    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      Decimeter9667 @MMRIZE
      @MMRIZE
      I’m working in the same situation: using an old iPad and trying to conserve space. I used this transform you posted way back in this thread:
      /* In your config */
      eventTransformer: (ev) => {
        if (!ev.isFullday) {
          let t = new Date(ev.startDate)
          let time = (t.getMinutes() === 0) ? String(t.getHours()) : String(t.getHours() + ':' + t.getMinutes())
          ev.title = `<span class="myTime">${time}</span> ${ev.title}`
        return ev
      That works great, but how can I get it to display the hour in 12h, not 24h?
        sdetweil @Decimeter9667
        @Decimeter9667 time see theIMG_0598.png eventTimeOptions
          Decimeter9667 @sdetweil
          @sdetweil Hmm… are you sure that works in the context of the transform I showed? eventTimeOptions doesn’t seem to change it.
            @Decimeter9667
            you are doing it raw. Date.getHours() returns 0-23
            so YOU have to check , and substract 12 if over 12
              @sdetweil Thanks. For anyone else looking to do this, here’s how I modified the code:
                                  const amPm = t.getHours() >= 12 ? 'p' : 'a';
                                  let time = (t.getMinutes() === 0) ? String(t.getHours() % 12 || 12) : String( (t.getHours() % 12 || 12)  + ':' + t.getMinutes())
                                  ev.title = `<span class="myTime">${time}${amPm}</span> ${ev.title}`
                              return ev
                @Decimeter9667 you could have set the hour in a local variable when you did the am/pm test
                // assume am.
                // of course you could reverse this if most of the events are in the afternoon
                let amPm='a'
                let hour=t.getHours()
                     if(hour >= 12) {
                             amPm= 'p';
                             hour-= 12
                then not have 2 more calls to getHour()
                performance things creep in all the time… (as you might be doing this for all events…)
                • A
                  anonymous321
                  Hello, I’m new to MagicMirror trying to build my first. I’m having an issue with any events showing up. When I run the attached code I get a blank calendar. However when I run the regular calendar I see all the events. Am I doing something wrong?
                  			module: "MMM-MonthlyCalendar",
                  			header: "Family Calendar",
                  			position: "bottom_bar",
                  				updatesEvery: 30,
                  				weeksInFuture: 5,
                  				mode: "fourWeeks",
                  				firstDayofWeek: "sunday",
                                                 //maximumEntries: "10000", <--- " I saw in one of the forums that this could help but it did not."
                  					url: "https://calendar.google.com/calendar/ical/******basic.ics",
                  					priority: 1,
                  Here is a screenshot of the regular calendar.
                  This is what it looks like with MMM-CalendarExt3
                    sdetweil @anonymous321
                    @anonymous321 2 things
                    what MagicMirror version is this? latest?
                    see this https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
                    • A
                      anonymous321
                      I think its the latest. I just installed it two nights ago. How would I check the version number?
                        @anonymous321 look at the messages at startu
                        if using pm2 then
                        pm2 logs --lines=xxx
                        xxx is number of most recent lines, default 15
                        or look inside the package.json file
                        • A
                          anonymous321
                          Version 1.9.4
                            @anonymous321
                            MagicMirror version
                            the fix is in the MagicMirror calendar module
                              p1lspeda
                              I’ve just come across this great module, but I cannot quite get it to work.
                              My default calendar module shows multiple google-calendar based calendars/entries.
                              This works fine.
                              However: CX3 only shows the ‘work’ calendar and I do not know why.
                              Can anybody point me in the right direction ?
                              Edit: so I got it working (somehow) but the calendar entries take forever to show up in CX3.
                              Why is that ?
                              [2025-02-07 12:31:47.169] [INFO]  Calendar-Fetcher: Broadcasting 12 events from https://calendar.google.com/calendar/ical...
                              [2025-02-07 12:31:47.701] [INFO]  Calendar-Fetcher: Broadcasting 27 events from https://calendar.google.com/calendar/ical...
                              [2025-02-07 12:31:48.719] [INFO]  Calendar-Fetcher: Broadcasting 70 events from https://calendar.google.com/calendar/ical...
