    MMM-euro2024
    30 Posts 8 Posters 9.0k Views 7 Watching
    • 0m4r0 Offline
      0m4r Module Developer @robiv8
      @robiv8 try with this:
      	disabled: false,
      	module: "MMM-euro2024",
      	position: "center",
      	header: "Euro 2024",
      	updateInterval: 60 * 1000,
      	token: "b1e67..myToken..67c8c5",
      https://github.com/0m4r
      • L Offline
        leafarenuk
        Hi guys,
        I cannot get this module to run…
        I also opened an issue in the repo: https://github.com/0m4r/MMM-euro2024/issues/2
        Can somebody from here help me? @0m4r ?
        Thanks in advance
        0m4r0 1 Reply Last reply Reply Quote 0
        • 0m4r0 Offline
          0m4r Module Developer @leafarenuk
          @leafarenuk I replied to you on Git Hub a week ago or so.
          As I have not heard back from you since then, I assume the problem is resolved.
          If not, feel free to get in touch again.
            com1cedric @0m4r
            @0m4r Hello and thank you for your great module.
            after installing it, it appears on my mirror, but stays on “loading…”.
            Do you maybe know this issue?
            Thanks in advance for your helps.
            Kind regards
            • NiggichN Offline
              Niggich
              Hello Mirrorenthusiasts,
              it is possible to use this module für the WorlCup 2026? Thx
              • 0m4r0 Offline
                0m4r Module Developer @Niggich
                @Niggich
                you can either use: https://github.com/0m4r/MMM-SoccerLiveScore and add 2000 to the leagues config parameter: https://github.com/0m4r/MMM-SoccerLiveScore#config
                or you can update the file:
                https://github.com/0m4r/MMM-euro2024/blob/main/MMM-euro2024.js
                to use the worldcup code: 2000
                (https://docs.football-data.org/general/v4/lookup_tables.html#_league_codes)
                NiggichN 2 Replies Last reply Reply Quote 1
                • NiggichN Offline
                  Niggich @0m4r
                  @0m4r
                  Thank You! It’s working like a charm.
                  • NiggichN Offline
                    Niggich @0m4r
                    @0m4r
                    I play around with the MMM-SoccerLiveScore module. I used the module at a Full HD Touchscreen. Is there a way to scroll the Standings by hand? The Screen is to small to show the full table.
                    THX
                    • 0m4r0 Offline
                      @Niggich it should scroll by itself if the config value scrollVertical is set to true.
                      I never tried it on a touch screen…
                      NiggichN 1 Reply Last reply Reply Quote 0
                      • NiggichN Offline
                        Niggich @0m4r
                        @0m4r No, it doesn’t scroll by itself when i set the value scrollVertical to true. It’s just scrolling the title bar but not the table.
                        • 0m4r0 Offline
                          @Niggich ok… I will need to take a look at it, but it may take some time…
