    MMM-CalendarExt3
    689 Posts 82 Posters 3.1m Views 86 Watching
      bobbylx @sdetweil
      @sdetweil said in MMM-CalendarExt3:
      @bobbylx said in MMM-CalendarExt3:
                          module: "compliments",
                          position: ""
      must be a valid position if specified…
      you can disable a module by adding
      disabled: true,
      after the module: line
      you can also comment out the position
      // position:“…”
      this would be how you use the default calendar with Ext3…
      it would work, but not be shown
      backup, backup, backup…
      see my scripts, backup to private repo on github… restore from there
      versionable…
      3 tiny files… and any keyfiles/token files…
      https://github.com/sdetweil/MagicMirror-backup-restore
      Thanks, just made that change, found a couple more that needed attention. I also checked my history in this thread, I’ve posted my config before asking other questions so I was able to borrow some lines. Getting close now.
      @MMRIZE said in MMM-CalendarExt3:
      @bobbylx
      CX3* series may not work on MIDORI, sorry. It’s too old browser, doesn’t support advanced modern JavaScript technologies.
      I had been using it with Midori until just a few days ago when I decided to reload. It wasn’t fast or always the best, but I’m using a Pi zero W so limited on browsers right now. I’ll be picking up a Pi 3 or 4 soon then I’ll do this all over again.
        aymen_a22
        Unsure why, but I keep getting this error message.
        Is anyone able to assist if possible please?
        Warning: vkCreateInstance: Found no drivers!
        Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
        at CheckVkSuccessImpl (…/…/third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
        at CreateVkInstance (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
        at Initialize (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
        at Create (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
        at operator() (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
          sdetweil @aymen_a22
          @aymen_a22 bug in electron , nothing we can do… ignore it
            princemaxwell
            Hello together,
            i have configured 8 calendars in the default calendar module. Three of them are from “i.cal.to” and five are my public iCloudcalendars.
            The default calendar app is loading them without errors, but MMM-CalendarExt3 has problems to view the iCloud entries.
            The mm-error.log shows:
            [19.03.2024 21:24.43.184] [ERROR] Calendar Error. Could not fetch calendar:  https://p63-caldav.icloud.com/published/2/MTA... TypeError: fetch failed
                at Object.fetch (node:internal/deps/undici/undici:11576:11) {
              cause: SocketError: other side closed
                  at TLSSocket.onSocketEnd (node:internal/deps/undici/undici:9790:26)
                  at TLSSocket.emit (node:events:526:35)
                  at endReadableNT (node:internal/streams/readable:1359:12)
                  at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
                code: 'UND_ERR_SOCKET',
                socket: {
                  localAddress: '10.0.0.20',
                  localPort: 37214,
                  remoteAddress: undefined,
                  remotePort: undefined,
                  remoteFamily: undefined,
                  timeout: undefined,
                  bytesWritten: 639,
                  bytesRead: 143898
            while the mm-out.log shows:
            [19.03.2024 21:23.35.168] [INFO]  Calendar-Fetcher: Broadcasting 5 events from https://p63-caldav.icloud.com/published/2/MTA....
            [19.03.2024 21:23.35.332] [INFO]  updatenotification: You are using pm2 with MagicMirror
            [19.03.2024 21:23.35.333] [INFO]  Checking git for module: MMM-soccer
            [19.03.2024 21:23.35.462] [INFO]  Checking git for module: MMM-Planetarium
            [19.03.2024 21:23.35.591] [INFO]  Checking git for module: MMM-Globe2
            [19.03.2024 21:23.36.450] [INFO]  Calendar-Fetcher: Broadcasting 0 events from https://p63-caldav.icloud.com/published/2/MTA....
            [19.03.2024 21:23.36.513] [INFO]  Checking git for module: MagicMirror
            [19.03.2024 21:23.36.963] [INFO]  Newsfeed-Fetcher: Broadcasting 30 items.
            [19.03.2024 21:23.37.049] [INFO]  Newsfeed-Fetcher: Broadcasting 100 items.
            [19.03.2024 21:23.37.825] [INFO]  Calendar-Fetcher: Broadcasting 7 events from https://p63-caldav.icloud.com/published/2/MTA....
            [19.03.2024 21:24.03.308] [INFO]  Calendar-Fetcher: Broadcasting 8 events from https://p63-caldav.icloud.com/published/2/MTA....
