    MMM-euro2024
    30 Posts 8 Posters 15.8k Views 7 Watching
    • 0m4r0
      0m4r Module Developer @sdetweil
      @sdetweil this is done in version 1.0.4
      https://github.com/0m4r
      R S 2 Replies Last reply
        robiv8 @0m4r
        @0m4r
        das log sagt: Please correct syntax errors at or above this line: ReferenceError: b1e6…meinToken…67c8c5 is not defined
        0m4r0 1 Reply Last reply
        • 0m4r0
          0m4r Module Developer @robiv8
          @robiv8 I think your configuration is wrong.
          Is the token wrapped into quotes?
            disabled: false,
            module: 'MMM-euro2024',
            position: 'center',
            header: 'Euro 2024',
              updateInterval: 60 * 1000,
              token: "M4g1cM1rr0r"
          R 1 Reply Last reply
            sdetweil @0m4r
            @0m4r this is what your module config looks like in MMM-Config
            • 0m4r0
              @sdetweil this is good, isn’t it?
                sdetweil @0m4r
                @0m4r yes… it works
                  robiv8 @0m4r
                  @0m4r
                  Hallo.
                  This i my config, as described in GitHub
                  	disabled: false,
                  	module: "MMM-euro2024",
                  	position: "center",
                  	header: "Euro 2024",
                  	token: [b1e67..myToken..67c8c5],
                  Ok Danke,
                  with superscripts it works.
                  Why isn’t that right in GitHub?
                  • 0m4r0
                    @robiv8 try with this:
                    	disabled: false,
                    	position: "center",
                    	token: "b1e67..myToken..67c8c5",
                    • L
                      leafarenuk
                      Hi guys,
                      I cannot get this module to run…
                      I also opened an issue in the repo: https://github.com/0m4r/MMM-euro2024/issues/2
                      Can somebody from here help me? @0m4r ?
                      Thanks in advance
                      • 0m4r0
                        0m4r Module Developer @leafarenuk
                        @leafarenuk I replied to you on Git Hub a week ago or so.
                        As I have not heard back from you since then, I assume the problem is resolved.
                        If not, feel free to get in touch again.
                          com1cedric @0m4r
                          @0m4r Hello and thank you for your great module.
                          after installing it, it appears on my mirror, but stays on “loading…”.
                          Do you maybe know this issue?
                          Thanks in advance for your helps.
                          Kind regards
                          • NiggichN
                            Niggich
                            Hello Mirrorenthusiasts,
                            it is possible to use this module für the WorlCup 2026? Thx
                            • 0m4r0
                              0m4r Module Developer @Niggich
                              @Niggich
                              you can either use: https://github.com/0m4r/MMM-SoccerLiveScore and add 2000 to the leagues config parameter: https://github.com/0m4r/MMM-SoccerLiveScore#config
                              or you can update the file:
                              https://github.com/0m4r/MMM-euro2024/blob/main/MMM-euro2024.js
                              to use the worldcup code: 2000
                              (https://docs.football-data.org/general/v4/lookup_tables.html#_league_codes)
                              NiggichN 2 Replies Last reply
                              • NiggichN
                                Niggich @0m4r
                                @0m4r
                                Thank You! It’s working like a charm.
                                • NiggichN
                                  Niggich @0m4r
                                  @0m4r
                                  I play around with the MMM-SoccerLiveScore module. I used the module at a Full HD Touchscreen. Is there a way to scroll the Standings by hand? The Screen is to small to show the full table.
                                  THX
                                  • 0m4r0
                                    @Niggich it should scroll by itself if the config value scrollVertical is set to true.
                                    I never tried it on a touch screen…
                                    NiggichN 1 Reply Last reply
                                    • NiggichN
                                      Niggich @0m4r
                                      @0m4r No, it doesn’t scroll by itself when i set the value scrollVertical to true. It’s just scrolling the title bar but not the table.
                                      • 0m4r0
                                        @Niggich ok… I will need to take a look at it, but it may take some time…
