    MMM-Multimonth
    calendarmagicmirror2module
    78 Posts 19 Posters 62.7k Views 17 Watching
    • BKeyportB
      MAJOR Update -
      29 Oct 2022 - Start Implementing streamlined CSS, add feature to move weekend around, documentation improvements.
      This update will not break old CSS or code. I’ve made sure any changed CSS includes reference to old CSS for compatibility. Some CSS names are changing to make more sense. Un-needed duplicates are being eliminated.
      New:
      If all you’re doing is changing the appearance, the README.md file has new instructions on how to do this… You can actually delete your old long changes and simply have changes in one css element.
      Now you can move the weekend. See the config table in README.
      Now you can turn on or off the previous/next month display in the month grid regardless of number of months!
      Let me know if you have any bugs or oddities.
      Thanks!
      BKeyportB 1 Reply Last reply
      Reply Quote 2
      • BKeyportB
        Another big update.
        Event visualization is now working. Module will underline in a color of your choice (see css in README.md) for any event pulled from MagicMirror’s default calendar module.
        Other tweaks have occurred. Please read the readme completely to upgrade.
        Thanks!
        MZ-BERM pugslyP 2 Replies Last reply
        • MZ-BERM
          MZ-BER @BKeyport
          Thank you! Is there also an option to disable it or can I only hide that via css?
          • BKeyportB
            BKeyport Module Developer @MZ-BER
            @MZ-BER To be honest, I forgot to add the code to turn it off. Was gonna fix something else and re-release in a couple of days.
            • BKeyportB
              New update to this module: Event visualization is now controllable by calendar.
              Please see github for adjustments - Pay attention to “calNames” .
              As always, module requires default calendar for functionality, but does not require display of said calendar.
              Enjoy!
              – B
              • pugslyP
                pugsly @BKeyport
                @BKeyport
                How do you change the font and size now?
                • BKeyportB
                  BKeyport Module Developer @pugsly
                  @pugsly in your custom.css file, change as desired, everything is based off the MagicMirror fonts:
                  .MMM-Multimonth .settings {
                    --background-dimmed: var(--color-background);
                    --background-weekday: var(--color-background);
                    --background-weekend: cornflowerblue;
                    --background-current: Yellow;
                    --background-header: Green;
                    --background-weekno: grey;
                    --background-dow: var(--color-background);
                    --color-weekday: var(--color-text);
                    --color-weekend: var(--color-background);
                    --color-current: var(--color-background);
                    --color-dimmed: var(--color-text-dimmed);
                    --color-header: var(--color-text-bright);
                    --color-weekno: var(--color-text-bright);
                    --color-dow: var(--color-text);
                    --color-event: Red;
                    --back-rounding: 8px;
                    --alignment: center;
                    --fontsize: --var(--font-size-xsmall);
                  If you’re talking about the undocumented feature, It’s not ready yet, I just had some critical updates caught in the crossfire of forgetting to build on a dev branch. :)
                  Also, you may want to scrub any previous custom.css for the module out and start over, a lot of the module’s css changed when I did the “one entry to rule them all” functionality above, and it may be confused a bit. This was mentioned in an older release.
                    Spinster
                    @BKeyport
                    I find it even after setting the config for monthsVertical: true it is still not showing vertical,
                    Whay could be the problem. Please advice.
                    • BKeyportB
                      BKeyport Module Developer @Spinster
                      @Spinster Indeed. Something seems to have broken. I’ll fix it today.
                      Edit:
                      It appears I deleted it’s CSS. Backed off to fix - Repull the files, in the module folder do
                      git pull
                      and relaunch your mirror, it’ll work now.
                      Starting to recode the project to incorporate the “Undocumented feature” I mentioned in previous git pushes - as well as make it easier to read and do in the future, and I guess I missed that when I redid the CSS.
                        p1lspeda
                        any idea on how I can achieve full background transparency with this module ?
                        Currently this is it:
                        Furthermore I’d like the day marking to have the same rounded edges as the week numbers.
                        How do I achieve that ?
                        Unfortunately I am not very experienced with css, so I most likely do not now how to ask the correct question - sorry for that.
                        • BKeyportB
                          BKeyport Module Developer @p1lspeda
                          @p1lspeda looks like I’ve got some work to do on the CSS - in looking up the solution, I found bugs.
                          In your custom.css (~/MagicMirror/css typically) paste the code below:
                            --color-event: Red;
                            --fontsize: var(--font-size-xsmall);
                          any line that includes “–background” can be set to rgba(255, 255, 255, 0) for transparent.
