    [MMM-OnThisDayWikiApi] - Get Wikipedia's OnThisDay using the Wikimedia API
    Scheduled Pinned Locked Moved Showcase
    17 Posts 7 Posters 8.8k Views 7 Watching
    • BerkSmash1984B
      BerkSmash1984 @slugmuffin
      @slugmuffin
      Just installed the module on my MM and it is working great. Thanks for this! The only thing that could be tweaked is, if using the bottom bar position, it will not be centered, but shifted to the left. Thus, I had to use the bottom center position.
        slugmuffin @BerkSmash1984
        @BerkSmash1984
        Is that happening as a list or as the single item view?
        BerkSmash1984B 1 Reply Last reply
        • BerkSmash1984B
          @slugmuffin
          Default config, using single item view.
            @BerkSmash1984 - Interesting, that’s the same configuration and position I’m using. Do you have any custom css or other modules that may be affecting it?
            • BerkSmash1984B
              @slugmuffin
              I am using MMM-pages. Nothing in custom css created for this module specifically
              • A
                angeliKITTYx
                I’m getting an error message. Is this something that will fix itself?
                KristjanESPERANTOK 1 Reply Last reply
                • KristjanESPERANTOK
                  KristjanESPERANTO Module Developer @angeliKITTYx
                  @angeliKITTYx The module works fine for me. Error code 500 indicates an error on the API. You can’t do anything about that. Do you use the latest version of the module? There was an update two weeks ago.
                  A 1 Reply Last reply
                  • A
                    angeliKITTYx @KristjanESPERANTO
                    @KristjanESPERANTO i just reinstalled it and I’m getting the same error
                      @angeliKITTYx Please show us your config of the module.
                      • A
                        @KristjanESPERANTO
                        			module: "MMM-OnThisDayWikiApi",
                        			position: "bottom_bar",
                        				type: "all",
                          @angeliKITTYx Okay, with type: "all"' it doesn’t work for me either. Try it with type: "selcted". That works for me.
                          			type: "selected"
                          • A
                            angeliKITTYx
                            Is there any way to make the font bigger? It looks so tiny compared to the rest of my display
                              sdetweil @angeliKITTYx
                              @angeliKITTYx as always, if it’s not in the module instructions , then you have to use css to adjust the styles.
                              sometimes the module author provides an initial css file you can copy from to custom.css to make those adjustments.
                              • I
                                imdickie
                                The title seems to ignore the forced maxWidth. Is there any way to force the title to align to the body?MMM-OnThisDay.png
                                G 1 Reply Last reply
                                • G
                                  greedyvegan @imdickie
                                  @imdickie said
                                  The title seems to ignore the forced maxWidth. Is there any way to force the title to align to the body?!
                                  I’ve had this issue before
                                  try the developer view in a browser to see your options
                                  the default settings doesn’t prohibit you
                                  .MMM-OnThisDayWikiApi
                                  {max-width:100vh;height:auto;max-height:auto;line-height:1em;}
                                  .MMM-OnThisDayWikiApi .title
                                  {text-align:justify;margin-bottom:0.5em;text-transform:uppercase;}
                                  .MMM-OnThisDayWikiApi-single .title
                                  {text-align: center; text-transform: capitalize;}
                                  .MMM-OnThisDayWikiApi ul
                                  {padding: 0; margin-top: 0.5em;}
                                  .MMM-OnThisDayWikiApi-list
                                  {list-style: none; padding: 0;}
                                  .MMM-OnThisDayWikiApi-list li
                                  { text-align: justify; margin-bottom: 0.5em;}
                                  post your custom.css to assist you further
                                  I 1 Reply Last reply
                                  • bugsounetB bugsounet referenced this topic on
                                  • I
                                    imdickie @greedyvegan
                                    @greedyvegan said in [MMM-OnThisDayWikiApi] - Get Wikipedia's OnThisDay using the Wikimedia API:
                                    It didn’t accomplish what I wanted, but I can see you did send me down the right path. I’ll do some investigating some Custom CSS statements.
                                    Thanks.
