    Help with calendar
    27 Posts 2 Posters 9.2k Views 2 Watching
    • G Offline
      gerbenz @sdetweil
      @sdetweil ss
      @sdetweil said in Help with calendar:
      @gerbenz hide the default calendar
      comment out its position setting on config.js
      // position: … whatever
      maybe you want week view instead of month view??
      mode:“week”, // instead of month
      weeksInView: 1
      size, that is all CSS (styling, which goes in MagicMirror/css/custom.css)
      the doc for Ext3 gives extensive info on css values…
      note the position you set it in also impacts its size…
      see this part of the module config for understanding the module positions
      https://docs.magicmirror.builders/modules/configuration.html#position
      I hide the original calendar, butt then the MMM-CalendarEXT3 is empty.
      when i place back the original then its filled
        sdetweil @gerbenz
        @gerbenz is this the latest MM release 2 .30
        did you put on the fix?
        see https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
        • G Offline
          gerbenz @sdetweil
          done,but not working. stays empty
            sdetweil @gerbenz
            @gerbenz can you show me output of
            git branch
            • G Offline
              gerbenz @sdetweil
              • _fix_clipping
                master
                sdetweil @gerbenz
                @gerbenz ok, can you show the output of starting MagicMirror
                if you are using pm2 then
                pm2 logs --lines=xxx
                xxx is the number of most recent lines , default 15
                you may need more
                careful the cal broadcast message contains the full url so coukd expose personal info
                is it broadcasting events ?
                • G Offline
                  gerbenz @sdetweil
                  only see events when i place orriginal callendar too,
                  then the addon works good.
                  wierd.
                    sdetweil @gerbenz
                    @gerbenz no idea
                    can you show the calendar configuration
                    (xxx out the urls but don’ change anything else)
                    you ARE just commenting out the calendar position line, right??
                    mine looks like this
                            classes: "page1",
                            //position: "top_left",
                            order: "*",
                            index: 1,
                            label: "instance 1",
                              broadcastPastEvents: true,
                              fetchInterval: 120000,
                              urgency: 0,
                              dateFormat: "Do.MMM, HH:mm",
                              fullDayEventDateFormat: "Do.MMM",
                              getRelative: 0,
                              hidePrivate: true,
                    • G Offline
                      gerbenz @sdetweil
                      		module: "MMM-CalendarExt3",
                      		header: "Afspraken",
                      		position: "middle_center",
                                  mode: "week",
                                  weeksInView: 1,
                                  weekIndex: 0,
                                  instanceId: "basicCalendar",
                                  locale: 'nl-NL',
                                  maxEventLines: 5,
                                  firstDayOfWeek: 0,
                      			startDayIndex: 0,
                                  displayEndTime: true,
                      	        calendarSet: null,
                                  refreshInterval: 60000,
                      		    fontsize: '30px',
                      		    eventHeight: '30px',
                      		    useWeather: false,
                      		    skipPassedEventToday: true,
                      					name: "werk stefnie",
                      					color: "red",
                      					url: "https://xxxx"
                                          url: "webcal://p181-caldav.icloud.com/published/xxxx",
                                          url: "webcal://p175-caldav.icloud.com/published/xxxx",
                        sdetweil @gerbenz
                        @gerbenz no, the default calendar, where the events come from
                        • G Offline
                          gerbenz @sdetweil
                          			coloredText: true,
                                      broadcastPastEvents: false, // <= IMPORTANT to see past events
                          			fetchInterval: 1000 * 60 * 1,
                          					symbol: "werk stefnie",
                          					url: "xxxxx"
                                              symbol: "Stefanie",
                                              url: "webcal://p181-caldav.icloud.com/published/xxxxx",
                                              symbol: "Gezin",
                                              symbol: "Amber",
                                              symbol: "Luna",
                                              url: "webcal://p181-caldav.icloud.com/published/xxxxxx",
                                              symbol: "Gerben",
                                              url: "webcal://p175-caldav.icloud.com/published/xxxxx",
                            sdetweil @gerbenz
                            @gerbenz fetch every 60 seconds?
                            might be a spammer
                            how about try 5 mins
                            and comment out the position
                            Ext3 tries not to flash the screen w updates, you are probably running into that with so frequent updates and so many cals all at different times
                            you can look at the pm2’log and see timestamps when events are sent from each cal
                            • G Offline
                              gerbenz @sdetweil
                              updating the screen works good.
                              all calendars are working.
                              butt when i hide the standard calendar then te addon calandar lost the events and is empty
                                sdetweil @gerbenz
                                @gerbenz but thats not how it works! the calendar module just keeps sending even when no position is specified.
                                i have both setup on my system and it works perfectly
                                maybe 10releases ago modules w no
                                position would not be run
                                you should be able to see the broadcasts go out in the logs
                                  @gerbenz show me the default calendar config whenExt3 is not working.
                                  • G Offline
                                    gerbenz @sdetweil
                                    I changed nothing, only possition to unknown dor the standard calendar.
                                    And then the addon calendar is show no events
                                      sdetweil @gerbenz
                                      @gerbenz no, NOT unknown, thats invalid, module will not be loaded (there will be an error in the log about this)
                                      just add
                                      to the front of the line w position on it to comment it out
                                      see mine that i posted earlier
                                      https://forum.magicmirror.builders/post/123049
                                      • G Offline
                                        gerbenz @sdetweil
                                        Okay i give it a try tomorrow.
                                        Thanks so far for youre help.
                                        I lett it know if it works.
                                        And do i need delete the adresses from the standard calendar or not?
                                          sdetweil @gerbenz
                                          @gerbenz address?
                                          look at my example
                                          • G Offline
                                            gerbenz @sdetweil
                                            I mean urls,
                                            I have in both the same urls for the calendar
