    MMM-OpenWeatherForecast deactivate Alerts or change to german
    mmm-openweatherforecastweatheralertsdeactivate
    9 Posts 5 Posters 1.7k Views 5 Watching
      chichi1887 @sdetweil
      @sdetweil T
      Thank u so much. It woks perfect. Have a Great weekend
        com1cedric @sdetweil
        Dear Sam, are you sur that the language is really checked by this module when asking open weather?
        If yes, I will ask openweather directly.
        With this example on Google, the messages are shown in the correct language (in this case FR), so that the provider (meteoswiss) publishes it in FR.
        But on the mirror with this module, it still only appears in EN.
        Thanks for your good advise and have a good evening.!
        Cédric
        C S 2 Replies Last reply Reply Quote 0
          com1cedric @com1cedric
          @com1cedric
          Here the confirmation from openweather:
            sdetweil @com1cedric
            @com1cedric < MMM-OpenWeatherForecast you will have to ask the author via on issue on the module github page
            the default weather module ~/MagicMirror/modules/default/weather
            module:“weather”
            is the one I know about (but still have to depend on others to fix)
              @sdetweil ok, thanks !
              • wishmaster270W Offline
                wishmaster270 Module Developer @com1cedric
                @com1cedric
                as I wrote in the issue you opened the module also calls the api with the correct language settings.
                I the description of the language setting of OpenWeather there is a hint that some alert providers do not provide translations.
                • I Offline
                  itsmemario1
                  @sdetweil said in MMM-OpenWeatherForecast deactivate Alerts or change to german:
                  Can you tell me which MMM-OpenWeatherForecast you are currently using, I can’t get mines to work for months.