            [19.03.2024 21:24.43.055] [INFO]  Calendar-Fetcher: Broadcasting 10 events from https://p29-caldav.icloud.com/published/2/ODA....
            [19.03.2024 21:24.43.503] [INFO]  Calendar-Fetcher: Broadcasting 1 events from https://i.cal.to/ical/77/....
            [19.03.2024 21:24.43.754] [INFO]  Calendar-Fetcher: Broadcasting 5 events from https://i.cal.to/ical/3/....
            [19.03.2024 21:24.43.781] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://i.cal.to/ical/61/....
            [19.03.2024 21:24.44.853] [INFO]  Calendar-Fetcher: Broadcasting 0 events from https://p63-caldav.icloud.com/published/2/MTA....
            [19.03.2024 21:24.45.665] [INFO]  Calendar-Fetcher: Broadcasting 7 events from https://p63-caldav.icloud.com/published/2/MTA....
            [19.03.2024 21:25.10.627] [INFO]  Calendar-Fetcher: Broadcasting 8 events from https://p63-caldav.icloud.com/published/2/MTA....
            I have increased the waitFetch, but it didn’t help.
            			module: "MMM-CalendarExt3",
            			position: "middle_center",
            			waitFetch: 32000,
            			disabled: false,
            Can someone help me?
            Max
            S M 3 Replies Last reply Reply Quote 0
              sdetweil @princemaxwell
              @princemaxwell the error log says problem w the default calendar as ext3 gets it’s events there
                princemaxwell @sdetweil
                @sdetweil when i disable the MMM-CalendarExt3 module, the errors are gone.
                All calendars are working fine and loading quickly in default calendar module.
                  MMRIZE @princemaxwell
                  @princemaxwell
                  CX3 doesn’t connect or fetch calendar server. That error probably has been caused by default calendar module.
                    @princemaxwell
                    CX3*s do not use nodeJS at all, so they are not related to your error messages. The modules are executed on the browser level, not on the server-side node environment, so they could not affect server-side processes like calendar fetching.
                    Your error message (UND_ERR_SOCKET) is caused by the undici node module; it may be used inside of the default calendar module to connect through HTTP/1.1. That error usually happens when the connection is closed by long waits or prior preemption.
                    There is a weird thing. As far as I know, the default calendar module depends on node-ical, which uses axios instead of undici. So I wonder why and from where this error message comes.
                    To make things simple clearly;
                    1. Backup your current config.js in the safe area.
                    2. Create a new config.js, and remove all other not-releated modules like MMM-Planetarium, MMM-soccer, … Leave only clock, calendar and MMM-CalendarExt3 modules.
                    3. Begin with one or two calendars, not all the calendars.
                    4. Try to execute MM again, and let’s see what happens.
                    5. After confirmation that a small qty of calendars has no issue, add more calendars.
                    6. After confirmation that there is no issue with the calendars, try adding more modules one by one.
                    (A possible reason, I guess, is that your modules are racing to use the network/dest-server severely. For example, your calendars look being rescanned every minutes. You may need to rearrange the interval of the schedule.)
                    S P 2 Replies Last reply Reply Quote 0
                      sdetweil @MMRIZE
                      @MMRIZE calendar uses built in fetch to get the ics file. we do not have node-ical fetch it for us ( the prior ical lib did not provide fetch)
                        MMRIZE @sdetweil
                        If so, this is really weird where the undici module is used.
                          sdetweil @MMRIZE
                          @MMRIZE undici is the implementation code of fetch
                            princemaxwell @MMRIZE
                            @MMRIZE
                            Thanks for your answer.
                            I cleaned up my config.js and only had following modules in it:
                            • alert
                            • updatenotification
                            • clock
                            • calendar
                            • MMM-CalendarExt3
                            No matter how many calendars I have activated, the default calendar loads all entries quite quickly, although you can notice that the “large” calendars with many entries took a few seconds to load (sometimes up to 20-30 seconds).
                            Nevertheless, I deleted the fetchInterval (31000) in the default calendar, so the default value of 300000 is now active.
                            After the default calendar displayed all entries, it took at least another 10 minutes for them to appear in the MMM-CalendarExt3.
                            Why is this taking so long? They are sent to MMM-CalendarExt3 via “broadcastEvents” or what?
