    MM2 launch without internet
    11 Posts 5 Posters 7.4k Views 4 Watching
    • yawnsY Offline
      yawns Moderator @cowboysdude
      @cowboysdude said in MM2 launch without internet:
      Some of it yes… like the clock but the rest if primarily internet data driven…
      Won’t even the clock reset to some dummy value? The raspberry does not have a realtime clock and does not know date and time once power was removed.
      It uses NTP to update its clock
        cianoo45
        Could I plug one of those USB wifi things into it, would that work?
        • yawnsY Offline
          yawns Moderator
          You could, but that won’t change anything, because you still need to make sure it connects to the wifi around.
          Or are you talking about a wireless wan (umts/3g) stick?
            cianoo45
            Yeah one of those little router things for 3g
            • yawnsY Offline
              yawns Moderator
              I never set up one of these on a raspberry, but that should work if reception is good.
              • brobergB Offline
                broberg Project Sponsor
                why not connect it to your own network first and when ready just connect it to hers ?
                  cianoo45 @broberg
                  Because I’m shipping it to her so i cant be there to set it up
                  brobergB aschulz90A 2 Replies Last reply Reply Quote 0
                  • brobergB Offline
                    broberg Project Sponsor @cianoo45
                    @cianoo45 Hmm, Okey, so you want it to connect right out of the box. Then I guess a 3g/4g modem would do the trick (unless it acts up and lacks signal at her place).
                    but when configuring and assembling your mirror just use your own network to start with.
                    If I were you I would get someone to configure the wifi on the pi for her when it has arrived.
                    • aschulz90A Offline
                      aschulz90 @cianoo45
                      @cianoo45
                      That is actually one of the use case i am covering with my app and BLE module:
                      https://forum.magicmirror.builders/topic/1497/magicmirrorapp/2
                      One of the features is, that you can connect a MagicMirror to a wifi network over bluetooth.
                      Only downside is, that there is currently only an app for Android and not for IOS or Windows Phone (i currently have neither, so can’t develop one in the near future).
