    Help with calendar
    27 Posts 2 Posters 7.1k Views 2 Watching
    • G Offline
      gerbenz @sdetweil
      @sdetweil ss
      @sdetweil said in Help with calendar:
      @gerbenz hide the default calendar
      comment out its position setting on config.js
      // position: … whatever
      maybe you want week view instead of month view??
      mode:“week”, // instead of month
      weeksInView: 1
      size, that is all CSS (styling, which goes in MagicMirror/css/custom.css)
      the doc for Ext3 gives extensive info on css values…
      note the position you set it in also impacts its size…
      see this part of the module config for understanding the module positions
      https://docs.magicmirror.builders/modules/configuration.html#position
      I hide the original calendar, butt then the MMM-CalendarEXT3 is empty.
      when i place back the original then its filled
        sdetweil @gerbenz
        @gerbenz is this the latest MM release 2 .30
        did you put on the fix?
        see https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
        • G Offline
          gerbenz @sdetweil
          done,but not working. stays empty
            sdetweil @gerbenz
            @gerbenz can you show me output of
            git branch
            • G Offline
              gerbenz @sdetweil
              • _fix_clipping
                master
                sdetweil @gerbenz
                @gerbenz ok, can you show the output of starting MagicMirror
                if you are using pm2 then
                pm2 logs --lines=xxx
                xxx is the number of most recent lines , default 15
                you may need more
                careful the cal broadcast message contains the full url so coukd expose personal info
                is it broadcasting events ?
                • G Offline
                  gerbenz @sdetweil
                  only see events when i place orriginal callendar too,
                  then the addon works good.
                  wierd.
                    sdetweil @gerbenz
                    @gerbenz no idea
                    can you show the calendar configuration
                    (xxx out the urls but don’ change anything else)
                    you ARE just commenting out the calendar position line, right??
                    mine looks like this
                            classes: "page1",
                            //position: "top_left",
                            order: "*",
                            index: 1,
                            label: "instance 1",
                              broadcastPastEvents: true,
                              fetchInterval: 120000,
                              urgency: 0,
                              dateFormat: "Do.MMM, HH:mm",
                              fullDayEventDateFormat: "Do.MMM",
                              getRelative: 0,
                              hidePrivate: true,
                    • G Offline
                      gerbenz @sdetweil
                      		module: "MMM-CalendarExt3",
                      		header: "Afspraken",
                      		position: "middle_center",
                                  mode: "week",
                                  weeksInView: 1,
                                  weekIndex: 0,
                                  instanceId: "basicCalendar",
                                  locale: 'nl-NL',
                                  maxEventLines: 5,
                                  firstDayOfWeek: 0,
                      			startDayIndex: 0,
                                  displayEndTime: true,
                      	        calendarSet: null,
                                  refreshInterval: 60000,
                      		    fontsize: '30px',
                      		    eventHeight: '30px',
                      		    useWeather: false,
                      		    skipPassedEventToday: true,
                      					name: "werk stefnie",
                      					color: "red",
                      					url: "https://xxxx"
                                          url: "webcal://p181-caldav.icloud.com/published/xxxx",
                                          url: "webcal://p175-caldav.icloud.com/published/xxxx",
                        sdetweil @gerbenz
                        @gerbenz no, the default calendar, where the events come from
