    Help with calendar
    27 Posts 2 Posters 6.9k Views 2 Watching
    • G Offline
      gerbenz
      Re: My family dashboard
      Who can help me?
      How can i scale the MMM-CalendarEXT3 to bigger one,
      And the weeks that past , hoe to remove from
      The calendar. I want only view 7 days.
      And is it possible to hide the original calendar.
      Sorry for questions but i’m newbie.
        sdetweil @gerbenz
        @gerbenz hide the default calendar
        comment out its position setting on config.js
        // position: … whatever
        maybe you want week view instead of month view??
        mode:“week”, // instead of month
        weeksInView: 1
        size, that is all CSS (styling, which goes in MagicMirror/css/custom.css)
        the doc for Ext3 gives extensive info on css values…
        note the position you set it in also impacts its size…
        see this part of the module config for understanding the module positions
        https://docs.magicmirror.builders/modules/configuration.html#position
        • G Offline
          gerbenz @sdetweil
          @sdetweil ss
          @sdetweil said in Help with calendar:
          weeksInView: 1
          I hide the original calendar, butt then the MMM-CalendarEXT3 is empty.
          when i place back the original then its filled
            sdetweil @gerbenz
            @gerbenz is this the latest MM release 2 .30
            did you put on the fix?
            see https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
            • G Offline
              gerbenz @sdetweil
              done,but not working. stays empty
                sdetweil @gerbenz
                @gerbenz can you show me output of
                git branch
                • G Offline
                  gerbenz @sdetweil
                  • _fix_clipping
                    master
                    sdetweil @gerbenz
                    @gerbenz ok, can you show the output of starting MagicMirror
                    if you are using pm2 then
                    pm2 logs --lines=xxx
                    xxx is the number of most recent lines , default 15
                    you may need more
                    careful the cal broadcast message contains the full url so coukd expose personal info
                    is it broadcasting events ?
                    • G Offline
                      gerbenz @sdetweil
                      only see events when i place orriginal callendar too,
                      then the addon works good.
                      wierd.
                        sdetweil @gerbenz
                        @gerbenz no idea
                        can you show the calendar configuration
                        (xxx out the urls but don’ change anything else)
                        you ARE just commenting out the calendar position line, right??
                        mine looks like this
                                classes: "page1",
                                //position: "top_left",
                                order: "*",
                                index: 1,
                                label: "instance 1",
                                  broadcastPastEvents: true,
                                  fetchInterval: 120000,
                                  urgency: 0,
                                  dateFormat: "Do.MMM, HH:mm",
                                  fullDayEventDateFormat: "Do.MMM",
                                  getRelative: 0,
                                  hidePrivate: true,
