    Standardmodule "updatenotification"
    13 Posts 6 Posters 8.4k Views 5 Watching
    • lolobyteL Offline
      lolobyte
      @MichMich
      Why is this module not mentioned in your description on MM2 website?
      https://github.com/MichMich/MagicMirror
      @all
      Can somebody explain me how this module work and why it does’t run in my configuration? 15 other Modules running like a oiled machine!
      • cowboysdudeC Offline
        This should be in your config.js file:
        		module: "updatenotification",
        		position: "top_bar"
        If it’s not then you aren’t using the current MM2…
        If you’re not I would suggest you [from a terminal window] type: git pull
        to update your software…
        lolobyteL 1 Reply Last reply Reply Quote 0
        • lolobyteL Offline
          lolobyte @cowboysdude
          @cowboysdude
          Hello, i use mm2 v2.1.0.
          The only thing i changed was the position to display the module and the position inside the config. It’s on the 3-rd last position.
                              "module": "updatenotification",
                              "position": "lower_third",
                              "classes": "small bright",
                              "disabled": false,
                              "$$hashKey": "object:2049"
                              "module": "MMM-RSS-FEED",
                        ............... and so on.
          • lolobyteL Offline
            lolobyte
            Did somebody know how often this module are checking for updates?
            Every hour or every day once?
            • yawnsY Offline
              yawns Moderator @lolobyte
              @lolobyte said in Standardmodule “updatenotification”:
              The readme says every 10 minutes by default
              • tosti007T Offline
                tosti007 Module Developer
                The module first takes all the module names and then filters out the modules that are default, not hosted by git or for which git errors.
                It does that only once when the mirror starts.
                After that it does a fetch request and checks how many commits it’s behind for the remaining modules. If this is more than one it shows something on the screen. And lastly it sets a timer for the next loop.
                If there is anything don't hesitate to contact me!
                ProfileSwitcher, TouchNotifications
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @lolobyte
                  @lolobyte i can see the hashkey property, this was a bug on my earlier prototype of the app. can you check when you change some settings for this module through the app if the haskey property is gone?
                  • lolobyteL Offline
                    lolobyte @strawberry 3.141
                    @strawberry-3.141
                    You mean the haskkey will be removed automatically by the new app or is that my part of the job?
                      @lolobyte it should be removed by the app if you change settings of this module on your phone and after that sync it with the mirror, otherwise this bug still persists and i have to recheck it. with the first prototype i wasn’t aware of that this internal reference was saved in the storage to the config in one line i didn’t spot it in the first place.
                      • lolobyteL Offline
                        @strawberry-3.141
                        Ok, i’ll try this lather after i check out my problem with the updatenotification.
                        At first i must find a module witch i use and witch was recently updated. :-(
                          @lolobyte you can checkout a previous version of a module through git
                          git checkout THECOMMITID
                          for the fuel module you could do this
                          git checkout 7aaac4bd2cc736d0ed3a96a41681e791b95bb77f
                          • lolobyteL Offline
                            @strawberry-3.141 wow, what number is that?
                            Where is it noticed?
                            MichMichM 1 Reply Last reply Reply Quote 0
                            • MichMichM Offline
                              MichMich @lolobyte
                              @lolobyte: it’s a default module which in the example config starting from V2.1.0 - So only when upgrading from a previous version, You need to add it manually. It’s in the changelog somewhere. But indeed, It might need some better documentation. Feel free to send PR’s to do this. :)
