run php artisan key:generate`
        • Modify the database and github settings in the .env file. (You need to create a github app for testing.)
        • Run php artisan migrate --seed to setup the database.
        If you make any changes to /resources/assets/js or /resources/assets/sass, make sure to run gulp to compile.
          Jopyth Moderator @roramirez
          @roramirez Installer system is a great idea, however this is something that @strawberry-3-141 will implement as a mobile app, from what I hear plus I am building something like this into my remote control (a website - currently on the develop branch). So maybe have a look at it, before you start something completely new. Although, if there is a good reason for building this again or in a different way, count me in.
          • Y Offline
            yawns Moderator
            Very nice, MichMich. I like the integration with github pulling almost all data and as such removing the need to enter description and all that over and over again. I added my modules
              Thanks @MichMich the information. I will take a look of code :)
              Hi @Jopyth , do you know where I can find some code or design about the @strawberry-3-141 app?
              I think we can bootstrap a app for install apps (modules) into a MagicMirror with API provider by modules section of web. The idea it’s most like a packages manager + configuration.
              • MichMichM Offline
                MichMich
                If you work on such an installer. Make sure it’s based on the module infrastructure where possible. That we you can develop and test is, without the need of directly integrating it in mm2. If It’s fully up and running and tested, we can integrate it by adding it to the list of default modules.
                  Cato Module Developer
                  @MichMich I noticed that format of table markdown is not optimal. The rows should be alternating color. A good example that current format is bad is here: http://beta.magicmirror.builders/module/29/motioneye. Notice that it’s difficult to see what configuration value belongs to which description…
                  • L Offline
                    LukeCodewalker Module Developer
                    Hey,
                    another problem with tables:
                    if you use html-tables in your GitHub README.md it’s not displayed the right way.
                    Example: http://beta.magicmirror.builders/module/33/soccerlivescore
                    MichMichM 1 Reply Last reply Reply Quote 0
                      chrisfoerg
                      It is only an idea. In Wordpress the themes have all the same style at the beginning in the css file for the declaration of the theme:
                      Theme Name: Tutorial
                      Theme URI: http://wordpress.lernenhoch2.de
                      Description: Template zum WordPress Tutorial auf http://wordpress.lernenhoch2.de
                      Author: Christian Strang
                      Author URI: http://lernenhoch2.de
                      https://codex.wordpress.org/Theme_Development#Theme_Stylesheet
                      maybe it is something for you to use?
                      • MichMichM Offline
                        MichMich @LukeCodewalker
                        @LukeCodewalker It seems the html is malformed and thus the markdown parser in unable to parse it correctly. It looks like the table contains white lines which are not allowed. If you run your markdown thru a markdown linter, you’ll see there is an issue with the markdown of that readme file.
                          Cato Module Developer @MichMich
                          @MichMich I guess both @LukeCodewalker and me have the same issue. I’ve included my markdown below and as far as I can see there should be no issue with it. The only thing might be the inclusion of
                          tags for new line.
                          Configuration option | Comment | Default
                          url | Video Streaming URL.<br><br>You find it in <i>Motion Eye</i> in the <i>Video Streaming Section</i> under <i>Usefull URLs</i> by by clicking the <i>Streaming URL</i> link.<br><br>It should look something like this: `http://motioneye:8081` (probably an IP instead of hostname) | No default
                          autoHide | If you want the camera to only be visible on the mirror when there is motion, set this to true. You will then have to enable "Call a Web Hook" in Motion Eye under the Motion Notifications section: <br><br> - Web Hook URL: <b>[http://URL of your mirror]/motioneye</b>. Example: http://192.168.1.11:8080/motioneye<br> - HTTP Method: <b>GET</b><br><br>Remember to update IP white list to enable access from your Motion Eye box.|false
                          autoHideDelay|If autoHide is enabled you can decide how long to wait before hiding the camera|60000 (60 seconds)
                          width|Width of camera image. You have to try out what fits YOUR monitor | 400px
                          debug|Show messages in the log|false
                          • MichMichM Offline
                            MichMich @Cato
                            @Cato That’s correct. You’re mixing html and markdown. Which is not supported within a markdown table. The markdown parser is very strict about this due to security reasons. (We want to prevent code injection via a readme file at all costs.)
                            I just use the parser used/developed by/for https://www.npmjs.com, so this is not something I can change.
                              @MichMich Are you sure about that?
                              I thought InLine HTML was perfectly allowed. See:
                              • https://daringfireball.net/projects/markdown/syntax#html
                              • https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet#html
                              • MichMichM Offline
                                MichMich @Cato
                                @Cato Yes, it’s allowed, but not within a markdown table.
                                  Ok, I’ll reformat my documentation when I get time.
                                  I found this nice tool: https://dlaa.me/markdownlint/ for checking syntax.
                                    paphko
                                    Nice step, a dedicated module database :-)
                                    However, via chrome for Android, I am not able to upload an image for my module…
                                      roramirez Core Contributors @MichMich
                                      @MichMich From some days I’ve been working in design and little code about mention before.
                                      I hope soon release something can be stable. At today is state alfa state and not working.
                                      I send the URL of project if someone is interested
                                      https://github.com/roramirez/MagicMirror-Module-Manager
                                        bmarofsky @MichMich
                                        @MichMich It would be good to require screenshots. Other wise its a good start.
                                        • T Offline
                                          tosti007 Module Developer
                                          I cannot upload any modules at all, either with pc (windows, firefox) or android (chrome). Is this currently supposed to be like that (aka disabled) or am i doing something wrong? :) I am on the correct github account and the repositories are public.
                                          If there is anything don’t hesitate to contact me!
                                          ProfileSwitcher, TouchNotifications
                                          MichMichM Y 2 Replies Last reply Reply Quote 0
                                          • MichMichM Offline
                                            MichMich @bmarofsky
                                            @bmarofsky Not all modules have visuals. Some just work in the background.
