    MMM-euro2024
    30 Posts 8 Posters 15.6k Views 7 Watching
      sdetweil @chrisfr1976
      @chrisfr1976 what is the module property for the api key? that is what ‘token’ means.
      and typically [apikey]
      means replace all that with the quoted string of the apikey
      • 0m4r0 Offline
        0m4r Module Developer @chrisfr1976
        @chrisfr1976 can you share the config you set up for the module (obviously hiding the token)? Apart from a problem with the token itself, I cannot think of anything wrong with what you describe.
        https://github.com/0m4r
          sdetweil @0m4r
          @0m4r the sample is missing the config:{} section
            disabled: false,
            module: "MMM-euro2024",
            position: "bottom_center",
            defaults: {
              updateInterval: 60 * 1000, // one minute
            token: [YOUR_TOKEN]
          should be
            disabled: false,
            config:{
                 token: [YOUR_TOKEN]
          your module passes this.config to the node_helper, but there is no config block, so only {} gets passed
          this.sendSocketNotification(this.name + 'CONFIG', this.config);
            @0m4r
            also, the defaults go in the modulename.js not in the node_helper.js
            defaults: {
                competitionId: 2018, // Euro 2024
                updateInterval: 60 * 1000, // 1 minute
            this provides overridable properties via config.js
            from the doc
            https://docs.magicmirror.builders/development/core-module-file.html#available-module-instance-properties
            0m4r0 1 Reply Last reply Reply Quote 1
            • 0m4r0 Offline
              0m4r Module Developer @sdetweil
              @sdetweil thanks for the detailed feedback.
              I will update it as soon as I get a moment :)
              • 0m4r0 Offline
                0m4r Module Developer @0m4r
                The README.md is updated.
                The configuration instructions should be now correct: https://github.com/0m4r/MMM-euro2024?tab=readme-ov-file#configuration
                  sdetweil @0m4r
                  @0m4r i want to nudge you a little more, on the defaults.
                  my MMM-Config module presents a form for config customization, and it does this by discovering the parameters in the defaults section of the modulename.js. as it sits, your module would have no parameters for the user to configure
                  just move that one section to the modulename.js from the node helper and all will be good. no other change to your module is required because you did that change.
                  0m4r0 1 Reply Last reply Reply Quote 0
                    robiv8
                    I get a black screen when I activate the module?
                    Original Config as in description and token available.
                    Does anyone know what this could be?
                    Ich bekomme einen Schwarzen Schirm wenn ich das Modul Aktiviere?
                    Original Config wie in Beschreibung und Token vorhanden.
                    Weiß jemand was das sein könnte?
                    Danke
                    Robert
                    • 0m4r0 Offline
                      0m4r Module Developer @robiv8
                      @robiv8 hey, I am sorry to hear that.
                      Are you able to provide some logs?
                      • 0m4r0 Offline
                        @sdetweil this is done in version 1.0.4
                        R S 2 Replies Last reply Reply Quote 0
                          robiv8 @0m4r
                          @0m4r
                          das log sagt: Please correct syntax errors at or above this line: ReferenceError: b1e6…meinToken…67c8c5 is not defined
                          • 0m4r0 Offline
                            @robiv8 I think your configuration is wrong.
                            Is the token wrapped into quotes?
                              disabled: false,
                              module: 'MMM-euro2024',
                              position: 'center',
                              header: 'Euro 2024',
                                token: "M4g1cM1rr0r"
                              sdetweil @0m4r
                              @0m4r this is what your module config looks like in MMM-Config
                              • 0m4r0 Offline
                                @sdetweil this is good, isn’t it?
                                  sdetweil @0m4r
                                  @0m4r yes… it works
                                    robiv8 @0m4r
                                    @0m4r
                                    Hallo.
                                    This i my config, as described in GitHub
                                    	disabled: false,
                                    	position: "center",
                                    	header: "Euro 2024",
                                    	token: [b1e67..myToken..67c8c5],
                                    Ok Danke,
                                    with superscripts it works.
                                    Why isn’t that right in GitHub?
                                    • 0m4r0 Offline
                                      @robiv8 try with this:
                                      	disabled: false,
                                      	position: "center",
                                      	token: "b1e67..myToken..67c8c5",
                                      • L Offline
                                        leafarenuk
                                        Hi guys,
                                        I cannot get this module to run…
                                        I also opened an issue in the repo: https://github.com/0m4r/MMM-euro2024/issues/2
                                        Can somebody from here help me? @0m4r ?
                                        Thanks in advance
                                        • 0m4r0 Offline
                                          0m4r Module Developer @leafarenuk
                                          @leafarenuk I replied to you on Git Hub a week ago or so.
                                          As I have not heard back from you since then, I assume the problem is resolved.
                                          If not, feel free to get in touch again.
                                            com1cedric @0m4r
                                            @0m4r Hello and thank you for your great module.
                                            after installing it, it appears on my mirror, but stays on “loading…”.
                                            Do you maybe know this issue?
                                            Thanks in advance for your helps.
                                            Kind regards