                            I took a look at the sizes of my calendar:
                            • Calendar 1: 1,068,804 bytes
                            • Calendar 2: 697,796 bytes
                            • Calendar 3: 398,683 bytes
                            • Calendar 4: 150,176 bytes
                            • Calendar 5: 73,128 bytes
                            • Calendar 6: 70,476 bytes
                            • Calendar 7: 23,940 bytes
                            • Calendar 8: 17,221 bytes
                            Calendars 6-8 are displayed relatively quickly in MMM-CalendarExt3, calendar 5 a little later. The others require the previously mentioned 5-10 minutes.
                            Could it have something to do with size?
                              @princemaxwell can you show the console log of mm with the timestamps for the broadcasts from the default calendar?
                              be careful as these message now expose the calendar url string…
                                No problem, i removed fragments from the share link and named them like my list above, sorted by size, cal-8 is the smallest filesize.
                                > magicmirror@2.26.0 start
                                [20.03.2024 15:28.52.845] [LOG]   Starting MagicMirror: v2.26.0
                                [20.03.2024 15:28.52.851] [LOG]   Loading config ...
                                [20.03.2024 15:28.52.856] [DEBUG] config template file not exists, no envsubst
                                [20.03.2024 15:28.52.862] [LOG]   Loading module helpers ...
                                [20.03.2024 15:28.52.864] [LOG]   No helper found for module: alert.
                                [20.03.2024 15:28.52.898] [LOG]   Initializing new module helper ...
                                [20.03.2024 15:28.52.898] [LOG]   Module helper loaded: updatenotification
                                [20.03.2024 15:28.52.900] [LOG]   No helper found for module: clock.
                                [20.03.2024 15:28.53.231] [LOG]   Initializing new module helper ...
                                [20.03.2024 15:28.53.232] [LOG]   Module helper loaded: calendar
                                [20.03.2024 15:28.53.234] [LOG]   No helper found for module: MMM-CalendarExt3.
                                [20.03.2024 15:28.53.235] [LOG]   All module helpers loaded.
                                [20.03.2024 15:28.53.244] [LOG]   Starting server on port 8080 ...
                                [20.03.2024 15:28.53.275] [LOG]   Server started ...
                                [20.03.2024 15:28.53.278] [LOG]   Connecting socket for: updatenotification
                                [20.03.2024 15:28.53.280] [LOG]   Starting module helper: updatenotification
                                [20.03.2024 15:28.53.281] [LOG]   Connecting socket for: calendar
                                [20.03.2024 15:28.53.282] [LOG]   Starting node helper for: calendar
                                [20.03.2024 15:28.53.283] [LOG]   Sockets connected & modules started ...
                                [20.03.2024 15:28.53.918] [LOG]   Launching application.
                                [20.03.2024 15:28.57.031] [LOG]   Create new calendarfetcher for url: https://p63-caldav.icloud.com/published/2/MTA-cal-2 - Interval: 3600000
                                [20.03.2024 15:28.57.194] [LOG]   Create new calendarfetcher for url: https://p63-caldav.icloud.com/published/2/MTA-cal-4 - Interval: 3600000
                                [20.03.2024 15:28.57.198] [LOG]   Create new calendarfetcher for url: https://p63-caldav.icloud.com/published/2/MTA-cal-3 - Interval: 3600000
                                [20.03.2024 15:28.57.201] [LOG]   Create new calendarfetcher for url: https://p29-caldav.icloud.com/published/2/ODA-cal-1 - Interval: 3600000
                                [20.03.2024 15:28.57.205] [LOG]   Create new calendarfetcher for url: https://p63-caldav.icloud.com/published/2/MTA-cal-5 - Interval: 3600000
                                [20.03.2024 15:28.57.208] [LOG]   Create new calendarfetcher for url: https://i.cal.to/ical/3/borussiadortmund/bundesliga-spielplan/cal-6.ics - Interval: 3600000
                                [20.03.2024 15:28.57.217] [LOG]   Create new calendarfetcher for url: https://i.cal.to/ical/77/nrw/ferien/cal-8.ics - Interval: 3600000
                                [20.03.2024 15:28.57.221] [LOG]   Create new calendarfetcher for url: https://i.cal.to/ical/61/nrw/feiertage/cal-7.ics - Interval: 3600000
                                [20.03.2024 15:28.57.224] [INFO]  updatenotification: Updater Class Loaded!
                                [20.03.2024 15:28.57.225] [INFO]  updatenotification: Checking PM2 using...
                                [20.03.2024 15:28.57.227] [INFO]  Checking git for module: MMM-CalendarExt3
                                [20.03.2024 15:28.57.290] [INFO]  Checking git for module: MagicMirror
                                [20.03.2024 15:28.57.729] [INFO]  Calendar-Fetcher: Broadcasting 2 events from https://i.cal.to/ical/61/nrw/feiertage/cal-7.ics.