                              [2025-02-07 12:31:49.691] [INFO]  Calendar-Fetcher: Broadcasting 42 events from https://calendar.google.com/calendar/ical...
                              [2025-02-07 12:31:50.976] [INFO]  Calendar-Fetcher: Broadcasting 36 events from https://calendar.google.com/calendar/ical...
                              [2025-02-07 12:31:56.453] [INFO]  Calendar-Fetcher: Broadcasting 93 events from https://calendar.google.com/calendar/ical...
                              my CX3 config:
                                                      module: "MMM-CalendarExt3",
                                                      title: "",
                                                              mode: "week",
                                                              weekIndex: "0",
                                                              weeksInView: "2",
                                                              instanceId: "basicCalendar",
                                                              //locale: 'de-DE',
                                                              maxEventLines: 8,
                                                              firstDayOfWeek: 1,
                                                              calendarSet: null,
                              my default calendar module config:
        position: "bottom_right",
        header: "Calendar",
        broadcastPastEvents: true,
        colored: false,
        coloredSymbolOnly: false,
        maximumEntries: 8,
        maxTitleLength: 50,
        maximumNumberOfDays: 180,
        timeFormat: "relative",
        getRelative: 60 * 24,
        urgency: 60,
        url: 'https://calendar.google.com/calendar...',
        symbol: 'calendar', // MAINZ 05 CALENDAR
        colour: 'white',
        symbol: 'calendar', // MAIN GOOGLE CALENDAR
        colour: 'white',
        symbol: 'calendar', // FORMULA 1 CALENDAR
        colour: 'white',
        symbol: 'calendar', // EB MAINZ
        colour: 'white',
        symbol: 'calendar', // PRO RUNDE
        colour: 'white',
        symbol: 'calendar', // BUSINESS TRIPS
        colour: 'white',
                                sdetweil @p1lspeda
                                @p1lspeda i would start with commenting out the calendarSet:null
                                  p1lspeda @sdetweil
                                  thanks for the help.
                                  Did that - no change.
                                  Same problem and I have no idea where to start an look
                                  Edit: HA ! I decreased the refreshIntervall and it seems as that did the trick - I could have probably just waited 30min (but I’m impatient)
                                    sdetweil @p1lspeda
                                    @p1lspeda ok. nice work.
                                    Ext3 attempts to not flash the screen on every update. the individual calendar data arrive at different times
                                    so the waitFetch value is used to decide when to display initially, and refreshInterval after that
                                    waitFetch defaults to 5 seconds
                                    so this means some data arrived after 5 seconds (waitFetch)
                                      p1lspeda
                                      Re: MMM-CalendarExt3
                                      Next (easy) question:
                                      My CX3 module doesn’t have symmetrical borders (left & right), i.e. the left border is smaller than the right border.
                                      I want to maximize the width or at least have symmetrical borders.
                                      Border = distance between module edge and display edge
                                      See the screenshot:
                                      How can I adjust these in my custom.css ?
                                      My custom.css includes
                                      body {
                                              margin: 10px;
                                              position: absolute;
                                              height: calc(100% - 30px);
                                              width: calc(100% - 30px);
                                      A hint/clue/idea would be very much appreciated.
                                      Thanks !
                                        sdetweil @p1lspeda
                                        @p1lspeda we already set margins and borders
                                        see css/main.css
                                        sounds like your 7 day width is not symmetrical to the position the module is in
                                        CX3 has extensive classes that should allow you to position it properly
                                        also your css entry whacks the entire page, not just your module config.
                                        see the position layout in the doc here
                                        html is typically reading anchored left for ltr langusgrd abd right for rtl langusges, so you should br able to increase the left edge number to shift the whole image right
                                        .CX3 {
                                           left:20px;
                                        this left is relative to its configured position
                                          p1lspeda @sdetweil
                                          @sdetweil Thanks for pointing me in the right direction.
                                          Seems I need to play around with css.
                                            sdetweil @p1lspeda
                                            @p1lspeda see the second link below in my signature for using the developers window elements tan
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 31 / 35
