    MMM-GooglePhotos
    294 Posts 56 Posters 409.5k Views 59 Watching
      megagprime @orayoflighto
      @orayoflighto awesome thanks guys but some of us are really dumb and I can’t figure this out. No new get token no matter how hard I try and I don’t know how to do it on my local pc… If I copy the file over I get the following ![alt text](image url)
        @orayoflighto i tried to do this but i am too dumb, how do i clone on local pc ? and when i do put v2 in folder and node i get this error 9fdb2fe4-798b-4de7-90fd-ea673cdfbd7f-image.png
          sdetweil @megagprime
          @megagprime to get a pull request
          in the existing module folder do
          git fetch origin pull/#/head:local_branch_name
          replace # w 146
          and pick a name for branch name
          the when that completes (no message)
          do
          git checkout whatever name u used
          now your photos module is using the pull request version
          then the normal instructions should work
          edit : shows what u get for not checking and trusting some ‘now old’ post on the internet!
          M 1 Reply Last reply
            megagprime @sdetweil
            @sdetweil admin@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ pull/<145>/head:< g2 >
            bash: syntax error near unexpected token `145’
              @megagprime no <>
              • L
                Lilleberg
                I have just installed MagicMirror on my RaspberryPi and are now playing around trying to tweak my screen to my needs. Just now I want to show a slideshow of one of my albums in the top region of the screen. I have my screen vertically.
                So the photo should show cover the whole top region from edge to edge, and maybe 1/3 down from the top edge. Trying to use the top_bar position, but the photos then are shown with a padding on the left side and in the top, and are not resized to fit inside the region. Anybody that can show how this can be done? Maybe in the css file?
                B 1 Reply Last reply
                  bhepler Module Developer @Lilleberg
                  @Lilleberg Try using the upper_third position for your pictures. That may be closer to what you want.
                    1a2a3a
                    hi, does anyone know how to configure the sizing of the gphoto?
                    im trying to make the photo not full screen, but to perhaps just the top portion of the mirror or to some size of the mirror (havent really decided on the location) but having trouble sizing them.
                    i changed the showWidth and showHeight but while they make the picture smaller, the quality seems to be reduce?
                    i have also added #GPHOTO in CSS with width and height at 50% but it still feel like its showing full screen…
                      1a2a3a
                      Did something change here? I’m getting an invalid module position found for this configuration. My position is “fullscreen”. It used to be working fine…?
                        sdetweil @1a2a3a
                        @1a2a3a yes we added checking for position names
                        its fullscreen_above and fullscreen_below
                        here is the list of MagicMirror module positions
                        https://docs.magicmirror.builders/modules/configuration.html
                        1 1 Reply Last reply
                          1a2a3a @sdetweil
                          @sdetweil which option is the same as the previous ‘fullscreen’?
                            sdetweil @1a2a3a
                            @1a2a3a fullscreen_below
                            • 11
                            • 12
                            • 13
                            • 14
                            • 15
                            • 15 / 15
