    Internet-monitor module Not Starting Mirror
    13 Posts 3 Posters 3.6k Views 3 Watching
    • E Offline
      ebourne
      I have reinstall the internet-monitor module multiple times and I am pretty sure i have done it right. I even use the config from github page. the problem i am seeing is that with the module in, it does not start my mirror. no black screen, no error, it just does not start?
      restarting stopping and starting the pm2 or just rebooting the PI doesn’t do anything either
      has anyone else seen that happen? for any modules even?
      • KristjanESPERANTOK Online
        KristjanESPERANTO Module Developer @KristjanESPERANTO
        @KristjanESPERANTO said in Internet-monitor module Not Starting Mirror:
        I also happened to be working on the problem just now. The speedtest-net package is apparently no longer compatible with the current node version. I created a PR to fix this: https://github.com/BrianHepler/internet-monitor/pull/2
        Let’s see when @bhepler merge it.
        @ebourne The maintainer of the module, @bhepler, accepted my Pull Request. Please update your module and check if it’s working 🙂
          sdetweil @ebourne
          @ebourne please show the messages at mm startup, where you do npm start
          • E Offline
            ebourne @sdetweil
            @sdetweil That is the weird thing. the start up message is completely normal
            once i comment out the config for internet-monitor and run pm2 restart mm.sh i get the same message
              sdetweil @ebourne
              @ebourne thats not the startup messages
              do this is the module enabled in config.js
              pm2 stop all
              npm start
              that will display the errors
              pm2 start mm
              to restart thru pm2
              E 1 Reply Last reply Reply Quote 1
              • E Offline
                ebourne @sdetweil
                oh i see. it seems it says it can’t find a folder, and that makes me confused since i did clone and npm installed in the internet-monitor folder. i thought that was all there was
                  sdetweil @ebourne
                  @ebourne which authors module are you using
                  show
                  git remote -v
                  E KristjanESPERANTOK 2 Replies Last reply Reply Quote 1
                  • E Offline
                    ebourne @sdetweil
                    @sdetweil brianhepler
                      S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                        sdetweil @KristjanESPERANTO
                        @KristjanESPERANTO not node version, electron version
                        so, the steps to fix I think (tested, failed before, doesn’t fail now)
                        #!/bin/bash
                        # this tool should be installed in MM
                        if [ ! -e node_modules/.bin/electron-rebuild ]; then
                            npm install electron/rebuild
                        fi
                        cd modules/internet-monitor
                        ../../node_modules/.bin/electron-rebuild
                        this should be a postinstall step in the package.json
                        this is the tested postinstall
                        and works…
                        and the fixed package.json
                          "name": "internet-speed",
                          "version": "1.0.0",
                          "description": "Displays ping, download and upload speed on your smart mirror.",
                          "main": "index.js",
                          "scripts": {
                            "test": "echo \"Error: no test specified\" && exit 1",
                            "postinstall":"./postinstall"
                          "keywords": [
                            "internet",
                            "speed"
                          "author": "Debayan Deb",
                          "license": "MIT",
                          "dependencies": {
                            "justgage": "^1.3.5",
                            "round-to": "^1.1.0",
                            "speedtest-net": "^2.2.0",
                            "raphael": "^2.2.8"
                        have to make postinstall executable
                        chmod +x postinstall
                          @sdetweil Interesting solution! I’m still not quite getting to grips with the rebuild of electron.
                          My approach in the PR is to use a version of speedtest-net that is compatible with the current version. That way, no rebuild is necessary.
                            @KristjanESPERANTO its not a rebuild of electron … its rebuilding binaries for the current electron version
                              • E Offline
                                ebourne @KristjanESPERANTO
                                @KristjanESPERANTO just wanna say thanks
                                it works
