    MMM-euro2024
    30 Posts 8 Posters 16.3k Views 7 Watching
      robiv8 @0m4r
      @0m4r
      Hallo.
      This i my config, as described in GitHub
      	disabled: false,
      	module: "MMM-euro2024",
      	position: "center",
      	header: "Euro 2024",
      	updateInterval: 60 * 1000,
      	token: [b1e67..myToken..67c8c5],
      Ok Danke,
      with superscripts it works.
      Why isn’t that right in GitHub?
      0m4r0 1 Reply Last reply
      • 0m4r0
        0m4r Module Developer @robiv8
        @robiv8 try with this:
        	disabled: false,
        	position: "center",
        	token: "b1e67..myToken..67c8c5",
        https://github.com/0m4r
        • L
          leafarenuk
          Hi guys,
          I cannot get this module to run…
          I also opened an issue in the repo: https://github.com/0m4r/MMM-euro2024/issues/2
          Can somebody from here help me? @0m4r ?
          Thanks in advance
          • 0m4r0
            0m4r Module Developer @leafarenuk
            @leafarenuk I replied to you on Git Hub a week ago or so.
            As I have not heard back from you since then, I assume the problem is resolved.
            If not, feel free to get in touch again.
              com1cedric @0m4r
              @0m4r Hello and thank you for your great module.
              after installing it, it appears on my mirror, but stays on “loading…”.
              Do you maybe know this issue?
              Thanks in advance for your helps.
              Kind regards
              • NiggichN
                Niggich
                Hello Mirrorenthusiasts,
                it is possible to use this module für the WorlCup 2026? Thx
                • 0m4r0
                  0m4r Module Developer @Niggich
                  @Niggich
                  you can either use: https://github.com/0m4r/MMM-SoccerLiveScore and add 2000 to the leagues config parameter: https://github.com/0m4r/MMM-SoccerLiveScore#config
                  or you can update the file:
                  https://github.com/0m4r/MMM-euro2024/blob/main/MMM-euro2024.js
                  to use the worldcup code: 2000
                  (https://docs.football-data.org/general/v4/lookup_tables.html#_league_codes)
                  NiggichN 2 Replies Last reply
                  • NiggichN
                    Niggich @0m4r
                    @0m4r
                    Thank You! It’s working like a charm.
                    • NiggichN
                      Niggich @0m4r
                      @0m4r
                      I play around with the MMM-SoccerLiveScore module. I used the module at a Full HD Touchscreen. Is there a way to scroll the Standings by hand? The Screen is to small to show the full table.
                      THX
                      • 0m4r0
                        @Niggich it should scroll by itself if the config value scrollVertical is set to true.
                        I never tried it on a touch screen…
                        NiggichN 1 Reply Last reply
                        • NiggichN
                          Niggich @0m4r
                          @0m4r No, it doesn’t scroll by itself when i set the value scrollVertical to true. It’s just scrolling the title bar but not the table.
                          • 0m4r0
                            @Niggich ok… I will need to take a look at it, but it may take some time…