                          example:
                          ---background-weekday: rgba(255,255,255,0);
                          See: https://www.w3schools.com/html/html_colors_rgb.asp for details.
                          (Note: the rest of the variables can also be set as you like, “back-rounding” for example, adjusts the rounded edges globally [except for current until below is added])
                          For the current day to round the edges properly paste:
                          .MMM-Multimonth .current {
                            border-style: hidden;
                            border-radius:  var(--back-rounding);
                            border-color: var(--background-current);
                            background-color: var(--background-current);
                            color: var(--color-current);
                          P 1 Reply Last reply
                            p1lspeda @BKeyport
                            @BKeyport said in MMM-Multimonth:
                            You are a star!
                            Thanks - I got the rounded edges working.
                            As for full transparency - we’re not quite there yet.
                            CSS:
                             /*  --background-color: transparent; */
                              --background-dimmed: rgba(255,255,255,0); /* var(--color-background);     /* For dimmed (previous/next month in current grid), use the global background color */
                              --background-weekday: rgba(255,255,255,0); /*var(--color-background);    /* For normal days, use global background */
                              --background-weekend: rgba(255,255,255,0); /*var(--color-background);    /* For the days defined as your weekend, change the background to cornflowerblue */
                              --background-current: Grey;                       /* for the current day, change the background to yellow */
                              --background-header: rgba(255,255,255,0); /*var(--color-background);     /* for the month and year line, use green background */
                              --background-weekno: Grey;                        /* for the week number, use a grey background */
                              --background-dow: rgba(255,255,255,0); /* var(--color-background);        /* For the days of the week, use global background */
                              --color-weekday: var(--color-text);               /* For normal days, use global normal text */
                              --color-weekend: var(--color-background);         /* For the days defined as your weekend, change the text to the background color */
                              --color-current: var(--color-background);         /* for the current day, change the text to the background color */
                              --color-dimmed: var(--color-text-dimmed);         /* For dimmed (previous/next month in current grid), use the global dimmed text color */
                              --color-header: var(--color-text-bright);         /* for the header lines, use the global bright text color */
                              --color-weekno: var(--color-text-bright);         /* for the week numbers, use the global bright text color */
                              --color-dow: var(--color-text);                   /* for the days of the week header, use the global text color */
                              --color-event: Red;                               /* For events, the color of the underline */
                              --back-rounding: 8px;                             /* Set the radius of the background rounded edges. See documentation for border-radius elsewhere */
                              --alignment: center;                              /* Adjust the text alignment */
                            results in:
                            Did I oversee something ?
                              sdetweil @p1lspeda
                              @p1lspeda full transparency,… isn’t the background black?
                              what are you expecting?
                              • BKeyportB
                                @sdetweil I’m assuming he wants to show a background image behind it.
                                I have error(s) in my CSS.
                                The settings don’t work. I think I reverted a bit too far on my end.
                                @p1lspeda - Give me 24-48 hours, I’ll fix this up by Sunday night, Los Angeles time. Expect an update, of which, will include removal of the .MMM-Multimonth .current tag in custom.css - it won’t be needed.
                                  sdetweil @BKeyport
                                  @BKeyport remember to use the developers window
                                  • BKeyportB
                                    @sdetweil It’s easy fixes. I just reverted to a point where I had the proto-settings but not the actual use of them. 🤪🤪🤪
                                    • BKeyportB
                                      @p1lspeda I have it fixed. Remove the old from custom.css and replace it with the following and then set whichever backgrounds you’d like as before. (rgba(255, 255, 255, 0);)
                                      Thanks for catching.
                                        --background-week: var(--color-background);
                                        --color-day: var(--color-text);
                                        --color-event: Red;
                                      the custom “.current” part is also not needed.
                                        p1lspeda @BKeyport
                                        @BKeyport
                                        Thanks!
                                        Either I am doing something wrong (and cannot see it) or there is still an issue with getting the module fully transparent.
                                        After the update and my custom.css this is what it looks like:
                                        custom.css:
                                        /* MMM-Multimonth */
                                        as you can see (my background is not black, it’s grey-ish atm).
                                        Thanks for all your help
                                        • BKeyportB
                                          You’re missing one or two variables. I redid them. add
                                          --background-week: rgba(255, 255, 255, 0);
                                          and it’ll snap into shape, assuming you’ve pulled the latest off github.
                                          Double check your list against my new one. Make sure all of them are there.
                                            p1lspeda @BKeyport
                                            @BKeyport
                                            You sir, are great.
                                            Thank you for being so patient.
                                            • 4 / 4
