    MMM-euro2024
    30 Posts 8 Posters 15.8k Views 7 Watching
      sdetweil @0m4r
      @0m4r i want to nudge you a little more, on the defaults.
      my MMM-Config module presents a form for config customization, and it does this by discovering the parameters in the defaults section of the modulename.js. as it sits, your module would have no parameters for the user to configure
      just move that one section to the modulename.js from the node helper and all will be good. no other change to your module is required because you did that change.
      0m4r0 1 Reply Last reply
        robiv8
        I get a black screen when I activate the module?
        Original Config as in description and token available.
        Does anyone know what this could be?
        Ich bekomme einen Schwarzen Schirm wenn ich das Modul Aktiviere?
        Original Config wie in Beschreibung und Token vorhanden.
        Weiß jemand was das sein könnte?
        Danke
        Robert
        • 0m4r0
          0m4r Module Developer @robiv8
          @robiv8 hey, I am sorry to hear that.
          Are you able to provide some logs?
          https://github.com/0m4r
          • 0m4r0
            0m4r Module Developer @sdetweil
            @sdetweil this is done in version 1.0.4
            R S 2 Replies Last reply
              robiv8 @0m4r
              @0m4r
              das log sagt: Please correct syntax errors at or above this line: ReferenceError: b1e6…meinToken…67c8c5 is not defined
              • 0m4r0
                @robiv8 I think your configuration is wrong.
                Is the token wrapped into quotes?
                  disabled: false,
                  module: 'MMM-euro2024',
                  position: 'center',
                  header: 'Euro 2024',
                    updateInterval: 60 * 1000,
                    token: "M4g1cM1rr0r"
                R 1 Reply Last reply
                  sdetweil @0m4r
                  @0m4r this is what your module config looks like in MMM-Config
                  • 0m4r0
                    @sdetweil this is good, isn’t it?
                      sdetweil @0m4r
                      @0m4r yes… it works
                        robiv8 @0m4r
                        @0m4r
                        Hallo.
                        This i my config, as described in GitHub
                        	disabled: false,
                        	module: "MMM-euro2024",
                        	position: "center",
                        	header: "Euro 2024",
                        	token: [b1e67..myToken..67c8c5],
                        Ok Danke,
                        with superscripts it works.
                        Why isn’t that right in GitHub?
                        • 0m4r0
                          @robiv8 try with this:
                          	disabled: false,
                          	position: "center",
                          	token: "b1e67..myToken..67c8c5",
                          • L
                            leafarenuk
                            Hi guys,
                            I cannot get this module to run…
                            I also opened an issue in the repo: https://github.com/0m4r/MMM-euro2024/issues/2
                            Can somebody from here help me? @0m4r ?
                            Thanks in advance
                            • 0m4r0
                              0m4r Module Developer @leafarenuk
                              @leafarenuk I replied to you on Git Hub a week ago or so.
                              As I have not heard back from you since then, I assume the problem is resolved.
                              If not, feel free to get in touch again.
                                com1cedric @0m4r
                                @0m4r Hello and thank you for your great module.
                                after installing it, it appears on my mirror, but stays on “loading…”.
                                Do you maybe know this issue?
                                Thanks in advance for your helps.
                                Kind regards
                                • NiggichN
                                  Niggich
                                  Hello Mirrorenthusiasts,
                                  it is possible to use this module für the WorlCup 2026? Thx
                                  • 0m4r0
                                    0m4r Module Developer @Niggich
                                    @Niggich
                                    you can either use: https://github.com/0m4r/MMM-SoccerLiveScore and add 2000 to the leagues config parameter: https://github.com/0m4r/MMM-SoccerLiveScore#config
                                    or you can update the file:
                                    https://github.com/0m4r/MMM-euro2024/blob/main/MMM-euro2024.js
                                    to use the worldcup code: 2000
                                    (https://docs.football-data.org/general/v4/lookup_tables.html#_league_codes)
                                    NiggichN 2 Replies Last reply
                                    • NiggichN
                                      Niggich @0m4r
                                      @0m4r
                                      Thank You! It’s working like a charm.
                                      • NiggichN
                                        Niggich @0m4r
                                        @0m4r
                                        I play around with the MMM-SoccerLiveScore module. I used the module at a Full HD Touchscreen. Is there a way to scroll the Standings by hand? The Screen is to small to show the full table.
                                        THX
                                        • 0m4r0
                                          @Niggich it should scroll by itself if the config value scrollVertical is set to true.
                                          I never tried it on a touch screen…
                                          NiggichN 1 Reply Last reply
                                          • NiggichN
                                            Niggich @0m4r
                                            @0m4r No, it doesn’t scroll by itself when i set the value scrollVertical to true. It’s just scrolling the title bar but not the table.