                                [20.03.2024 15:28.57.825] [INFO]  Calendar-Fetcher: Broadcasting 1 events from https://i.cal.to/ical/77/nrw/ferien/cal-8.ics.
                                [20.03.2024 15:28.59.069] [INFO]  Calendar-Fetcher: Broadcasting 5 events from https://i.cal.to/ical/3/borussiadortmund/bundesliga-spielplan/cal-6.ics.
                                [20.03.2024 15:29.00.814] [INFO]  Calendar-Fetcher: Broadcasting 4 events from https://p63-caldav.icloud.com/published/2/MTA-cal-5.
                                [20.03.2024 15:29.00.869] [INFO]  updatenotification: You are using pm2 with MagicMirror
                                [20.03.2024 15:29.02.223] [INFO]  Calendar-Fetcher: Broadcasting 1 events from https://p63-caldav.icloud.com/published/2/MTA-cal-4.
                                [20.03.2024 15:29.04.265] [INFO]  Calendar-Fetcher: Broadcasting 7 events from https://p63-caldav.icloud.com/published/2/MTA-cal-3.
                                [20.03.2024 15:29.49.438] [INFO]  Calendar-Fetcher: Broadcasting 8 events from https://p63-caldav.icloud.com/published/2/MTA-cal-2.
                                [20.03.2024 15:30.30.417] [INFO]  Calendar-Fetcher: Broadcasting 12 events from https://p29-caldav.icloud.com/published/2/ODA-cal-1.
                                  @princemaxwell
                                  Now I know what happens. Your symptom is not related with any errors.
                                  Let me explain the process.
                                  1. Each calendar parsing/fetching in the calendar module will take some time, a few seconds or some dozen seconds. How long will it take is unpredictable.
                                  2. The default calendar module will refresh itself and broadcast accumulated events on any calendar fetched. So, in some unlucky cases, the module may flicker due to too-short-term refreshing.
                                  3. CX3’s view is very complex and heavy for redrawing frequently. To avoid that flickering, CX3 will wait some time after any broadcasted event arrives (waitFetch: 5000ms by default) to check whether the following broadcasting will arrive in the short term. If no other followed broadcasting happens, stop waiting and process collected events at that moment and draw the view.
                                  4. This means that if you have 8 calendars and 5 calendars complete fetching in 4 seconds and the other 3 calendars may take over 10 seconds, only the events from the earlier 5 calendars will be collected and prepared to show before the first rendering time(waitFetch 5000ms).
                                  5. After the first rendering, the remaining 3 calendars may complete fetching. CX3 receives those events but does not render them instantly to avoid flickering. The rendering will be done every refreshInterval (by default 10 minutes) with stocked events that are received during that period.
                                  6. That is the reason why some of your calendars will be shown the first time, but others are applied after 10 minutes.
                                  So, you may have these options.
                                  1. Do nothing. Just wait 10 minutes; the lazy events will normally be applied to CX3 from the second refreshing cycle. Calendar events are not regarded as needing urgent, instant reflection. Your MM may stay on for a long time. Ten minutes after the first bootup will not be a big issue, and your family will not care.
                                  2. Or Give enough long waitFetch. Your log showed that almost 2 minute is needed to complete fetching 8 calendars entirely. waitFetch: 1000 * 60 * 2 may work. (The default value is 5000ms, not 300000) (This means you need 2 minutes before drawing the CX3 view at first time.)
                                  3. Or Give shorter refreshInterval to redraw and reflect the change of events. The default value is 1000 * 60 * 10 (10 minutes) But you can assign shorter. But 99.99% of refreshing will deal unchanged same events. So I think it is a kind of waste. Anyway, if you want instant reflection, give it shorter value.
                                    princemaxwell
                                    @MMRIZE
                                    All right, that makes complete sense.
                                    I understand that now.
                                    CX3 initially only recognizes broadcast events and does not know how many calendars are configured and waits until all of them have been processed.
                                    By the way, with the 300000 I meant the time from the default calendar, the “fetchInterval”, whose default value is: 300000 (5 minutes).
                                    I tried the 2nd option, unfortunately it doesn’t work, I set it to 1000 * 60 * 2, but it takes exactly 10 minutes.
