    [MMM-OnThisDayWikiApi] - Get Wikipedia's OnThisDay using the Wikimedia API
    Scheduled Pinned Locked Moved Showcase
    17 Posts 7 Posters 8.5k Views 7 Watching
    • BerkSmash1984B
      BerkSmash1984 @slugmuffin
      @slugmuffin
      I am using MMM-pages. Nothing in custom css created for this module specifically
      • A
        angeliKITTYx
        I’m getting an error message. Is this something that will fix itself?
        • KristjanESPERANTOK
          KristjanESPERANTO Module Developer @angeliKITTYx
          @angeliKITTYx The module works fine for me. Error code 500 indicates an error on the API. You can’t do anything about that. Do you use the latest version of the module? There was an update two weeks ago.
          • A
            angeliKITTYx @KristjanESPERANTO
            @KristjanESPERANTO i just reinstalled it and I’m getting the same error
              @angeliKITTYx Please show us your config of the module.
              • A
                @KristjanESPERANTO
                			module: "MMM-OnThisDayWikiApi",
                			position: "bottom_bar",
                				type: "all",
                  @angeliKITTYx Okay, with type: "all"' it doesn’t work for me either. Try it with type: "selcted". That works for me.
                  			type: "selected"
                  • A
                    angeliKITTYx
                    Is there any way to make the font bigger? It looks so tiny compared to the rest of my display
                      sdetweil @angeliKITTYx
                      @angeliKITTYx as always, if it’s not in the module instructions , then you have to use css to adjust the styles.
                      sometimes the module author provides an initial css file you can copy from to custom.css to make those adjustments.
                      • I
                        imdickie
                        The title seems to ignore the forced maxWidth. Is there any way to force the title to align to the body?MMM-OnThisDay.png
                        • G
                          greedyvegan @imdickie
                          @imdickie said
                          The title seems to ignore the forced maxWidth. Is there any way to force the title to align to the body?!
                          I’ve had this issue before
                          try the developer view in a browser to see your options
                          the default settings doesn’t prohibit you
                          .MMM-OnThisDayWikiApi
                          {max-width:100vh;height:auto;max-height:auto;line-height:1em;}
                          .MMM-OnThisDayWikiApi .title
                          {text-align:justify;margin-bottom:0.5em;text-transform:uppercase;}
                          .MMM-OnThisDayWikiApi-single .title
                          {text-align: center; text-transform: capitalize;}
                          .MMM-OnThisDayWikiApi ul
                          {padding: 0; margin-top: 0.5em;}
                          .MMM-OnThisDayWikiApi-list
                          {list-style: none; padding: 0;}
                          .MMM-OnThisDayWikiApi-list li
                          { text-align: justify; margin-bottom: 0.5em;}
                          post your custom.css to assist you further
                          • bugsounetB bugsounet referenced this topic on
                          • I
                            imdickie @greedyvegan
                            @greedyvegan said in [MMM-OnThisDayWikiApi] - Get Wikipedia's OnThisDay using the Wikimedia API:
                            It didn’t accomplish what I wanted, but I can see you did send me down the right path. I’ll do some investigating some Custom CSS statements.
                            Thanks.
