    Internet-monitor module Not Starting Mirror
    13 Posts 3 Posters 3.5k Views 3 Watching
      sdetweil @ebourne
      @ebourne please show the messages at mm startup, where you do npm start
      • E Offline
        ebourne @sdetweil
        @sdetweil That is the weird thing. the start up message is completely normal
        once i comment out the config for internet-monitor and run pm2 restart mm.sh i get the same message
          sdetweil @ebourne
          @ebourne thats not the startup messages
          do this is the module enabled in config.js
          pm2 stop all
          npm start
          that will display the errors
          pm2 start mm
          to restart thru pm2
          E 1 Reply Last reply Reply Quote 1
          • E Offline
            ebourne @sdetweil
            oh i see. it seems it says it can’t find a folder, and that makes me confused since i did clone and npm installed in the internet-monitor folder. i thought that was all there was
              sdetweil @ebourne
              @ebourne which authors module are you using
              show
              git remote -v
              E KristjanESPERANTOK 2 Replies Last reply Reply Quote 1
              • E Offline
                ebourne @sdetweil
                @sdetweil brianhepler
                • KristjanESPERANTOK Offline
                  I also happened to be working on the problem just now. The speedtest-net package is apparently no longer compatible with the current node version. I created a PR to fix this: https://github.com/BrianHepler/internet-monitor/pull/2
                  Let’s see when @bhepler merge it.
                  S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                    sdetweil @KristjanESPERANTO
                    @KristjanESPERANTO not node version, electron version
                    so, the steps to fix I think (tested, failed before, doesn’t fail now)
                    #!/bin/bash
                    # this tool should be installed in MM
                    if [ ! -e node_modules/.bin/electron-rebuild ]; then
                        npm install electron/rebuild
                    fi
                    cd modules/internet-monitor
                    ../../node_modules/.bin/electron-rebuild
                    this should be a postinstall step in the package.json
                    this is the tested postinstall
                    and works…
                    and the fixed package.json
                      "name": "internet-speed",
                      "version": "1.0.0",
                      "description": "Displays ping, download and upload speed on your smart mirror.",
                      "main": "index.js",
                      "scripts": {
                        "test": "echo \"Error: no test specified\" && exit 1",
                        "postinstall":"./postinstall"
                      "keywords": [
                        "internet",
                        "speed"
                      "author": "Debayan Deb",
                      "license": "MIT",
                      "dependencies": {
                        "justgage": "^1.3.5",
                        "round-to": "^1.1.0",
                        "speedtest-net": "^2.2.0",
                        "raphael": "^2.2.8"
                    have to make postinstall executable
                    chmod +x postinstall
                      @sdetweil Interesting solution! I’m still not quite getting to grips with the rebuild of electron.
                      My approach in the PR is to use a version of speedtest-net that is compatible with the current version. That way, no rebuild is necessary.
                        @KristjanESPERANTO its not a rebuild of electron … its rebuilding binaries for the current electron version