                                    When and how often is waitFetch executed, just once? I would have expected CX3 to notice a broadcast and then update according to waitFetch.
                                      @princemaxwell
                                      waitFetch will be applied only to the very first broadcast notification. If you set waitFetch: 120000, this sequence will happen (I’ll assume the calendar module is described before CX3 in config.js)
                                      1. the calendar module starts the parsing of calendars.
                                      2. CX3 module starts. Library is loaded and the DOM is prepared. It is now ready to receive the events.
                                      3. The first calendars might complete its fetching. then calendar module will broadcast the events at that moment.
                                      4. CX3 receive the first broadcasted events. Wait 120000ms(2 minute) from that moment to get other lazy broadcasting coming.
                                      5. Other calendars might be fetched. But some might still need to be completed.
                                      6. Anyway, after 120000ms from the first broadcast, CX3 will draw the events that have arrived till then. (It means the view of CX3 is shown for the first time after at least 2 minutes from the boot)
                                      7. Then after 10minutes(refreshInterval), CX3 will refresh again. Maybe until then, all calendars would have been fetched.(I hope.)
                                      Anyway your log was showing the 1st calendar fetching as below;
                                      [20.03.2024 15:28.57.729] [INFO]  Calendar-Fetcher: Broadcasting 2 events from ...
                                      And the 8th fetching ;
                                      [20.03.2024 15:30.30.417] [INFO]  Calendar-Fetcher: Broadcasting 12 events from ...
                                      It takes 93 seconds to complete. So I think waitFetch: 120000 (120 seconds) would be enough; however, if there are still missing events, the possible reasons would be;
                                      1. It takes more than 120 seconds at that moment randomly to complete fetching of all calendars since first fetching,
                                      2. some calendars were too fast-fetched before CX3 was ready. so they were missed. (all modules are loaded and starts sequentially, so if you have certain number of modules, CX3 may not be ready until that moment.)
                                      Of course, you can adjust the order of modules in config, assign needed values of waitFetch and refreshInterval to show the entire events properly on the first boot time.
                                      But, my suggestion is,
                                      Just leave them and do nothing.
                                      After 10 minutes from the first bootup, everything will be OK. Your MM might be rebooted at midnight or in the morning on real-life usage. MM would stay turned on all day or for several days. So literally, nobody will care, even realize there had been some missing events on the bootup time. You don’t have to make an effort to solve this unworthy issue.
                                        @MMRIZE
                                        The standards are absolutely sufficient for everyday use.
                                        But while I position the modules and adapt the CSS to my own wishes and test the functions of the modules, the long time is rather annoying and I wanted to shorten it.
                                        I have now activated the following config and restarted.
                                        I recorded the contents of the screen and looked at exactly when and what happened.
                                        		disabled: false,
                                        		waitFetch: 1000 * 60 * 2,
                                        		refreshInterval: 1000 * 60 * 2,
                                        		module: "MMM-CalendarExt3Agenda",
                                        		position: "top_center",
                                        		disabled: false,
                                        		title: "Kalender",
                                        			instanceId: "basicCalendar",
                                        			locale: 'de',
                                        			firstDayOfWeek: 1,
                                        			startDayIndex: -1,
                                        			endDayIndex: 10,
                                        			calendarSet: []
                                        The result is that the config is ignored.
                                        • CX3 starts after the calendar module and displayed the first entries of the 3 small calendars as soon as they appeared.
                                        • CX3 only refreshes after 10 minutes. You can tell this by the display briefly disappearing and then fading in again. Then all entries are included.
                                        • CX3A also starts after the calendar module and also shows the entries of the 3 small calendars directly.
                                        • CX3A refreshes after 30 minutes (default?). Even then, all entries are included.
                                        Apparently waitFetch is ignored for both, otherwise, according to your explanation, the first entries would only appear after waitFetch. But these are there immediately as soon as the module has been loaded.
                                        Other configurations are also ignored. For example, I used this for testing:
                                        mode: ‘day’,
                                        But i only get the week view.
                                        When i change it in MMM-CalendarExt3.js, then it works.
                                        Why is the config ignored or what am I missing?
                                          @princemaxwell
                                          You did a simple mistake. Configuration parameters of the module should be placed inside of the module’s config:{}.
                                            @MMRIZE
                                            Oh no, that’s embarrassing. I completely overlooked that and of course it works now. So often you look at what the problem could be and just don’t see it.
                                            Thank you very much for your help!
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 34
                                            • 35
                                            • 25 / 35
