    MMM-euro2024
    23 Posts 7 Posters 7.8k Views 7 Watching
    • 0m4r0 Offline
      0m4r Module Developer
      A few weeks more to go, but the magic mirror module is already here for you: https://github.com/0m4r/MMM-euro2024!
      MMM-euro2024
      KristjanESPERANTOK C C 3 Replies Last reply Reply Quote 2
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @0m4r
        @0m4r Nice! Thanks! 👏
        Don’t forget to add it to the module list 🙂
          chrisfr1976 @0m4r
          @0m4r There is a problem with the token. I think, I’m stupid, but:
          You write for the config token: [YOUR_TOKEN]
          So I’ve tried token:[1234567890], With this I get an error in the config.js and the mirror does not start up.
          Then I’ve tried token:1234567890,. Same issue.
          Then I’ve tried token:"1234567890", Then the config.js is okay and electron starts. But in this case I get an error message:
          [ERROR] MMM-euro2024 fetchTeams 2018 {"message":"Your API token is invalid.","errorCode":400}
          …of course I received a real API-key from Daniel. Copy+paste, so the key real in my config is okay.
          How should I enter the API-Key? :thinking_face:
          Regards, Chris.
          S 0m4r0 2 Replies Last reply Reply Quote 1
            sdetweil @chrisfr1976
            @chrisfr1976 what is the module property for the api key? that is what ‘token’ means.
            and typically [apikey]
            means replace all that with the quoted string of the apikey
            • 0m4r0 Offline
              0m4r Module Developer @chrisfr1976
              @chrisfr1976 can you share the config you set up for the module (obviously hiding the token)? Apart from a problem with the token itself, I cannot think of anything wrong with what you describe.
                sdetweil @0m4r
                @0m4r the sample is missing the config:{} section
                  disabled: false,
                  module: "MMM-euro2024",
                  position: "bottom_center",
                  defaults: {
                    updateInterval: 60 * 1000, // one minute
                  token: [YOUR_TOKEN]
                should be
                  disabled: false,
                  config:{
                       token: [YOUR_TOKEN]
                your module passes this.config to the node_helper, but there is no config block, so only {} gets passed
                this.sendSocketNotification(this.name + 'CONFIG', this.config);
                  @0m4r
                  also, the defaults go in the modulename.js not in the node_helper.js
                  defaults: {
                      competitionId: 2018, // Euro 2024
                      updateInterval: 60 * 1000, // 1 minute
                  this provides overridable properties via config.js
                  from the doc
                  https://docs.magicmirror.builders/development/core-module-file.html#available-module-instance-properties
                  0m4r0 1 Reply Last reply Reply Quote 1
                  • 0m4r0 Offline
                    0m4r Module Developer @sdetweil
                    @sdetweil thanks for the detailed feedback.
                    I will update it as soon as I get a moment :)
                    • 0m4r0 Offline
                      0m4r Module Developer @0m4r
                      The README.md is updated.
                      The configuration instructions should be now correct: https://github.com/0m4r/MMM-euro2024?tab=readme-ov-file#configuration
                        sdetweil @0m4r
                        @0m4r i want to nudge you a little more, on the defaults.
                        my MMM-Config module presents a form for config customization, and it does this by discovering the parameters in the defaults section of the modulename.js. as it sits, your module would have no parameters for the user to configure
                        just move that one section to the modulename.js from the node helper and all will be good. no other change to your module is required because you did that change.
                        0m4r0 1 Reply Last reply Reply Quote 0
