    Internet-monitor module Not Starting Mirror
    13 Posts 3 Posters 2.8k Views 3 Watching
      sdetweil @ebourne
      @ebourne which authors module are you using
      show
      git remote -v
      E KristjanESPERANTOK 2 Replies Last reply Reply Quote 1
      • E Offline
        ebourne @sdetweil
        @sdetweil brianhepler
        • KristjanESPERANTOK Offline
          I also happened to be working on the problem just now. The speedtest-net package is apparently no longer compatible with the current node version. I created a PR to fix this: https://github.com/BrianHepler/internet-monitor/pull/2
          Let’s see when @bhepler merge it.
          S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
            sdetweil @KristjanESPERANTO
            @KristjanESPERANTO not node version, electron version
            so, the steps to fix I think (tested, failed before, doesn’t fail now)
            #!/bin/bash
            # this tool should be installed in MM
            if [ ! -e node_modules/.bin/electron-rebuild ]; then
                npm install electron/rebuild
            fi
            cd modules/internet-monitor
            ../../node_modules/.bin/electron-rebuild
            this should be a postinstall step in the package.json
            this is the tested postinstall
            and works…
            and the fixed package.json
              "name": "internet-speed",
              "version": "1.0.0",
              "description": "Displays ping, download and upload speed on your smart mirror.",
              "main": "index.js",
              "scripts": {
                "test": "echo \"Error: no test specified\" && exit 1",
                "postinstall":"./postinstall"
              "keywords": [
                "internet",
                "speed"
              "author": "Debayan Deb",
              "license": "MIT",
              "dependencies": {
                "justgage": "^1.3.5",
                "round-to": "^1.1.0",
                "speedtest-net": "^2.2.0",
                "raphael": "^2.2.8"
            have to make postinstall executable
            chmod +x postinstall
              @sdetweil Interesting solution! I’m still not quite getting to grips with the rebuild of electron.
              My approach in the PR is to use a version of speedtest-net that is compatible with the current version. That way, no rebuild is necessary.
                @KristjanESPERANTO its not a rebuild of electron … its rebuilding binaries for the current electron version
                  KristjanESPERANTO Module Developer @KristjanESPERANTO
                  @KristjanESPERANTO said in Internet-monitor module Not Starting Mirror:
                  @ebourne The maintainer of the module, @bhepler, accepted my Pull Request. Please update your module and check if it’s working 🙂
                  • E Offline
                    ebourne @KristjanESPERANTO
                    @KristjanESPERANTO just wanna say thanks
                    it works
