    MMM-OpenWeatherForecast deactivate Alerts or change to german
    mmm-openweatherforecastweatheralertsdeactivate
    9 Posts 5 Posters 1.9k Views 5 Watching
      chichi1887
      I am using the MMM-OpenWeatherForecast module for MagicMirror and would like to either disable the alerts or set them to German. I have tried many different configurations but cannot figure out how to resolve this issue. Here is my current configuration:
      module: "MMM-OpenWeatherForecast",
      header: "Wetter",
          apiBaseURL: "https://api.openweathermap.org/data/3.0/onecall?",
          apikey: "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX",
          latitude: "XX.XXX",
          longitude: "XX.XXX",
          units: "metric",
          language: "de",
          iconset: "5c",
          showAlerts: false,
          colored: true,
          concise: true,
          requestDelay: 2000,
          showFeelsLikeTemp: false,
          displayKmhForWind: true,
          label_hourlyTimeFormat: "k:mm[h]",
          forecastLayout: "tiled",
          maxHourliesToShow: "6",
          hourlyForecastInterval: "2",
          maxDailiesToShow: "3",
          label_sunriseTimeFormat: "k:mm[h]",
          showCurrentConditions: true,           // Show current conditions
          showSummary: true,                     // Show summary
          showExtraCurrentConditions: true,      // Show extra current conditions
          extraCurrentConditions: {
              highLowTemp: true,                 // High/Low temperature
              precipitation: true,               // Precipitation
              sunrise: true,                     // Sunrise
              sunset: true,                      // Sunset
              wind: true,                        // Wind
              barometricPressure: false,         // Barometric pressure
              humidity: true,                    // Humidity
              dewPoint: false,                   // Dew point
              uvIndex: false,                    // UV index
              visibility: false                  // Visibility
        sdetweil @chichi1887
        @chichi1887 don’t know which version of the module you are using, but the one from Tom
        shows in the njk (display template)
            {% if config.showSummary %}
              <div class="summary-wrapper small">
                <div class="summary">{{ forecast.summary }}</div>
                {% for alert in forecast.alerts %}
                  <div class="weather-alert">
                    <span class="weather-alert-title">{{ alert.event }}</span>
                    <span class="weather-alert-description">{{ alert.description }}</span>
                    <span class="weather-alert-source">{{ alert.sender_name }}</span>
                  </div>
                {% endfor %}
              </div>
            {% endif %}
        so if showSummary is true, the alerts could be shown… AFTER the forecast.summary
        if you don’t need/want the forecast summary , set showSummary:false,
        if you DO want the summary, but not the notices, then you will have to use css (in css/custom.css add)
        .MMM-OpenWeatherForecast  .weather-alert {
             display:none;
        I think this data comes back from OpenWeather in english
        regardless of the language set in the api request
        C C 2 Replies Last reply Reply Quote 1
          chichi1887 @sdetweil
          @sdetweil T
          Thank u so much. It woks perfect. Have a Great weekend
            com1cedric @sdetweil
            Dear Sam, are you sur that the language is really checked by this module when asking open weather?
            If yes, I will ask openweather directly.
            With this example on Google, the messages are shown in the correct language (in this case FR), so that the provider (meteoswiss) publishes it in FR.
            But on the mirror with this module, it still only appears in EN.
            Thanks for your good advise and have a good evening.!
            Cédric
            C S 2 Replies Last reply Reply Quote 0
              com1cedric @com1cedric
              @com1cedric
              Here the confirmation from openweather:
                sdetweil @com1cedric
                @com1cedric < MMM-OpenWeatherForecast you will have to ask the author via on issue on the module github page
                the default weather module ~/MagicMirror/modules/default/weather
                module:“weather”
                is the one I know about (but still have to depend on others to fix)
                  @sdetweil ok, thanks !
                  • wishmaster270W Offline
                    wishmaster270 Module Developer @com1cedric
                    @com1cedric
                    as I wrote in the issue you opened the module also calls the api with the correct language settings.
                    I the description of the language setting of OpenWeather there is a hint that some alert providers do not provide translations.
                    • I Offline
                      itsmemario1
                      @sdetweil said in MMM-OpenWeatherForecast deactivate Alerts or change to german:
                      Can you tell me which MMM-OpenWeatherForecast you are currently using, I can’t get mines to work for months.
