    Help with calendar
    27 Posts 2 Posters 9.9k Views 2 Watching
    • G
      gerbenz
      Re: My family dashboard
      Who can help me?
      How can i scale the MMM-CalendarEXT3 to bigger one,
      And the weeks that past , hoe to remove from
      The calendar. I want only view 7 days.
      And is it possible to hide the original calendar.
      Sorry for questions but i’m newbie.
        sdetweil @gerbenz
        @gerbenz hide the default calendar
        comment out its position setting on config.js
        // position: … whatever
        maybe you want week view instead of month view??
        mode:“week”, // instead of month
        weeksInView: 1
        size, that is all CSS (styling, which goes in MagicMirror/css/custom.css)
        the doc for Ext3 gives extensive info on css values…
        note the position you set it in also impacts its size…
        see this part of the module config for understanding the module positions
        https://docs.magicmirror.builders/modules/configuration.html#position
        G 1 Reply Last reply
        • G
          gerbenz @sdetweil
          @sdetweil ss
          @sdetweil said in Help with calendar:
          weeksInView: 1
          I hide the original calendar, butt then the MMM-CalendarEXT3 is empty.
          when i place back the original then its filled
            sdetweil @gerbenz
            @gerbenz is this the latest MM release 2 .30
            did you put on the fix?
            see https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
            • G
              gerbenz @sdetweil
              done,but not working. stays empty
                sdetweil @gerbenz
                @gerbenz can you show me output of
                git branch
                • G
                  gerbenz @sdetweil
                  • _fix_clipping
                    master
                    sdetweil @gerbenz
                    @gerbenz ok, can you show the output of starting MagicMirror
                    if you are using pm2 then
                    pm2 logs --lines=xxx
                    xxx is the number of most recent lines , default 15
                    you may need more
                    careful the cal broadcast message contains the full url so coukd expose personal info
                    is it broadcasting events ?
                    • G
                      gerbenz @sdetweil
                      only see events when i place orriginal callendar too,
                      then the addon works good.
                      wierd.
                        sdetweil @gerbenz
                        @gerbenz no idea
                        can you show the calendar configuration
                        (xxx out the urls but don’ change anything else)
                        you ARE just commenting out the calendar position line, right??
                        mine looks like this
                                classes: "page1",
                                //position: "top_left",
                                order: "*",
                                index: 1,
                                label: "instance 1",
                                  broadcastPastEvents: true,
                                  fetchInterval: 120000,
                                  urgency: 0,
                                  dateFormat: "Do.MMM, HH:mm",
                                  fullDayEventDateFormat: "Do.MMM",
                                  getRelative: 0,
                                  hidePrivate: true,
                        • G
                          gerbenz @sdetweil
                          		module: "MMM-CalendarExt3",
                          		header: "Afspraken",
                          		position: "middle_center",
                                      mode: "week",
                                      weeksInView: 1,
                                      weekIndex: 0,
                                      instanceId: "basicCalendar",
                                      locale: 'nl-NL',
                                      maxEventLines: 5,
                                      firstDayOfWeek: 0,
                          			startDayIndex: 0,
                                      displayEndTime: true,
                          	        calendarSet: null,
                                      refreshInterval: 60000,
                          		    fontsize: '30px',
                          		    eventHeight: '30px',
                          		    useWeather: false,
                          		    skipPassedEventToday: true,
                          					name: "werk stefnie",
                          					color: "red",
                          					url: "https://xxxx"
                                              url: "webcal://p181-caldav.icloud.com/published/xxxx",
                                              url: "webcal://p175-caldav.icloud.com/published/xxxx",
                            sdetweil @gerbenz
                            @gerbenz no, the default calendar, where the events come from
                            • G
                              gerbenz @sdetweil
                              			coloredText: true,
                                          broadcastPastEvents: false, // <= IMPORTANT to see past events
                              			fetchInterval: 1000 * 60 * 1,
                              					symbol: "werk stefnie",
                              					url: "xxxxx"
                                                  symbol: "Stefanie",
                                                  url: "webcal://p181-caldav.icloud.com/published/xxxxx",
                                                  symbol: "Gezin",
                                                  symbol: "Amber",
                                                  symbol: "Luna",
                                                  url: "webcal://p181-caldav.icloud.com/published/xxxxxx",
                                                  symbol: "Gerben",
                                                  url: "webcal://p175-caldav.icloud.com/published/xxxxx",
                                sdetweil @gerbenz
                                @gerbenz fetch every 60 seconds?
                                might be a spammer
                                how about try 5 mins
                                and comment out the position
                                Ext3 tries not to flash the screen w updates, you are probably running into that with so frequent updates and so many cals all at different times
                                you can look at the pm2’log and see timestamps when events are sent from each cal
                                • G
                                  gerbenz @sdetweil
                                  updating the screen works good.
                                  all calendars are working.
                                  butt when i hide the standard calendar then te addon calandar lost the events and is empty
                                    sdetweil @gerbenz
                                    @gerbenz but thats not how it works! the calendar module just keeps sending even when no position is specified.
                                    i have both setup on my system and it works perfectly
                                    maybe 10releases ago modules w no
                                    position would not be run
                                    you should be able to see the broadcasts go out in the logs
                                      @gerbenz show me the default calendar config whenExt3 is not working.
                                      • G
                                        gerbenz @sdetweil
                                        I changed nothing, only possition to unknown dor the standard calendar.
                                        And then the addon calendar is show no events
                                          sdetweil @gerbenz
                                          @gerbenz no, NOT unknown, thats invalid, module will not be loaded (there will be an error in the log about this)
                                          just add
                                          to the front of the line w position on it to comment it out
                                          see mine that i posted earlier
                                          https://forum.magicmirror.builders/post/123049
                                          • G
                                            gerbenz @sdetweil
                                            Okay i give it a try tomorrow.
                                            Thanks so far for youre help.
                                            I lett it know if it works.
                                            And do i need delete the adresses from the standard calendar or not?
